04-06-2006, 01:04 AM
#16
Vehicle: 02 vw jetta 1.8t
@jibberjabbs
We are working on getting the sensors to poll faster. Should help w/ RPM.
--raygun
01-14-2007, 08:25 PM
#17
Hey david have a question for you maybe a known problem but her goes. i just got my OBDPro serial scan tool in the mail hooked it up it works fine with the software it came with but, in CF when i put it on the right com por and select 327 it connects jstu fine but everythign always stays n/a once in a while certain things will come up with the correct temperature or what ever but the values will never change so far i got intake temp throttle position and oen other pne i think, but once it finaly gets a value of one of them it never seems to update. hopefully you may know why and can help me out!! or anybody
02-08-2007, 02:13 PM
#18
seem to have the same problem here, tried about everything in the meanwhile, port-speed, other than 327 ..
other port-speeds just gave me a disconnected ..
anybody a solution ? please ?
03-10-2008, 05:05 PM
#19
Vehicle: 2002/Subaru/Forester
I have the same problem with N/A everywhere on my Subaru Forester XT 2002 year SG5 (Japanese made right-handed car).
03-11-2008, 07:41 PM
#20
Vehicle: http://www.fluxmedia.net/
These issues should have since been fixed since the last post on this thread. Are you running CF version 1.47? You can also post your OBDII log, we can have a look at that to see any issues... You will find that I believe in <LocalSettings>/ApplicationData/Centrafuse/Plugins/OBDII/log.txt. Logging must also be enabled in obdii settings.
03-12-2008, 01:46 AM
#21
Ok, I'll make a log file.
I am using the latest version of CF 1.47. And the problem still exist.
03-12-2008, 04:22 AM
#22
So, here is the LOG-information:
P.S.
I Have a strange feeling, that my ECU didn't allow to read any information... Maybe I am wrong...
57:43:67>
58:01:12> openComPort(): Serial connection made, COM4 @ 38400bps
58:01:12> initDevice()
58:01:12> TX: atz<CR>
58:02:23> RX: atz<CR><CR><CR>ELM327 v1.2a<CR><CR>>
58:02:25> initDevice(): <ATZ Response> atz<CR><CR><CR>ELM327 v1.2a<CR><CR>>
58:02:25> TX: ate0<CR>
58:02:28> RX: ate0<CR>OK<CR><CR>>
58:02:31> TX: 0100<CR>
58:05:71> RX: 41 00 80 00 00 00 <CR><CR>>
58:05:71> initDevice(ELM327): <PIDS_SUPPORTED_00 Response> 41 00 80 00 00 00 <CR><CR>>
58:05:75> TX: 0100<CR>
58:05:89> RX: 41 00 80 00 00 00 <CR>
58:06:10> RX: 41 00 80 00 00 00 <CR><CR>>
58:06:14> TX: 0120<CR>
58:06:15> RXMSG: 41 00 80 00 00 00 <CR><CR>
58:06:17> 1a: 10000000000000000000000000000000
58:06:29> RX: 7F 01 11 <CR>
58:06:50> RX: 7F 01 11 <CR><CR>>
58:06:53> TX: 011C<CR>
58:06:68> RX: 7F 01 11 <CR>
58:06:87> RX: 7F 01 11 <CR><CR>>
58:08:79> TX: 03<CR>
58:08:95> RX: 43 00 00 00 00 00 00 <CR>
58:09:04> RX: 43 00 00 00 00 00 00 <CR><CR>>
58:09:04> RXMSG: 43 00 00 00 00 00 00 <CR><CR>
58:09:07> TX: 0120<CR>
58:09:23> RX: 7F 01 11 <CR>
58:09:29> RX: 7F 01 11 <CR><CR>>
58:11:23> TX: 03<CR>
58:11:40> RX: 43 00 00 00 00 00 00 <CR>
58:11:45> RX: 43 00 00 00 00 00 00 <CR><CR>>
58:11:45> RXMSG: 43 00 00 00 00 00 00 <CR><CR>
58:11:50> TX: 0120<CR>
58:11:68> RX: 7F 01 11 <CR>
58:11:71> RX: 7F 01 11 <CR><CR>>
58:13:65> TX: 03<CR>
58:13:79> RX: 43 00 00 00 00 00 00 <CR>
58:13:85> RX: 43 00 00 00 00 00 00 <CR><CR>>
58:13:85> RXMSG: 43 00 00 00 00 00 00 <CR><CR>
58:13:90> TX: 0120<CR>
58:14:04> RX: 7F 01 11 <CR>
58:14:12> RX: 7F 01 11 <CR><CR>>
58:15:84> RX: <CR><CR>ELM327 v1.2a<CR><CR>>
58:16:04> TX: 03<CR>
58:16:07> RX: 03<CR>
58:16:95> RX: 03<CR>SEARCHING...<CR>
58:16:95> RX(-):
58:19:53> Max read() loops reached!!
58:21:25> RX: UNABLE TO CONNECT<CR><CR>>
58:31:45> COM_MONITOR_DELAY reached
58:40:06> SENSOR1_CLICK Pg.1 False
58:40:67> SENSOR1_CLICK Pg.1 True
58:41:09> SENSOR1_CLICK Pg.1 False
58:41:53> SENSOR1_CLICK Pg.1 True
58:59:46> wThread2() exiting
58:59:53> wThread1() exiting
58:59:54> closeComPort(): COM port closed
03-12-2008, 12:09 PM
#23
OK I got the log entries I will look into these as soon as I can, been busy lately with the latest release but will get to these OBDII issue as soon as I can...
Also, try turning the "Ignore Supported PID List" on in the OBDII settings, see if that does anything for you...
03-12-2008, 01:39 PM
#24
I tried to set "Ignore Supported PID List", but after that Centrafuse didn't connect to ELM327 at all.
07-06-2008, 12:41 AM
#25
Vehicle: 06 Impreza Hatch
Was there any fix for this issue at all?
I'm having thr problem where it connects and displays data fine for a while (sometimes a few seconds, sometimes a few minutes) before the data 'freezes' and no longer updates.
I'm using the ODBPros interface
Log data:
45:46:33> a(): openComPort(): Serial connection made, COM6 @ 57600bps
45:46:33> a(): initDevice()
45:46:33> a(): TX: atz<CR>
45:47:49> a(): RX: <CR><LF><CR><LF>ELM327 v1.0a compatible<CR><LF>>
45:47:50> a(): initDevice(): <ATZ Response> <CR><LF><CR><LF>ELM327 v1.0a compatible<CR><LF>>
45:47:50> a(): TX: ate0<CR>
45:47:55> a(): RX: ate0<CR><LF>OK<CR><LF>>
45:47:56> a(): TX: 0100<CR>
45:50:97> a(): RX: BUS INIT: OK<CR><LF>NO DATA<CR><LF>>
45:50:98> a(): initDevice(ELM327): <PIDS_SUPPORTED_00 Response> BUS INIT: OK<CR><LF>NO DATA<CR><LF>>
45:51:10> a(): TX: 011C<CR>
45:51:25> a(): RX: 41 1C 06 <CR><LF>
45:51:41> a(): RX: 41 1C 06 <CR><LF>>
45:51:44> a(): RXMSG: 41 1C 06 <CR><LF>
45:51:48> a(): TX: 010D<CR>
45:51:63> a(): RX: 41 0D 00 <CR><LF>
45:51:79> a(): RX: 41 0D 00 <CR><LF>>
45:51:80> a(): RXMSG: 41 0D 00 <CR><LF>
45:51:81> a(): TX: 010C<CR>
45:51:96> a(): RX: 41 0C 0A BE <CR><LF>
45:52:12> a(): RX: 41 0C 0A BE <CR><LF>>
45:52:13> a(): RXMSG: 41 0C 0A BE <CR><LF>
45:52:20> a(): TX: 0105<CR>
45:52:50> a(): RX: NO DATA<CR><LF>>
45:52:69> a(): TX: 010D<CR>
45:52:80> a(): RX: 41 0D 00 <CR><LF>
45:53:00> a(): RX: 41 0D 00 <CR><LF>>
45:53:01> a(): RXMSG: 41 0D 00 <CR><LF>
45:53:01> a(): TX: 010C<CR>
45:53:15> a(): RX: 41 0C 0A BE <CR><LF>
45:53:32> a(): RX: 41 0C 0A BE <CR><LF>>
45:53:33> a(): RXMSG: 41 0C 0A BE <CR><LF>
45:53:37> a(): TX: 0105<CR>
45:53:47> a(): RX: 41 05 87 <CR><LF>
45:53:70> a(): RX: 41 05 87 <CR><LF>>
45:53:71> a(): RXMSG: 41 05 87 <CR><LF>
45:53:85> a(): TX: 010D<CR>
45:54:00> a(): RX: 41 0D 00 <CR><LF>
45:54:17> a(): RX: 41 0D 00 <CR><LF>>
45:54:19> a(): RXMSG: 41 0D 00 <CR><LF>
45:54:21> a(): TX: 010C<CR>
45:54:34> a(): RX: 41 0C 0A 8C <CR><LF>
45:54:52> a(): RX: 41 0C 0A 8C <CR><LF>>
45:54:54> a(): RXMSG: 41 0C 0A 8C <CR><LF>
45:54:57> a(): TX: 0105<CR>
45:54:70> a(): RX: 41 05 87 <CR><LF>
45:54:90> a(): RX: 41 05 87 <CR><LF>>
45:54:91> a(): RXMSG: 41 05 87 <CR><LF>
45:55:03> a(): TX: 010D<CR>
45:55:16> a(): RX: 41 0D 00 <CR><LF>
45:55:33> a(): RX: 41 0D 00 <CR><LF>>
45:55:35> a(): RXMSG: 41 0D 00 <CR><LF>
45:55:35> a(): TX: 010C<CR>
45:55:48> a(): RX: 41 0C 0A 8C <CR><LF>
45:55:69> a(): RX: 41 0C 0A 8C <CR><LF>>
45:55:71> a(): RXMSG: 41 0C 0A 8C <CR><LF>
45:55:88> a(): TX: 010D<CR>
45:56:01> a(): RX: 41 0D 00 <CR><LF>
45:56:20> a(): RX: 41 0D 00 <CR><LF>>
45:56:22> a(): RXMSG: 41 0D 00 <CR><LF>
45:56:22> a(): TX: 010C<CR>
45:56:35> a(): RX: 41 0C 0A BE <CR><LF>
45:56:52> a(): RX: 41 0C 0A BE <CR><LF>>
45:56:53> a(): RXMSG: 41 0C 0A BE <CR><LF>
45:56:85> a(): TX: 03<CR>
45:57:00> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
45:57:16> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
45:57:18> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
45:57:21> a(): TX: 010D<CR>
45:57:31> a(): RX: 41 0D 00 <CR><LF>
45:57:52> a(): RX: 41 0D 00 <CR><LF>>
45:57:53> a(): RXMSG: 41 0D 00 <CR><LF>
45:57:55> a(): TX: 010C<CR>
45:57:70> a(): RX: 41 0C 0A BE <CR><LF>
45:57:88> a(): RX: 41 0C 0A BE <CR><LF>>
45:57:90> a(): RXMSG: 41 0C 0A BE <CR><LF>
45:57:93> a(): TX: 0105<CR>
45:58:05> a(): RX: 41 05 87 <CR><LF>
45:58:24> a(): RX: 41 05 87 <CR><LF>>
45:58:25> a(): RXMSG: 41 05 87 <CR><LF>
45:58:37> a(): TX: 010D<CR>
45:58:52> a(): RX: 41 0D 00 <CR><LF>
45:58:70> a(): RX: 41 0D 00 <CR><LF>>
45:58:72> a(): RXMSG: 41 0D 00 <CR><LF>
45:58:74> a(): TX: 010C<CR>
45:58:84> a(): RX: 41 0C 0A BE <CR><LF>
45:59:04> a(): RX: 41 0C 0A BE <CR><LF>>
45:59:05> a(): RXMSG: 41 0C 0A BE <CR><LF>
45:59:11> a(): TX: 0105<CR>
45:59:21> a(): RX: 4
45:59:25> a(): RX: 41 05 87 <CR><LF>
45:59:44> a(): RX: 41 05 87 <CR><LF>>
45:59:45> a(): RXMSG: 41 05 87 <CR><LF>
45:59:57> a(): TX: 010D<CR>
45:59:72> a(): RX: 41 0D 00 <CR><LF>
45:59:87> a(): RX: 41 0D 00 <CR><LF>>
45:59:88> a(): RXMSG: 41 0D 00 <CR><LF>
45:59:90> a(): TX: 010C<CR>
46:00:05> a(): RX: 41 0C 0A 8C <CR><LF>
46:00:21> a(): RX: 41 0C 0A 8C <CR><LF>>
46:00:24> a(): RXMSG: 41 0C 0A 8C <CR><LF>
46:00:30> a(): TX: 0105<CR>
46:00:44> a(): RX: 41 05 87 <CR><LF>
46:00:69> a(): RX: 41 05 87 <CR><LF>>
46:00:71> a(): RXMSG: 41 05 87 <CR><LF>
46:00:87> a(): TX: 010D<CR>
46:01:01> a(): RX: 41 0D 00 <CR><LF>
46:01:18> a(): RX: 41 0D 00 <CR><LF>>
46:01:20> a(): RXMSG: 41 0D 00 <CR><LF>
46:01:21> a(): TX: 010C<CR>
46:01:35> a(): RX: 41 0C 0A BE <CR><LF>
46:01:53> a(): RX: 41 0C 0A BE <CR><LF>>
46:01:54> a(): RXMSG: 41 0C 0A BE <CR><LF>
46:01:80> a(): TX: 010D<CR>
46:01:93> a(): RX: 41 0D 00 <CR><LF>
46:02:13> a(): RX: 41 0D 00 <CR><LF>>
46:02:16> a(): RXMSG: 41 0D 00 <CR><LF>
46:02:16> a(): TX: 010C<CR>
46:02:31> a(): RX: 41 0C 0A 8C <CR><LF>
46:02:47> a(): RX: 41 0C 0A 8C <CR><LF>>
46:02:49> a(): RXMSG: 41 0C 0A 8C <CR><LF>
46:02:68> a(): TX: 03<CR>
46:02:80> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
46:03:00> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
46:03:01> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
46:03:07> a(): TX: 010D<CR>
46:03:40> a(): RX: NO DATA<CR><LF>>
46:03:41> a(): TX: 010C<CR>
46:03:51> a(): RX: 41 0C 0A 8C <CR><LF>
46:03:72> a(): RX: 41 0C 0A 8C <CR><LF>>
46:03:73> a(): RXMSG: 41 0C 0A 8C <CR><LF>
46:03:76> a(): TX: 0105<CR>
46:03:88> a(): RX: 41 05 87 <CR><LF>
46:04:06> a(): RX: 41 05 87 <CR><LF>>
46:04:08> a(): RXMSG: 41 05 87 <CR><LF>
46:04:20> a(): TX: 010D<CR>
46:04:32> a(): RX: 41 0D 00 <CR><LF>
46:04:52> a(): RX: 41 0D 00 <CR><LF>>
46:04:53> a(): RXMSG: 41 0D 00 <CR><LF>
46:04:56> a(): TX: 010C<CR>
46:04:70> a(): RX: 41 0C 0A 8C <CR><LF>
46:04:88> a(): RX: 41 0C 0A 8C <CR><LF>>
46:04:89> a(): RXMSG: 41 0C 0A 8C <CR><LF>
46:04:93> a(): TX: 0105<CR>
46:05:04> a(): RX: 41 05 87 <CR><LF>
46:05:24> a(): RX: 41 05 87 <CR><LF>>
46:05:25> a(): RXMSG: 41 05 87 <CR><LF>
46:05:39> a(): TX: 010D<CR>
46:05:52> a(): RX: 41 0D 00 <CR><LF>
46:05:73> a(): RX: 41 0D 00 <CR><LF>>
46:05:75> a(): RXMSG: 41 0D 00 <CR><LF>
46:05:77> a(): TX: 010C<CR>
46:05:88> a(): RX: 41 0C 0A BE <CR><LF>
46:06:08> a(): RX: 41 0C 0A BE <CR><LF>>
46:06:17> a(): RXMSG: 41 0C 0A BE <CR><LF>
46:06:27> a(): TX: 0105<CR>
46:06:43> a(): RX: 41 05 88 <CR><LF>
46:06:75> a(): RX: 41 05 88 <CR><LF>>
46:06:76> a(): RXMSG: 41 05 88 <CR><LF>
46:06:94> a(): TX: 010D<CR>
46:07:37> a(): RX: 41 0D 00 <CR><LF>>
46:07:39> a(): RXMSG: 41 0D 00 <CR><LF>
46:07:39> a(): TX: 010C<CR>
46:07:52> a(): RX: 41 0C 0B EA <CR><LF>
46:07:70> a(): RX: 41 0C 0B EA <CR><LF>>
46:07:73> a(): RXMSG: 41 0C 0B EA <CR><LF>
46:07:89> a(): TX: 010D<CR>
46:08:08> a(): RX: 41 0D 00 <CR><LF>
46:08:21> a(): RX: 41 0D 00 <CR><LF>>
46:08:24> a(): RXMSG: 41 0D 00 <CR><LF>
46:08:24> a(): TX: 010C<CR>
46:08:40> a(): RX: 41 0C 0C E4 <CR><LF>
46:08:57> a(): RX: 41 0C 0C E4 <CR><LF>>
46:08:74> a(): RXMSG: 41 0C 0C E4 <CR><LF>
46:08:91> a(): TX: 03<CR>
46:09:05> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
46:09:25> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
46:09:29> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
46:09:33> a(): TX: 010D<CR>
46:09:46> a(): RX: 41 0D 00 <CR><LF>
46:09:70> a(): RX: 41 0D 00 <CR><LF>>
46:09:73> a(): RXMSG: 41 0D 00 <CR><LF>
46:09:77> a(): TX: 010C<CR>
46:09:92> a(): RX: 41 0C 0B EA <CR><LF>
46:10:08> a(): RX: 41 0C 0B EA <CR><LF>>
46:10:10> a(): RXMSG: 41 0C 0B EA <CR><LF>
46:10:12> a(): TX: 0105<CR>
46:10:26> a(): RX: 41 05 88 <CR><LF>
46:10:43> a(): RX: 41 05 88 <CR><LF>>
46:10:44> a(): RXMSG: 41 05 88 <CR><LF>
46:10:57> a(): TX: 010D<CR>
46:10:73> a(): RX: 41 0D 00 <CR><LF>
46:10:88> a(): RX: 41 0D 00 <CR><LF>>
46:10:89> a(): RXMSG: 41 0D 00 <CR><LF>
46:10:91> a(): TX: 010C<CR>
46:11:04> a(): RX: 41 0C 0B B8 <CR><LF>
46:11:24> a(): RX: 41 0C 0B B8 <CR><LF>>
46:11:25> a(): RXMSG: 41 0C 0B B8 <CR><LF>
46:11:36> a(): TX: 0105<CR>
46:11:48> a(): RX: 41 05 88 <CR><LF>
46:11:70> a(): RX: 41 05 88 <CR><LF>>
46:11:71> a(): RXMSG: 41 05 88 <CR><LF>
46:11:82> a(): TX: 010D<CR>
46:11:96> a(): RX: 41 0D 00 <CR><LF>
46:12:13> a(): RX: 41 0D 00 <CR><LF>>
46:12:14> a(): RXMSG: 41 0D 00 <CR><LF>
46:12:16> a(): TX: 010C<CR>
46:12:28> a(): RX: 41 0C 0B 22 <CR><LF>
46:12:48> a(): RX: 41 0C 0B 22 <CR><LF>>
46:12:49> a(): RXMSG: 41 0C 0B 22 <CR><LF>
46:12:56> a(): TX: 0105<CR>
46:12:74> a(): RX: 41 05 88 <CR><LF>
46:12:88> a(): RX: 41 05 88 <CR><LF>>
46:12:90> a(): RXMSG: 41 05 88 <CR><LF>
46:13:05> a(): TX: 010D<CR>
46:13:15> a(): RX: 41 0D 00 <CR><LF>
46:13:37> a(): RX: 41 0D 00 <CR><LF>>
46:13:38> a(): RXMSG: 41 0D 00 <CR><LF>
46:13:40> a(): TX: 010C<CR>
46:13:53> a(): RX: 41 0C 0B 22 <CR><LF>
46:13:71> a(): RX: 41 0C 0B 22 <CR><LF>>
46:13:73> a(): RXMSG: 41 0C 0B 22 <CR><LF>
46:13:95> a(): TX: 010D<CR>
46:14:09> a(): RX: 41 0D 00 <CR><LF>
46:14:28> a(): RX: 41 0D 00 <CR><LF>>
46:14:30> a(): RXMSG: 41 0D 00 <CR><LF>
46:14:33> a(): TX: 010C<CR>
46:14:44> a(): RX: 41 0C 0B 54 <CR><LF>
46:14:73> a(): RX: 41 0C 0B 54 <CR><LF>>
46:14:74> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:14:99> a(): TX: 03<CR>
46:15:11> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
46:15:29> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
46:15:32> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
46:15:36> a(): TX: 010D<CR>
46:15:49> a(): RX: 41 0D 00 <CR><LF>
46:15:70> a(): RX: 41 0D 00 <CR><LF>>
46:15:71> a(): RXMSG: 41 0D 00 <CR><LF>
46:15:74> a(): TX: 010C<CR>
46:15:87> a(): RX: 41 0C 0B 22 <CR><LF>
46:16:09> a(): RX: 41 0C 0B 22 <CR><LF>>
46:16:11> a(): RXMSG: 41 0C 0B 22 <CR><LF>
46:16:16> a(): TX: 0105<CR>
46:16:29> a(): RX: 41 05 88 <CR><LF>
46:16:47> a(): RX: 41 05 88 <CR><LF>>
46:16:48> a(): RXMSG: 41 05 88 <CR><LF>
46:16:68> a(): TX: 010D<CR>
46:16:79> a(): RX: 41 0D 00 <CR><LF>
46:17:00> a(): RX: 41 0D 00 <CR><LF>>
46:17:01> a(): RXMSG: 41 0D 00 <CR><LF>
46:17:02> a(): TX: 010C<CR>
46:17:17> a(): RX: 41 0C 0B 22 <CR><LF>
46:17:32> a(): RX: 41 0C 0B 22 <CR><LF>>
46:17:33> a(): RXMSG: 41 0C 0B 22 <CR><LF>
46:17:36> a(): TX: 0105<CR>
46:17:48> a(): RX: 41 05 88 <CR><LF>
46:17:69> a(): RX: 41 05 88 <CR><LF>>
46:17:70> a(): RXMSG: 41 05 88 <CR><LF>
46:17:81> a(): TX: 010D<CR>
46:17:95> a(): RX: 41 0D 00 <CR><LF>
46:18:12> a(): RX: 41 0D 00 <CR><LF>>
46:18:13> a(): RXMSG: 41 0D 00 <CR><LF>
46:18:15> a(): TX: 010C<CR>
46:18:28> a(): RX: 41 0C 0B 54 <CR><LF>
46:18:45> a(): RX: 41 0C 0B 54 <CR><LF>>
46:18:46> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:18:51> a(): TX: 0105<CR>
46:18:70> a(): RX: 41 05 88 <CR><LF>
46:18:84> a(): RX: 41 05 88 <CR><LF>>
46:18:85> a(): RXMSG: 41 05 88 <CR><LF>
46:18:96> a(): TX: 010D<CR>
46:19:08> a(): RX: 41 0D 00 <CR><LF>
46:19:27> a(): RX: 41 0D 00 <CR><LF>>
46:19:28> a(): RXMSG: 41 0D 00 <CR><LF>
46:19:30> a(): TX: 010C<CR>
46:19:45> a(): RX: 41 0C 0B 22 <CR><LF>
46:19:70> a(): RX: 41 0C 0B 22 <CR><LF>>
46:19:72> a(): RXMSG: 41 0C 0B 22 <CR><LF>
46:19:94> a(): TX: 010D<CR>
46:20:08> a(): RX: 41 0D 00 <CR><LF>
46:20:26> a(): RX: 41 0D 00 <CR><LF>>
46:20:28> a(): RXMSG: 41 0D 00 <CR><LF>
46:20:28> a(): TX: 010C<CR>
46:20:42> a(): RX: 41 0C 0B 22 <CR><LF>
46:20:60> a(): RX: 41 0C 0B 22 <CR><LF>>
46:20:69> a(): RXMSG: 41 0C 0B 22 <CR><LF>
46:20:88> a(): TX: 03<CR>
46:21:02> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
46:21:20> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
46:21:21> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
46:21:25> a(): TX: 010D<CR>
46:21:40> a(): RX: 41 0D 00 <CR><LF>
46:21:55> a(): RX: 41 0D 00 <CR><LF>>
46:21:57> a(): RXMSG: 41 0D 00 <CR><LF>
46:21:60> a(): TX: 010C<CR>
46:21:73> a(): RX: 41 0C 0B 54 <CR><LF>
46:21:90> a(): RX: 41 0C 0B 54 <CR><LF>>
46:21:91> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:21:97> a(): TX: 0105<CR>
46:22:09> a(): RX: 41 05 88 <CR><LF>
46:22:27> a(): RX: 41 05 88 <CR><LF>>
46:22:28> a(): RXMSG: 41 05 88 <CR><LF>
46:22:40> a(): TX: 010D<CR>
46:22:49> a(): RX: 4
46:22:52> a(): RX: 41 0D 00 <CR><LF>
46:22:72> a(): RX: 41 0D 00 <CR><LF>>
46:22:74> a(): RXMSG: 41 0D 00 <CR><LF>
46:22:78> a(): TX: 010C<CR>
46:22:88> a(): RX: 41 0C 0B 54 <CR><LF>
46:23:08> a(): RX: 41 0C 0B 54 <CR><LF>>
46:23:09> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:23:12> a(): TX: 0105<CR>
46:23:27> a(): RX: 41 05 88 <CR><LF>
46:23:48> a(): RX: 41 05 88 <CR><LF>>
46:23:50> a(): RXMSG: 41 05 88 <CR><LF>
46:23:81> a(): TX: 010D<CR>
46:24:13> a(): RX: NO DATA<CR><LF>>
46:24:27> a(): TX: 010C<CR>
46:24:40> a(): RX: 41 0C 0B 22 <CR><LF>
46:24:75> a(): RX: 41 0C 0B 22 <CR><LF>>
46:24:76> a(): RXMSG: 41 0C 0B 22 <CR><LF>
46:24:91> a(): TX: 0105<CR>
46:25:04> a(): RX: 41 05 87 <CR><LF>
46:25:23> a(): RX: 41 05 87 <CR><LF>>
46:25:24> a(): RXMSG: 41 05 87 <CR><LF>
46:25:48> a(): TX: 010D<CR>
46:25:76> a(): RX: 41 0D 00 <CR><LF>
46:25:78> a(): RX: 41 0D 00 <CR><LF>>
46:25:81> a(): RXMSG: 41 0D 00 <CR><LF>
46:25:93> a(): TX: 010C<CR>
46:26:05> a(): RX: 41 0C 0B 54 <CR><LF>
46:26:25> a(): RX: 41 0C 0B 54 <CR><LF>>
46:26:26> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:26:55> a(): TX: 010D<CR>
46:26:71> a(): RX: 41 0D 00 <CR><LF>
46:26:87> a(): RX: 41 0D 00 <CR><LF>>
46:26:89> a(): RXMSG: 41 0D 00 <CR><LF>
46:26:99> a(): TX: 010C<CR>
46:27:13> a(): RX: 41 0C 0B 22 <CR><LF>
46:27:29> a(): RX: 41 0C 0B 22 <CR><LF>>
46:27:31> a(): RXMSG: 41 0C 0B 22 <CR><LF>
46:27:59> a(): TX: 03<CR>
46:27:76> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
46:27:92> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
46:27:94> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
46:28:04> a(): TX: 010D<CR>
46:28:19> a(): RX: 41 0D 00 <CR><LF>
46:28:36> a(): RX: 41 0D 00 <CR><LF>>
46:28:37> a(): RXMSG: 41 0D 00 <CR><LF>
46:28:47> a(): TX: 010C<CR>
46:28:60> a(): RX: 41 0C 0B 54 <CR><LF>
46:28:80> a(): RX: 41 0C 0B 54 <CR><LF>>
46:28:82> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:28:95> a(): TX: 0105<CR>
46:29:11> a(): RX: 41 05 87 <CR><LF>
46:29:29> a(): RX: 41 05 87 <CR><LF>>
46:29:31> a(): RXMSG: 41 05 87 <CR><LF>
46:29:52> a(): TX: 010D<CR>
46:29:72> a(): RX: 41 0D 00 <CR><LF>
46:29:82> a(): RX: 41 0D 00 <CR><LF>>
46:29:83> a(): RXMSG: 41 0D 00 <CR><LF>
46:29:95> a(): TX: 010C<CR>
46:30:05> a(): RX: 41 0C 0B 54 <CR><LF>
46:30:28> a(): RX: 41 0C 0B 54 <CR><LF>>
46:30:29> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:30:43> a(): TX: 0105<CR>
46:30:58> a(): RX: 41 05 86 <CR><LF>
46:30:76> a(): RX: 41 05 86 <CR><LF>>
46:30:78> a(): RXMSG: 41 05 86 <CR><LF>
46:31:01> a(): TX: 010D<CR>
46:31:15> a(): RX: 41 0D 00 <CR><LF>
46:31:32> a(): RX: 41 0D 00 <CR><LF>>
46:31:34> a(): RXMSG: 41 0D 00 <CR><LF>
46:31:46> a(): TX: 010C<CR>
46:31:82> a(): RX: NO DATA<CR><LF>>
46:31:96> a(): TX: 0105<CR>
46:32:08> a(): RX: 41 05 86 <CR><LF>
46:32:28> a(): RX: 41 05 86 <CR><LF>>
46:32:29> a(): RXMSG: 41 05 86 <CR><LF>
46:32:53> a(): TX: 010D<CR>
46:32:81> a(): RX: 41 0D 00 <CR><LF>
46:32:85> a(): RX: 41 0D 00 <CR><LF>>
46:32:86> a(): RXMSG: 41 0D 00 <CR><LF>
46:32:97> a(): TX: 010C<CR>
46:33:09> a(): RX: 41 0C 0B 54 <CR><LF>
46:33:29> a(): RX: 41 0C 0B 54 <CR><LF>>
46:33:30> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:33:59> a(): TX: 010D<CR>
46:33:80> a(): RX: 41 0D 00 <CR><LF>
46:33:92> a(): RX: 41 0D 00 <CR><LF>>
46:33:94> a(): RXMSG: 41 0D 00 <CR><LF>
46:34:04> a(): TX: 010C<CR>
46:34:16> a(): RX: 41 0C 0B 54 <CR><LF>
46:34:36> a(): RX: 41 0C 0B 54 <CR><LF>>
46:34:37> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:34:77> a(): TX: 03<CR>
46:34:91> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
46:35:08> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
46:35:09> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
46:35:20> a(): TX: 010D<CR>
46:35:36> a(): RX: 41 0D 00 <CR><LF>
46:35:51> a(): RX: 41 0D 00 <CR><LF>>
46:35:53> a(): RXMSG: 41 0D 00 <CR><LF>
46:35:69> a(): TX: 010C<CR>
46:35:91> a(): RX: 41 0C 0B 54 <CR><LF>
46:36:06> a(): RX: 41 0C 0B 54 <CR><LF>>
46:36:09> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:36:22> a(): TX: 0105<CR>
46:36:37> a(): RX: 41 05 86 <CR><LF>
46:36:52> a(): RX: 41 05 86 <CR><LF>>
46:36:53> a(): RXMSG: 41 05 86 <CR><LF>
46:36:85> a(): TX: 010D<CR>
46:37:00> a(): RX: 41 0D 00 <CR><LF>
46:37:16> a(): RX: 41 0D 00 <CR><LF>>
46:37:17> a(): RXMSG: 41 0D 00 <CR><LF>
46:37:29> a(): TX: 010C<CR>
46:37:43> a(): RX: 41 0C 0B 22 <CR><LF>
46:37:74> a(): RX: 41 0C 0B 22 <CR><LF>>
46:37:77> a(): RXMSG: 41 0C 0B 22 <CR><LF>
46:37:92> a(): TX: 0105<CR>
46:38:03> a(): RX: 41 05 85 <CR><LF>
46:38:24> a(): RX: 41 05 85 <CR><LF>>
46:38:25> a(): RXMSG: 41 05 85 <CR><LF>
46:38:48> a(): TX: 010D<CR>
46:38:75> a(): RX: 41 0D 00 <CR><LF>
46:38:77> a(): RX: 41 0D 00 <CR><LF>>
46:38:80> a(): RXMSG: 41 0D 00 <CR><LF>
46:38:91> a(): TX: 010C<CR>
46:39:03> a(): RX: 41 0C 0B 54 <CR><LF>
46:39:23> a(): RX: 41 0C 0B 54 <CR><LF>>
46:39:24> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:39:40> a(): TX: 0105<CR>
46:39:51> a(): RX: 41 05 85 <CR><LF>
46:39:72> a(): RX: 41 05 85 <CR><LF>>
46:39:74> a(): RXMSG: 41 05 85 <CR><LF>
46:39:96> a(): TX: 010D<CR>
46:40:10> a(): RX: 41 0D 00 <CR><LF>
46:40:28> a(): RX: 41 0D 00 <CR><LF>>
46:40:29> a(): RXMSG: 41 0D 00 <CR><LF>
46:40:40> a(): TX: 010C<CR>
46:40:55> a(): RX: 41 0C 0B 54 <CR><LF>
46:40:75> a(): RX: 41 0C 0B 54 <CR><LF>>
46:40:77> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:41:04> a(): TX: 010D<CR>
46:41:15> a(): RX: 41 0D 00 <CR><LF>
46:41:36> a(): RX: 41 0D 00 <CR><LF>>
46:41:37> a(): RXMSG: 41 0D 00 <CR><LF>
46:41:48> a(): TX: 010C<CR>
46:41:70> a(): RX: 41 0C 0B 22 <CR><LF>
46:41:81> a(): RX: 41 0C 0B 22 <CR><LF>>
46:41:85> a(): RXMSG: 41 0C 0B 22 <CR><LF>
46:42:24> a(): TX: 03<CR>
46:42:42> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
46:42:56> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
46:42:58> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
46:42:69> a(): TX: 010D<CR>
46:42:80> a(): RX: 41 0D 00 <CR><LF>
46:43:01> a(): RX: 41 0D 00 <CR><LF>>
46:43:02> a(): RXMSG: 41 0D 00 <CR><LF>
46:43:02> a(): TX: 010C<CR>
46:43:13> a(): RX: 41 0C 0B 54 <CR><LF>
46:43:36> a(): RX: 41 0C 0B 54 <CR><LF>>
46:43:37> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:43:40> a(): TX: 0105<CR>
46:43:52> a(): RX: 41 05 85 <CR><LF>
46:43:72> a(): RX: 41 05 85 <CR><LF>>
46:43:73> a(): RXMSG: 41 05 85 <CR><LF>
46:43:91> a(): TX: 010D<CR>
46:44:04> a(): RX: 41 0D 00 <CR><LF>
46:44:23> a(): RX: 41 0D 00 <CR><LF>>
46:44:24> a(): RXMSG: 41 0D 00 <CR><LF>
46:44:25> a(): TX: 010C<CR>
46:44:39> a(): RX: 41 0C 0B 54 <CR><LF>
46:44:55> a(): RX: 41 0C 0B 54 <CR><LF>>
46:44:56> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:44:60> a(): TX: 0105<CR>
46:44:74> a(): RX: 41 05 85 <CR><LF>
46:44:92> a(): RX: 41 05 85 <CR><LF>>
46:44:93> a(): RXMSG: 41 05 85 <CR><LF>
46:45:06> a(): TX: 010D<CR>
46:45:15> a(): RX: 4
46:45:16> a(): RX: 41 0D 00 <CR><LF>
46:45:36> a(): RX: 41 0D 00 <CR><LF>>
46:45:37> a(): RXMSG: 41 0D 00 <CR><LF>
46:45:38> a(): TX: 010C<CR>
46:45:52> a(): RX: 41 0C 0B 54 <CR><LF>
46:45:69> a(): RX: 41 0C 0B 54 <CR><LF>>
46:45:71> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:45:74> a(): TX: 0105<CR>
46:45:87> a(): RX: 41 05 84 <CR><LF>
46:46:04> a(): RX: 41 05 84 <CR><LF>>
46:46:05> a(): RXMSG: 41 05 84 <CR><LF>
46:46:19> a(): TX: 010D<CR>
46:46:32> a(): RX: 41 0D 00 <CR><LF>
46:46:53> a(): RX: 41 0D 00 <CR><LF>>
46:46:54> a(): RXMSG: 41 0D 00 <CR><LF>
46:46:55> a(): TX: 010C<CR>
46:46:70> a(): RX: 41 0C 0B 54 <CR><LF>
46:46:86> a(): RX: 41 0C 0B 54 <CR><LF>>
46:46:89> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:47:08> a(): TX: 010D<CR>
46:47:18> a(): RX: 41 0D 00 <CR><LF>
46:47:41> a(): RX: 41 0D 00 <CR><LF>>
46:47:42> a(): RXMSG: 41 0D 00 <CR><LF>
46:47:42> a(): TX: 010C<CR>
46:47:56> a(): RX: 41 0C 0B 54 <CR><LF>
46:47:73> a(): RX: 41 0C 0B 54 <CR><LF>>
46:47:75> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:47:94> a(): TX: 03<CR>
46:48:21> a(): RX: NO DATA<CR><LF>>
46:48:28> a(): TX: 010D<CR>
46:48:41> a(): RX: 41 0D 00 <CR><LF>
46:48:69> a(): RX: 41 0D 00 <CR><LF>>
46:48:72> a(): RXMSG: 41 0D 00 <CR><LF>
46:48:74> a(): TX: 010C<CR>
46:48:85> a(): RX: 41 0C 0B 54 <CR><LF>
46:49:04> a(): RX: 41 0C 0B 54 <CR><LF>>
46:49:05> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:49:10> a(): TX: 0105<CR>
46:49:24> a(): RX: 41 05 84 <CR><LF>
46:49:41> a(): RX: 41 05 84 <CR><LF>>
46:49:43> a(): RXMSG: 41 05 84 <CR><LF>
46:49:53> a(): TX: 010D<CR>
46:49:72> a(): RX: 41 0D 00 <CR><LF>
46:49:83> a(): RX: 41 0D 00 <CR><LF>>
46:49:84> a(): RXMSG: 41 0D 00 <CR><LF>
46:49:85> a(): TX: 010C<CR>
46:51:57> a(): RX: 41 0C 0B 54 <CR><LF>>
46:51:58> a(): RXMSG: 41 0C 0B 54 <CR><LF>
46:51:62> a(): TX: 0105<CR>
46:51:75> a(): RX: 41 05 84 <CR><LF>
46:51:93> a(): RX: 41 05 84 <CR><LF>>
46:51:94> a(): RXMSG: 41 05 84 <CR><LF>
46:52:08> a(): TX: 010D<CR>
46:52:20> a(): RX: 41 0D 00 <CR><LF>
46:52:38> a(): RX: 41 0D 00 <CR><LF>>
46:52:40> a(): RXMSG: 41 0D 00 <CR><LF>
46:52:40> a(): TX: 010C<CR>
46:52:53> a(): RX: 41 0C 10 36 <CR><LF>
46:52:72> a(): RX: 41 0C 10 36 <CR><LF>>
46:52:73> a(): RXMSG: 41 0C 10 36 <CR><LF>
46:52:79> a(): TX: 0105<CR>
46:52:92> a(): RX: 41 05 84 <CR><LF>
46:53:10> a(): RX: 41 05 84 <CR><LF>>
46:53:11> a(): RXMSG: 41 05 84 <CR><LF>
46:53:21> a(): TX: 010D<CR>
46:53:37> a(): RX: 41 0D 00 <CR><LF>
46:53:53> a(): RX: 41 0D 00 <CR><LF>>
46:53:54> a(): RXMSG: 41 0D 00 <CR><LF>
46:53:55> a(): TX: 010C<CR>
46:53:72> a(): RX: 41 0C 12 C0 <CR><LF>
46:53:86> a(): RX: 41 0C 12 C0 <CR><LF>>
46:53:88> a(): RXMSG: 41 0C 12 C0 <CR><LF>
46:54:08> a(): TX: 010D<CR>
46:54:21> a(): RX: 41 0D 00 <CR><LF>
46:54:38> a(): RX: 41 0D 00 <CR><LF>>
46:54:41> a(): RXMSG: 41 0D 00 <CR><LF>
46:54:41> a(): TX: 010C<CR>
46:54:54> a(): RX: 41 0C 12 2A <CR><LF>
46:54:71> a(): RX: 41 0C 12 2A <CR><LF>>
46:54:73> a(): RXMSG: 41 0C 12 2A <CR><LF>
46:54:93> a(): TX: 03<CR>
46:55:02> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
46:55:25> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
46:55:26> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
46:55:29> a(): TX: 010D<CR>
46:55:38> a(): RX: 41 0D 00 <CR><LF>
46:55:69> a(): RX: 41 0D 00 <CR><LF>>
46:55:71> a(): RXMSG: 41 0D 00 <CR><LF>
46:55:71> a(): TX: 010C<CR>
46:55:85> a(): RX: 41 0C 0C B2 <CR><LF>
46:56:02> a(): RX: 41 0C 0C B2 <CR><LF>>
46:56:05> a(): RXMSG: 41 0C 0C B2 <CR><LF>
46:56:23> a(): TX: 0105<CR>
46:56:37> a(): RX: 41 05 83 <CR><LF>
46:56:54> a(): RX: 41 05 83 <CR><LF>>
46:56:56> a(): RXMSG: 41 05 83 <CR><LF>
46:56:80> a(): TX: 010D<CR>
46:56:93> a(): RX: 41 0D 00 <CR><LF>
46:57:10> a(): RX: 41 0D 00 <CR><LF>>
46:57:12> a(): RXMSG: 41 0D 00 <CR><LF>
46:57:22> a(): TX: 010C<CR>
46:57:37> a(): RX: 41 0C 0A BE <CR><LF>
46:57:54> a(): RX: 41 0C 0A BE <CR><LF>>
46:57:55> a(): RXMSG: 41 0C 0A BE <CR><LF>
46:57:72> a(): TX: 0105<CR>
46:57:85> a(): RX: 41 05 83 <CR><LF>
46:58:02> a(): RX: 41 05 83 <CR><LF>>
46:58:05> a(): RXMSG: 41 05 83 <CR><LF>
46:58:33> a(): TX: 010D<CR>
46:58:51> a(): RX: 41 0D 00 <CR><LF>
46:58:73> a(): RX: 41 0D 00 <CR><LF>>
46:58:75> a(): RXMSG: 41 0D 00 <CR><LF>
46:58:88> a(): TX: 010C<CR>
46:59:00> a(): RX: 41 0C 0B 22 <CR><LF>
46:59:21> a(): RX: 41 0C 0B 22 <CR><LF>>
46:59:23> a(): RXMSG: 41 0C 0B 22 <CR><LF>
46:59:39> a(): TX: 0105<CR>
46:59:70> a(): RX: 41 05 83 <CR><LF>
46:59:71> a(): RX: 41 05 83 <CR><LF>>
46:59:73> a(): RXMSG: 41 05 83 <CR><LF>
46:59:99> a(): TX: 010D<CR>
47:00:38> a(): RX: 41 0D 00 <CR><LF>>
47:00:39> a(): RXMSG: 41 0D 00 <CR><LF>
47:00:50> a(): TX: 010C<CR>
47:00:73> a(): RX: 41 0C 0A BE <CR><LF>
47:00:99> a(): RX: 41 0C 0A BE <CR><LF>>
47:01:00> a(): RXMSG: 41 0C 0A BE <CR><LF>
47:01:35> a(): TX: 010D<CR>
47:01:46> a(): RX: 41 0D 00 <CR><LF>
47:01:71> a(): RX: 41 0D 00 <CR><LF>>
47:01:73> a(): RXMSG: 41 0D 00 <CR><LF>
47:01:85> a(): TX: 010C<CR>
47:01:98> a(): RX: 41 0C 0A BE <CR><LF>
47:02:16> a(): RX: 41 0C 0A BE <CR><LF>>
47:02:17> a(): RXMSG: 41 0C 0A BE <CR><LF>
47:02:52> a(): TX: 03<CR>
47:02:81> a(): RX: NO DATA<CR><LF>>
47:02:95> a(): TX: 010D<CR>
47:03:06> a(): RX: 41 0D 00 <CR><LF>
47:03:25> a(): RX: 41 0D 00 <CR><LF>>
47:03:27> a(): RXMSG: 41 0D 00 <CR><LF>
47:03:38> a(): TX: 010C<CR>
47:03:50> a(): RX: 41 0C 0A BE <CR><LF>
47:03:71> a(): RX: 41 0C 0A BE <CR><LF>>
47:03:72> a(): RXMSG: 41 0C 0A BE <CR><LF>
47:03:87> a(): TX: 0105<CR>
47:03:97> a(): RX: 41 05 83 <CR><LF>
47:04:17> a(): RX: 41 05 83 <CR><LF>>
47:04:18> a(): RXMSG: 41 05 83 <CR><LF>
47:04:41> a(): TX: 010D<CR>
47:04:52> a(): RX: 41 0D 00 <CR><LF>
47:04:72> a(): RX: 41 0D 00 <CR><LF>>
47:04:75> a(): RXMSG: 41 0D 00 <CR><LF>
47:04:86> a(): TX: 010C<CR>
47:04:97> a(): RX: 41 0C 0A BE <CR><LF>
47:05:18> a(): RX: 41 0C 0A BE <CR><LF>>
47:05:19> a(): RXMSG: 41 0C 0A BE <CR><LF>
47:05:37> a(): TX: 0105<CR>
47:05:50> a(): RX: 41 05 83 <CR><LF>
47:05:72> a(): RX: 41 05 83 <CR><LF>>
47:05:75> a(): RXMSG: 41 05 83 <CR><LF>
47:05:98> a(): TX: 010D<CR>
47:06:09> a(): RX: 41 0D 00 <CR><LF>
47:06:29> a(): RX: 41 0D 00 <CR><LF>>
47:06:30> a(): RXMSG: 41 0D 00 <CR><LF>
47:06:42> a(): TX: 010C<CR>
47:06:76> a(): RX: 41 0C 0A BE <CR><LF>>
47:06:77> a(): RXMSG: 41 0C 0A BE <CR><LF>
47:06:90> a(): TX: 0105<CR>
47:07:02> a(): RX: 41 05 83 <CR><LF>
47:07:23> a(): RX: 41 05 83 <CR><LF>>
47:07:25> a(): RXMSG: 41 05 83 <CR><LF>
47:07:47> a(): TX: 010D<CR>
47:07:57> a(): RX: 41 0D 00 <CR><LF>
47:07:77> a(): RX: 41 0D 00 <CR><LF>>
47:08:01> a(): RXMSG: 41 0D 00 <CR><LF>
47:08:10> a(): TX: 010C<CR>
47:08:28> a(): RX: 41 0C 0A 8C <CR><LF>
47:08:40> a(): RX: 41 0C 0A 8C <CR><LF>>
47:08:41> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:08:82> a(): TX: 010D<CR>
47:08:96> a(): RX: 41 0D 00 <CR><LF>
47:09:15> a(): RX: 41 0D 00 <CR><LF>>
47:09:16> a(): RXMSG: 41 0D 00 <CR><LF>
47:09:27> a(): TX: 010C<CR>
47:09:40> a(): RX: 41 0C 0A 8C <CR><LF>
47:09:58> a(): RX: 41 0C 0A 8C <CR><LF>>
47:09:59> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:09:85> a(): TX: 03<CR>
47:10:13> a(): RX: NO DATA<CR><LF>>
47:10:25> a(): TX: 010D<CR>
47:10:37> a(): RX: 41 0D 00 <CR><LF>
47:10:57> a(): RX: 41 0D 00 <CR><LF>>
47:10:58> a(): RXMSG: 41 0D 00 <CR><LF>
47:10:71> a(): TX: 010C<CR>
47:10:85> a(): RX: 41 0C 0A 8C <CR><LF>
47:11:02> a(): RX: 41 0C 0A 8C <CR><LF>>
47:11:04> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:11:18> a(): TX: 0105<CR>
47:11:28> a(): RX: 41 05 83 <CR><LF>
47:11:49> a(): RX: 41 05 83 <CR><LF>>
47:11:50> a(): RXMSG: 41 05 83 <CR><LF>
47:11:80> a(): TX: 010D<CR>
47:11:92> a(): RX: 41 0D 00 <CR><LF>
47:12:12> a(): RX: 41 0D 00 <CR><LF>>
47:12:15> a(): RXMSG: 41 0D 00 <CR><LF>
47:12:25> a(): TX: 010C<CR>
47:12:38> a(): RX: 41 0C 0A 5A <CR><LF>
47:12:57> a(): RX: 41 0C 0A 5A <CR><LF>>
47:12:58> a(): RXMSG: 41 0C 0A 5A <CR><LF>
47:12:72> a(): TX: 0105<CR>
47:12:82> a(): RX: 41 05 83 <CR><LF>
47:13:02> a(): RX: 41 05 83 <CR><LF>>
47:13:04> a(): RXMSG: 41 05 83 <CR><LF>
47:13:25> a(): TX: 010D<CR>
47:13:37> a(): RX: 41 0D 00 <CR><LF>
47:13:54> a(): RX: 41 0D 00 <CR><LF>>
47:13:56> a(): RXMSG: 41 0D 00 <CR><LF>
47:13:69> a(): TX: 010C<CR>
47:13:82> a(): RX: 41 0C 0A 8C <CR><LF>
47:14:00> a(): RX: 41 0C 0A 8C <CR><LF>>
47:14:01> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:14:16> a(): TX: 0105<CR>
47:14:25> a(): RX: 41 05 83 <CR><LF>
47:14:45> a(): RX: 41 05 83 <CR><LF>>
47:14:46> a(): RXMSG: 41 05 83 <CR><LF>
47:14:75> a(): TX: 010D<CR>
47:14:88> a(): RX: 41 0D 00 <CR><LF>
47:15:05> a(): RX: 41 0D 00 <CR><LF>>
47:15:07> a(): RXMSG: 41 0D 00 <CR><LF>
47:15:17> a(): TX: 010C<CR>
47:15:30> a(): RX: 41 0C 0A 8C <CR><LF>
47:15:47> a(): RX: 41 0C 0A 8C <CR><LF>>
47:15:48> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:15:80> a(): TX: 010D<CR>
47:15:93> a(): RX: 41 0D 00 <CR><LF>
47:16:10> a(): RX: 41 0D 00 <CR><LF>>
47:16:12> a(): RXMSG: 41 0D 00 <CR><LF>
47:16:25> a(): TX: 010C<CR>
47:16:35> a(): RX: 41 0C 0A BE <CR><LF>
47:16:55> a(): RX: 41 0C 0A BE <CR><LF>>
47:16:56> a(): RXMSG: 41 0C 0A BE <CR><LF>
47:16:85> a(): TX: 03<CR>
47:16:97> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
47:17:15> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
47:17:16> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
47:17:27> a(): TX: 010D<CR>
47:17:40> a(): RX: 41 0D 00 <CR><LF>
47:17:57> a(): RX: 41 0D 00 <CR><LF>>
47:17:58> a(): RXMSG: 41 0D 00 <CR><LF>
47:17:70> a(): TX: 010C<CR>
47:18:02> a(): RX: NO DATA<CR><LF>>
47:18:17> a(): TX: 0105<CR>
47:18:28> a(): RX: 41 05 83 <CR><LF>
47:18:49> a(): RX: 41 05 83 <CR><LF>>
47:18:50> a(): RXMSG: 41 05 83 <CR><LF>
47:18:78> a(): TX: 010D<CR>
47:18:90> a(): RX: 41 0D 00 <CR><LF>
47:19:09> a(): RX: 41 0D 00 <CR><LF>>
47:19:10> a(): RXMSG: 41 0D 00 <CR><LF>
47:19:22> a(): TX: 010C<CR>
47:19:34> a(): RX: 41 0C 0A 8C <CR><LF>
47:19:54> a(): RX: 41 0C 0A 8C <CR><LF>>
47:19:55> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:19:72> a(): TX: 0105<CR>
47:19:85> a(): RX: 41 05 83 <CR><LF>
47:20:02> a(): RX: 41 05 83 <CR><LF>>
47:20:04> a(): RXMSG: 41 05 83 <CR><LF>
47:20:25> a(): TX: 010D<CR>
47:20:37> a(): RX: 41 0D 00 <CR><LF>
47:20:57> a(): RX: 41 0D 00 <CR><LF>>
47:20:58> a(): RXMSG: 41 0D 00 <CR><LF>
47:20:69> a(): TX: 010C<CR>
47:20:79> a(): RX: 41 0C 0A 8C <CR><LF>
47:20:99> a(): RX: 41 0C 0A 8C <CR><LF>>
47:21:00> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:21:16> a(): TX: 0105<CR>
47:21:25> a(): RX: 41 05 84 <CR><LF>
47:21:48> a(): RX: 41 05 84 <CR><LF>>
47:21:49> a(): RXMSG: 41 05 84 <CR><LF>
47:21:75> a(): TX: 010D<CR>
47:21:87> a(): RX: 41 0D 00 <CR><LF>
47:22:05> a(): RX: 41 0D 00 <CR><LF>>
47:22:06> a(): RXMSG: 41 0D 00 <CR><LF>
47:22:17> a(): TX: 010C<CR>
47:22:30> a(): RX: 41 0C 0A 8C <CR><LF>
47:22:47> a(): RX: 41 0C 0A 8C <CR><LF>>
47:22:48> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:22:82> a(): TX: 010D<CR>
47:22:92> a(): RX: 41 0D 00 <CR><LF>
47:23:15> a(): RX: 41 0D 00 <CR><LF>>
47:23:16> a(): RXMSG: 41 0D 00 <CR><LF>
47:23:27> a(): TX: 010C<CR>
47:23:40> a(): RX: 41 0C 0A 8C <CR><LF>
47:23:57> a(): RX: 41 0C 0A 8C <CR><LF>>
47:23:58> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:23:85> a(): TX: 03<CR>
47:23:98> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
47:24:17> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
47:24:19> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
47:24:29> a(): TX: 010D<CR>
47:24:42> a(): RX: 41 0D 00 <CR><LF>
47:24:60> a(): RX: 41 0D 00 <CR><LF>>
47:24:78> a(): RXMSG: 41 0D 00 <CR><LF>
47:24:88> a(): TX: 010C<CR>
47:24:98> a(): RX: 41 0C 0A BE <CR><LF>
47:25:20> a(): RX: 41 0C 0A BE <CR><LF>>
47:25:21> a(): RXMSG: 41 0C 0A BE <CR><LF>
47:25:38> a(): TX: 0105<CR>
47:25:83> a(): RX: NO DATA<CR><LF>>
47:26:07> a(): TX: 010D<CR>
47:26:17> a(): RX: 41 0D 00 <CR><LF>
47:26:49> a(): RX: 41 0D 00 <CR><LF>>
47:26:50> a(): RXMSG: 41 0D 00 <CR><LF>
47:26:50> a(): TX: 010C<CR>
47:26:72> a(): RX: 41 0C 0A 8C <CR><LF>
47:26:82> a(): RX: 41 0C 0A 8C <CR><LF>>
47:26:83> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:26:91> a(): TX: 0105<CR>
47:27:02> a(): RX: 41 05 84 <CR><LF>
47:27:22> a(): RX: 41 05 84 <CR><LF>>
47:27:24> a(): RXMSG: 41 05 84 <CR><LF>
47:27:34> a(): TX: 010D<CR>
47:27:47> a(): RX: 41 0D 00 <CR><LF>
47:27:69> a(): RX: 41 0D 00 <CR><LF>>
47:27:70> a(): RXMSG: 41 0D 00 <CR><LF>
47:27:71> a(): TX: 010C<CR>
47:27:85> a(): RX: 41 0C 0A 8C <CR><LF>
47:28:02> a(): RX: 41 0C 0A 8C <CR><LF>>
47:28:05> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:28:08> a(): TX: 0105<CR>
47:28:18> a(): RX: 41 05 84 <CR><LF>
47:28:40> a(): RX: 41 05 84 <CR><LF>>
47:28:41> a(): RXMSG: 41 05 84 <CR><LF>
47:28:53> a(): TX: 010D<CR>
47:28:72> a(): RX: 41 0D 00 <CR><LF>
47:28:85> a(): RX: 41 0D 00 <CR><LF>>
47:28:86> a(): RXMSG: 41 0D 00 <CR><LF>
47:28:87> a(): TX: 010C<CR>
47:29:00> a(): RX: 41 0C 0A 8C <CR><LF>
47:29:18> a(): RX: 41 0C 0A 8C <CR><LF>>
47:29:19> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:29:35> a(): TX: 010D<CR>
47:29:48> a(): RX: 41 0D 00 <CR><LF>
47:29:71> a(): RX: 41 0D 00 <CR><LF>>
47:29:72> a(): RXMSG: 41 0D 00 <CR><LF>
47:29:72> a(): TX: 010C<CR>
47:29:85> a(): RX: 41 0C 0A 8C <CR><LF>
47:30:05> a(): RX: 41 0C 0A 8C <CR><LF>>
47:30:06> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:30:22> a(): TX: 03<CR>
47:30:35> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
47:30:52> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
47:30:55> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
47:30:57> a(): TX: 010D<CR>
47:30:72> a(): RX: 41 0D 00 <CR><LF>
47:30:87> a(): RX: 41 0D 00 <CR><LF>>
47:30:88> a(): RXMSG: 41 0D 00 <CR><LF>
47:30:89> a(): TX: 010C<CR>
47:31:02> a(): RX: 41 0C 0A BE <CR><LF>
47:31:20> a(): RX: 41 0C 0A BE <CR><LF>>
47:31:21> a(): RXMSG: 41 0C 0A BE <CR><LF>
47:31:28> a(): TX: 0105<CR>
47:31:39> a(): RX: 41 05 84 <CR><LF>
47:31:58> a(): RX: 41 05 84 <CR><LF>>
47:31:59> a(): RXMSG: 41 05 84 <CR><LF>
47:31:80> a(): TX: 010D<CR>
47:31:92> a(): RX: 41 0D 00 <CR><LF>
47:32:12> a(): RX: 41 0D 00 <CR><LF>>
47:32:14> a(): RXMSG: 41 0D 00 <CR><LF>
47:32:15> a(): TX: 010C<CR>
47:32:25> a(): SENSOR3_CLICK Pg.1 True
47:32:32> a(): RX: 41 0C 0A BE <CR><LF>
47:32:45> a(): RX: 41 0C 0A BE <CR><LF>>
47:32:47> a(): RXMSG: 41 0C 0A BE <CR><LF>
47:32:48> a(): TX: 010F<CR>
47:32:60> a(): RX: 41 0F 5F <CR><LF>
47:32:80> a(): RX: 41 0F 5F <CR><LF>>
47:32:81> a(): RXMSG: 41 0F 5F <CR><LF>
47:32:86> a(): TX: 0105<CR>
47:32:99> a(): RX: 41 05 84 <CR><LF>
47:33:17> a(): RX: 41 05 84 <CR><LF>>
47:33:18> a(): RXMSG: 41 05 84 <CR><LF>
47:33:30> a(): TX: 010D<CR>
47:33:42> a(): RX: 41 0D 00 <CR><LF>
47:33:70> a(): RX: 41 0D 00 <CR><LF>>
47:33:71> a(): RXMSG: 41 0D 00 <CR><LF>
47:33:72> a(): TX: 010C<CR>
47:33:84> a(): RX: 41 0C 0A 8C <CR><LF>
47:34:02> a(): RX: 41 0C 0A 8C <CR><LF>>
47:34:04> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:34:08> a(): TX: 010F<CR>
47:34:22> a(): RX: 41 0F 5F <CR><LF>
47:34:39> a(): RX: 41 0F 5F <CR><LF>>
47:34:41> a(): RXMSG: 41 0F 5F <CR><LF>
47:34:44> a(): TX: 0105<CR>
47:34:54> a(): RX: 41 05 85 <CR><LF>
47:34:75> a(): RX: 41 05 85 <CR><LF>>
47:34:76> a(): RXMSG: 41 05 85 <CR><LF>
47:34:90> a(): TX: 010D<CR>
47:35:05> a(): RX: 41 0D 00 <CR><LF>
47:35:22> a(): RX: 41 0D 00 <CR><LF>>
47:35:23> a(): RXMSG: 41 0D 00 <CR><LF>
47:35:25> a(): TX: 010C<CR>
47:35:38> a(): RX: 41 0C 0A BE <CR><LF>
47:35:57> a(): RX: 41 0C 0A BE <CR><LF>>
47:35:58> a(): RXMSG: 41 0C 0A BE <CR><LF>
47:35:72> a(): TX: 010F<CR>
47:35:85> a(): RX: 41 0F 5F <CR><LF>
47:36:03> a(): RX: 41 0F 5F <CR><LF>>
47:36:05> a(): RXMSG: 41 0F 5F <CR><LF>
47:36:18> a(): TX: 010D<CR>
47:36:28> a(): RX: 41 0D 00 <CR><LF>
47:36:47> a(): RX: 41 0D 00 <CR><LF>>
47:36:48> a(): RXMSG: 41 0D 00 <CR><LF>
47:36:49> a(): TX: 010C<CR>
47:36:70> a(): RX: 41 0C 0A 8C <CR><LF>
47:36:80> a(): RX: 41 0C 0A 8C <CR><LF>>
47:36:81> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:37:02> a(): TX: 03<CR>
47:37:15> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
47:37:32> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
47:37:35> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
47:37:37> a(): TX: 010D<CR>
47:37:47> a(): RX: 41 0D 00 <CR><LF>
47:37:70> a(): RX: 41 0D 00 <CR><LF>>
47:37:71> a(): RXMSG: 41 0D 00 <CR><LF>
47:37:72> a(): TX: 010C<CR>
47:37:85> a(): RX: 41 0C 0A 8C <CR><LF>
47:38:02> a(): RX: 41 0C 0A 8C <CR><LF>>
47:38:05> a(): RXMSG: 41 0C 0A 8C <CR><LF>
47:38:05> a(): TX: 010F<CR>
47:38:17> a(): RX: 41 0F 5F <CR><LF>
47:38:35> a(): RX: 41 0F 5F <CR><LF>>
47:38:36> a(): RXMSG: 41 0F 5F <CR><LF>
47:38:37> a(): TX: 0105<CR>
47:38:49> a(): RX: 41 05 85 <CR><LF>
47:38:70> a(): RX: 41 05 85 <CR><LF>>
47:38:71> a(): RXMSG: 41 05 85 <CR><LF>
47:38:82> a(): TX: 010D<CR>
47:38:95> a(): RX: 41 0D 00 <CR><LF>
47:39:12> a(): RX: 41 0D 00 <CR><LF>>
47:39:22> a(): RXMSG: 41 0D 00 <CR><LF>
47:40:17> a(): TX: 03<CR>
47:40:27> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
47:40:47> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
47:40:48> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
47:41:45> a(): TX: 03<CR>
47:41:57> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
47:41:74> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
47:41:76> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
47:42:71> a(): SENSOR1_CLICK Pg.2 True
47:42:79> a(): TX: 03<CR>
47:42:92> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
47:43:10> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
47:43:11> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
47:43:15> a(): TX: 010E<CR>
47:43:25> a(): RX: 41 0E A0 <CR><LF>
47:43:45> a(): RX: 41 0E A0 <CR><LF>>
47:43:47> a(): RXMSG: 41 0E A0 <CR><LF>
47:43:72> a(): TX: 010E<CR>
47:43:78> a(): SENSOR2_CLICK Pg.2 True
47:43:87> a(): RX: 41 0E A2 <CR><LF>
47:44:05> a(): RX: 41 0E A2 <CR><LF>>
47:44:06> a(): RXMSG: 41 0E A2 <CR><LF>
47:44:09> a(): TX: 0111<CR>
47:44:22> a(): RX: 41 11 1B <CR><LF>
47:44:40> a(): RX: 41 11 1B <CR><LF>>
47:44:41> a(): RXMSG: 41 11 1B <CR><LF>
47:44:59> a(): TX: 010E<CR>
47:44:70> a(): RX: 41 0E 9E <CR><LF>
47:44:90> a(): RX: 41 0E 9E <CR><LF>>
47:44:91> a(): RXMSG: 41 0E 9E <CR><LF>
47:44:96> a(): TX: 0111<CR>
47:45:09> a(): RX: 41 11 1B <CR><LF>
47:45:27> a(): RX: 41 11 1B <CR><LF>>
47:45:28> a(): RXMSG: 41 11 1B <CR><LF>
47:45:42> a(): TX: 010E<CR>
47:45:52> a(): RX: 41 0E 9C <CR><LF>
47:45:72> a(): RX: 41 0E 9C <CR><LF>>
47:45:74> a(): RXMSG: 41 0E 9C <CR><LF>
47:45:78> a(): TX: 0111<CR>
47:45:92> a(): RX: 41 11 1B <CR><LF>
47:46:10> a(): RX: 41 11 1B <CR><LF>>
47:46:11> a(): RXMSG: 41 11 1B <CR><LF>
47:46:25> a(): TX: 010E<CR>
47:46:35> a(): RX: 41 0E A2 <CR><LF>
47:46:57> a(): RX: 41 0E A2 <CR><LF>>
47:46:58> a(): RXMSG: 41 0E A2 <CR><LF>
47:46:71> a(): TX: 0111<CR>
47:46:84> a(): RX: 41 11 1B <CR><LF>
47:47:02> a(): RX: 41 11 1B <CR><LF>>
47:47:04> a(): RXMSG: 41 11 1B <CR><LF>
47:47:17> a(): TX: 03<CR>
47:47:27> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
47:47:47> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
47:47:48> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
47:47:51> a(): TX: 010E<CR>
47:47:62> a(): RX: 41 0E 9E <CR><LF>
47:47:82> a(): RX: 41 0E 9E <CR><LF>>
47:47:84> a(): RXMSG: 41 0E 9E <CR><LF>
47:47:88> a(): TX: 0111<CR>
47:48:02> a(): RX: 41 11 1C <CR><LF>
47:48:19> a(): RX: 41 11 1C <CR><LF>>
47:48:20> a(): RXMSG: 41 11 1C <CR><LF>
47:48:42> a(): TX: 010E<CR>
47:48:54> a(): RX: 41 0E 9E <CR><LF>
47:48:72> a(): RX: 41 0E 9E <CR><LF>>
47:48:74> a(): RXMSG: 41 0E 9E <CR><LF>
47:48:74> a(): TX: 0111<CR>
47:48:87> a(): RX: 41 11 1B <CR><LF>
47:49:05> a(): RX: 41 11 1B <CR><LF>>
47:49:06> a(): RXMSG: 41 11 1B <CR><LF>
47:49:22> a(): TX: 010E<CR>
47:49:32> a(): RX: 41 0E A2 <CR><LF>
47:49:53> a(): RX: 41 0E A2 <CR><LF>>
47:49:55> a(): RXMSG: 41 0E A2 <CR><LF>
47:49:59> a(): TX: 0111<CR>
47:49:73> a(): RX: 41 11 1C <CR><LF>
47:49:90> a(): RX: 41 11 1C <CR><LF>>
47:49:91> a(): RXMSG: 41 11 1C <CR><LF>
47:50:10> a(): TX: 010E<CR>
47:50:20> a(): RX: 41 0E A4 <CR><LF>
47:50:40> a(): RX: 41 0E A4 <CR><LF>>
47:50:41> a(): RXMSG: 41 0E A4 <CR><LF>
47:50:46> a(): TX: 0111<CR>
47:50:60> a(): RX: 41 11 1B <CR><LF>
47:50:77> a(): RX: 41 11 1B <CR><LF>>
47:50:78> a(): RXMSG: 41 11 1B <CR><LF>
47:50:95> a(): TX: 010E<CR>
47:51:05> a(): RX: 41 0E A4 <CR><LF>
47:51:25> a(): RX: 41 0E A4 <CR><LF>>
47:51:26> a(): RXMSG: 41 0E A4 <CR><LF>
47:51:27> a(): TX: 0111<CR>
47:51:40> a(): RX: 41 11 1B <CR><LF>
47:51:57> a(): RX: 41 11 1B <CR><LF>>
47:51:58> a(): RXMSG: 41 11 1B <CR><LF>
47:51:77> a(): TX: 03<CR>
47:51:87> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
47:52:07> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
47:52:08> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
47:52:11> a(): TX: 010E<CR>
47:52:22> a(): RX: 41 0E A2 <CR><LF>
47:52:42> a(): RX: 41 0E A2 <CR><LF>>
47:52:44> a(): RXMSG: 41 0E A2 <CR><LF>
47:52:49> a(): TX: 0111<CR>
47:52:80> a(): RX: NO DATA<CR><LF>>
47:52:95> a(): TX: 010E<CR>
47:53:09> a(): RX: 41 0E 9C <CR><LF>
47:53:27> a(): RX: 41 0E 9C <CR><LF>>
47:53:28> a(): RXMSG: 41 0E 9C <CR><LF>
47:53:32> a(): TX: 0111<CR>
47:53:45> a(): RX: 41 11 1B <CR><LF>
47:53:70> a(): RX: 41 11 1B <CR><LF>>
47:53:71> a(): RXMSG: 41 11 1B <CR><LF>
47:53:85> a(): TX: 010E<CR>
47:53:95> a(): RX: 41 0E A0 <CR><LF>
47:54:17> a(): RX: 41 0E A0 <CR><LF>>
47:54:18> a(): RXMSG: 41 0E A0 <CR><LF>
47:54:22> a(): TX: 0111<CR>
47:54:34> a(): RX: 41 11 1B <CR><LF>
47:54:52> a(): RX: 41 11 1B <CR><LF>>
47:54:54> a(): RXMSG: 41 11 1B <CR><LF>
47:54:74> a(): TX: 010E<CR>
47:54:84> a(): RX: 41 0E A2 <CR><LF>
47:55:04> a(): RX: 41 0E A2 <CR><LF>>
47:55:05> a(): RXMSG: 41 0E A2 <CR><LF>
47:55:09> a(): TX: 0111<CR>
47:55:22> a(): RX: 41 11 1B <CR><LF>
47:55:40> a(): RX: 41 11 1B <CR><LF>>
47:55:41> a(): RXMSG: 41 11 1B <CR><LF>
47:55:54> a(): TX: 010E<CR>
47:55:70> a(): RX: 41 0E 9E <CR><LF>
47:55:84> a(): RX: 41 0E 9E <CR><LF>>
47:55:87> a(): RXMSG: 41 0E 9E <CR><LF>
47:55:90> a(): TX: 0111<CR>
47:56:03> a(): RX: 41 11 1B <CR><LF>
47:56:20> a(): RX: 41 11 1B <CR><LF>>
47:56:21> a(): RXMSG: 41 11 1B <CR><LF>
47:56:36> a(): TX: 03<CR>
47:56:45> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
47:56:71> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
47:56:72> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
47:56:75> a(): TX: 010E<CR>
47:56:85> a(): RX: 41 0E A4 <CR><LF>
47:57:05> a(): RX: 41 0E A4 <CR><LF>>
47:57:06> a(): RXMSG: 41 0E A4 <CR><LF>
47:57:10> a(): TX: 0111<CR>
47:57:22> a(): RX: 41 11 1B <CR><LF>
47:57:40> a(): RX: 41 11 1B <CR><LF>>
47:57:41> a(): RXMSG: 41 11 1B <CR><LF>
47:57:56> a(): TX: 010E<CR>
47:57:70> a(): RX: 41 0E A2 <CR><LF>
47:57:87> a(): RX: 41 0E A2 <CR><LF>>
47:57:88> a(): RXMSG: 41 0E A2 <CR><LF>
47:57:92> a(): TX: 0111<CR>
47:58:05> a(): RX: 41 11 1B <CR><LF>
47:58:25> a(): RX: 41 11 1B <CR><LF>>
47:58:26> a(): RXMSG: 41 11 1B <CR><LF>
47:58:40> a(): TX: 010E<CR>
47:58:50> a(): RX: 41 0E A0 <CR><LF>
47:58:70> a(): RX: 41 0E A0 <CR><LF>>
47:58:71> a(): RXMSG: 41 0E A0 <CR><LF>
47:58:77> a(): TX: 0111<CR>
47:58:90> a(): RX: 41 11 1B <CR><LF>
47:59:07> a(): RX: 41 11 1B <CR><LF>>
47:59:08> a(): RXMSG: 41 11 1B <CR><LF>
47:59:22> a(): TX: 010E<CR>
47:59:32> a(): RX: 41 0E A2 <CR><LF>
47:59:52> a(): RX: 41 0E A2 <CR><LF>>
47:59:54> a(): RXMSG: 41 0E A2 <CR><LF>
47:59:58> a(): TX: 0111<CR>
47:59:70> a(): RX: 41 11 1B <CR><LF>
47:59:89> a(): RX: 41 11 1B <CR><LF>>
47:59:91> a(): RXMSG: 41 11 1B <CR><LF>
48:00:05> a(): TX: 010E<CR>
48:00:14> a(): RX: 4
48:00:16> a(): RX: 41 0E 9E <CR><LF>
48:00:37> a(): RX: 41 0E 9E <CR><LF>>
48:00:38> a(): RXMSG: 41 0E 9E <CR><LF>
48:00:42> a(): TX: 0111<CR>
48:00:55> a(): RX: 41 11 1B <CR><LF>
48:00:72> a(): RX: 41 11 1B <CR><LF>>
48:00:74> a(): RXMSG: 41 11 1B <CR><LF>
48:00:87> a(): TX: 03<CR>
48:00:97> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
48:01:17> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
48:01:18> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
48:01:21> a(): TX: 010E<CR>
48:01:31> a(): RX: 41 0E 9E <CR><LF>
48:01:52> a(): RX: 41 0E 9E <CR><LF>>
48:01:57> a(): RXMSG: 41 0E 9E <CR>&l | |
