Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 03-06-2006, 07:41 PM   #1
Thumbs up 1.6 GPS Bugs
I think it's best to seperate all our bugs into categories as suggested in the forums. This way David can focus on one section at a time.
Anointed is offline   Reply With Quote
Advertisement Sponsored links
Old 03-06-2006, 08:25 PM   #2
BUG Intergrating Iguidance into 1.6 - Worked fine in 1.5, acting up in 1.6
I tried intergrating iGuidance and when I click any buttons on iguidance it takes me back to the CF main screen. It seems like the layers could be out of wack. The window name is correct. Any input?
Old 03-07-2006, 07:03 AM   #3
When my pc comes out of sleep mode Destinator reports that there is no gps signal which is fair enough. But to get destinator to start navigating again i have to go in setup/plugins/destinator and reset the com port. Is there anyway to get over this problem ?
clarkie is offline   Reply With Quote
Old 03-07-2006, 10:21 AM   #4
MySQL Error
veetid's Avatar
Are you using a USB GPS mouse? If so try updating your drivers...
david
veetid is offline   Reply With Quote
Old 03-07-2006, 06:56 PM   #5
EL CAMINO's Avatar
i have the same problem,i try to embbed iguidance and i just get the main window again over and over,man without my gps i cant use centrafuse what a shame.....
EL CAMINO is offline   Reply With Quote
Old 03-07-2006, 08:19 PM   #6
David is fixing Iguidance embed problem
Davids aware of the IGUIDANCE problem an is in the process of fixing it. In the mean time I guess we are out of luck, unless we go back to 1.5....lol
Old 03-08-2006, 02:56 AM   #7
Problem with correct location on map
In CF 1.5 with Destinator I had no problem with my gps and position.
After I have installed CF 1.6 my GPS shows a wrong position on the map. In Destinator I am driving about 500 meters next to the road....
Am I the only one with this problem. I am using a Danish map from Destinator v. 3
MaVa_DK is offline   Reply With Quote
Old 03-08-2006, 06:17 AM   #8
Bug or Feature request?
It annoys me the way the audio pauses when a voice prompt plays in the GPS plugin. Can you make it configurable so it doesnt pause.
Also, if you have the music paused (cause your on the phone or something) and a voice prompt sounds, it un-pauses the music.
jasonk is offline   Reply With Quote
Old 03-08-2006, 05:13 PM   #9
david
Installed new Drivers and moved the GPS mouse connection to its own usb port.
Previously it was plugged in a hub, only two ports on the AOpen mini pc.
Problem now fixed thanks very much.
Old 03-08-2006, 05:19 PM   #10
newers's Avatar
Imperial to Metric
Is there a way to change from Imperial to Metric measurements?
newers is offline   Reply With Quote
Old 03-08-2006, 05:23 PM   #11
MySQL Error
veetid's Avatar
If you go into settings and click plugins, you can then load the individual settings for each plugin...
david
Old 03-08-2006, 06:56 PM   #12
buurin's Avatar
This behavior existed in 1.5 but only sporadically...
Think we could make a batch file(called via a butotn in CF) to minimize CF and launch IG fullscreen or something... we need a workaround asap!
Also.. does the behavior only occur when using igmod?
B Smoov
Project Status: 90% Complete
Next Step: TIVO for Radio
Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
buurin is offline   Reply With Quote
Old 03-08-2006, 07:03 PM   #13
EL CAMINO's Avatar
with igmod and with iguidance too.the good thing is that i didnt install it in my car.for now once again i will continue using 1.4 that is very stable for me....
Old 03-09-2006, 05:13 PM   #14
MrWhite's Avatar
If you set CF to german language, the destinator buttons for day and night skin are switched. That means that the day skin button turns the night view on and so on...
Ctrl+Alt+Del
MrWhite is offline   Reply With Quote
Old 03-09-2006, 07:43 PM   #15
ShawJohn's Avatar
cf1.6 will not allow me to set the gps settings... Tried manually searching for the file with them in, and tried it through setup both in the menu, and by clicking the satelite logo...HELP!
ShawJohn is offline   Reply With Quote
Alturion Professional Advanced GPS 6 - The New D3 ? Is There A SDK ? ccsnet GPS 91 11-07-2006 04:47 PM
Several Bugs - GPS, Interface, Upgrade DReffects CF Bug Reports 1 12-14-2005 02:23 AM
GlobalSat BT-338 Review tom2112 The Review Palace 8 06-27-2005 11:02 AM
Alturion GPS Pro 5 + few bugs SuperSonic MediaCar 9 08-07-2004 11:54 AM
Mediacar V1.8.5 coyote MediaCar 47 02-16-2004 01:16 PM
