08-22-2006, 06:59 AM
#136
Raw Wave
Quote: Originally Posted by tj!2k4
Control Panel uninstall, and there is no "C:\Program Files\Flux Media" directory, and yet there were still a ton of references in the registry which I manually removed.. and am still unable to install RC2. I'm thinking there must still be something else left behind in the registry that is preventing the install.
See post 131
08-22-2006, 09:11 AM
#137
Raw Wave
Quote: Originally Posted by ShawJohn
See post 131
I don't get it. What are you trying to say? ... that you're guessing Windows installer is the culprit?
08-22-2006, 09:12 AM
#138
follow-up... re: XM plugin
Quote: Originally Posted by midiwall
Cool.. okay. I'll play more with it.
Life is better. I'm now not sure what was causing what I was hearing before; well, I figure that (like you said David) it was that my LINE_IN was unmuted, but now I can't make it happen. Strange.
Quote:
I have a side question about the preload... "why?".
And after playing with the plugin for a while last night, I still have this question.
:: Mark
08-22-2006, 10:03 AM
#139
Raw Wave
If you manually deleted it, you need to somehow get the directory structure back (from a backup maybe) so that control panel can uninstall it, that solves the problem
I recon windows installer knows its installed the software, and hasn't removed it so it thinks its still there  and hence will not allow it to install new version, which incidentally it thinks is an older version due to the version number change from 1.7 to 0.96
08-22-2006, 10:07 AM
#140
Raw Wave
Thanks for the suggestion, but I did a "real" uninstall from the control panel already.
I was listing the steps I had already taken to remove RC1.
08-22-2006, 11:26 AM
#141
VENDOR - Centrafuse
I have it on my list of known issues to speed up channel changing.. The buffering is because you can pause/rewind/fastforward while listening to XM...
When you change channel I have to destory the buffer, create a new one, send the channel change command, buffer a few seconds, then start playback...
This allows you to pause, etc...
david
08-22-2006, 12:49 PM
#142
Raw Wave
Dare I ask when RC2.1 might show its face
08-22-2006, 12:55 PM
#143
Yeup, I understand, but the preload of a channel only buys the user two seconds of rewind previous to what they first hear. I don't know that's such a feature as would be the "nicer" effect of hearing the new channel sooner.
A similar example comes from the TiVo world. When I change channels, I get the new channel immediately. The data is always streamed to disk of course so when I pause, the buffer starts to build in front of me. When I PLAY, then I'm playing from the buffer tail. If I FF to get closer to the present, then that's when I get to rewind into the past.
Hmmm.. another side thought... Instead of running the buffer in a create/fill/destroy cycle, why not just make it circular and move a head/tail pointer? That'll save the memory management overhead and you should be able to pick up some speed on systems with less RAM.
:: Mark
08-22-2006, 07:10 PM
#144
VENDOR - Centrafuse
You get 2 seconds when you first change, but if you listen for 20 minutes, you can rewind for 20 minutes, etc...
I already have it on my list to speed this up...
david
#145
VENDOR - Centrafuse
soon
david
08-22-2006, 07:13 PM
#146
Why cant CF play ISo files?
08-22-2006, 07:21 PM
#147
david
My opinion is that anything more than a second is too much. Even a full second is pushing it...
08-22-2006, 08:00 PM
#148
I really hate to push this David, but I gotta think that we're having a bit of a communications breakdown here.
I know you have it on the list to speed up, but if that means anything short of "absolutely no buffer preload" then you've killed the ability to channel surf for no real reason.
Lemme try it this way... Is this true? - I'm listening to channel 41
- I switch to channel 48
- I wait for 2 seconds while the buffer preloads
- I hear channel 48 (side note: can you please tie the crossfade into the other crossfade Y/N option?)
- _at this point_ I can only rewind 2 seconds
- I listen for some amount of time...
- I now switch to channel 82
- I hear channel 82
So, given that my waiting for two seconds at the channel switch only bought me two seconds of initial rewind time, then... why make me wait at all?
:: Mark
08-22-2006, 10:58 PM
#149
VENDOR - Centrafuse
- I hear channel 82
I understand you completly... My point is I plan to speed up the channel switching by changing the code. I have it listed as a bug. My first thoughts are I will switch the channel first so it will start playing immediately, then behind the scenes recreate the buffer and start buffering... So at first rewind would do nothing, until you listen to the channel for awhile or pause...
I plan to fix this, as I said it's not listed as a feature, but a bug... which means I believe it is wrong as well and plan to fix it...
david
08-22-2006, 11:28 PM
#150
david
Okay... I'll back off and wait. My concern is coming from you saying "speed up" versus "make it instant".
Thanks David.
:: Mark
| Thread Tools |
| Display Modes |
Linear Mode
