08-11-2006, 10:55 PM
#16
Quote: Originally Posted by sivart321
here is that phone control error... I spent an hour or so getting the serial conection to work properly, and then continued through the wizard...I end up with this as soon as I enable phone control.
here is the newest error.log file
Same here, same dialog pops up
08-12-2006, 01:37 AM
#17
Raw Wave
David,
I can reproduce a web plugin bug consistently:
1) open web
2) Load a page like apple.com
3) Now go to media screen.
4) Go back to Web, and try typing another URL.
Nothing happens! You are stuck now, and cannot load any other page. Apparently happens as soon as you leave the web screen, and come back...
Also, here is a screenshot of the issue that sivart mentioned earlier in this thread. I got it too... it's odd, and happens pretty often to me. Cannot determine how/when.
08-12-2006, 01:44 AM
#18
Raw Wave
Double Beep?
Im hearing a lot of Double Beeps now in RC2, and I am definitely only clicking ONCE. It acts like I click only once too, but it beeps twice real quick. Kind of annoying really!
FYI, I was still in regular click mode, because I realize there are issues with single-click mode.
#19
I also had CF crash on me this evening upon resume from hibernation. It showed a loading dialog (I must assume it was the CD, or XM) I am not sure.
I will see if there is an error.log, but I imagine since I restarted the computer it will be gone? I will look and see.
08-12-2006, 02:46 AM
#20
i have same issue
08-12-2006, 02:53 AM
#21
Yeah, I'm hearing a lot of the double beeps as well. RC2 still seems a bit buggy on my end. Some of the external apps that I load in do not fully close sometimes. I find myself clicking around to close it.
Also, I have a suggestion to make....an alternative to the button layout settings... On the main screen if you hold down one of the buttons for 5 seconds, a dialog could pop up asking you to assign that button a function. I just thought that might be easier instead of having to do it in the settings.
08-12-2006, 03:08 AM
#22
Quote: Originally Posted by veetid
This is the way it's suppose to work, I will look into the play now button to see if I can find the problem... If you go into one album does it play all the albums, or just that album?
david
Yes, if I drill down far enough so I see the list of songs from a single album and then hit the Play button, it queues up all of those songs. It appears the only places it doesn't work as expected is when I'm looking at Artists\<specific artist> (where I'd expect it to play all albums for that artist) and Genres\<specific genre> (where I'd expect it to play all albums for all artists within that genre).
08-12-2006, 03:26 AM
#23
Banned
BUG: When you rename an application, you have to exit setup and re-enter for the main-list to update the name.
REQUEST: More hot-keys. Specifically, "Y" or [Enter] for Yes and "N" or [Esc] for No in Yes/No Prompts. "+" and "-" work in screens with +/- buttons (setup).
08-12-2006, 04:05 AM
#24
Phone Control Moderator
This may happen if the uninstall has left some files in the PhoCo folder for any reason.
Do this: Backup the PhoneCtl.Config.xml from PhoCo folder, uninstall CF, wipe out the directory then re-install.
Put the backupd PhoneCtl.Config.xml back in the PhoCo folder, create a file called "wizard" (without extension) within the PhoCo folder and you'll be fine.
08-12-2006, 04:51 AM
#25
Banned
This is an awesome idea!
08-12-2006, 12:06 PM
#26
Raw Wave
Gosh, this is just a GREAT idea. It really is!
08-12-2006, 12:24 PM
#27
Now I'm not sure if this is just me or what... On XM radio, my station lineup shows up and everything and I can click on a station. But after first load, when I click on a station it will play like 10s of the station then stop. No other stations will then play through.
I was starting to think this was the hardware @ fault so I loaded up RR. All the stations play through fine on RR. Anyone else experiencing this? I haven't had time to play around with it to get the error situated.
---- Also: If you click "Refresh Station Lineup" it'll say it's doing so, but will have an OK button at the bottom. If you click the OK button too early you only get a handfull of stations. It seems like it should work like the Loading Library button and show a percentage and not let you click before then, other than a Cancel button?
Jim
2005 Acura TL
2005 Honda VTX1800N
PreludePC 2.0 in the making...
Smaller, faster, better...
08-12-2006, 12:29 PM
#28
Haha, I knew I would have a good idea at one time or another!
08-12-2006, 04:44 PM
#29
VENDOR - Centrafuse
Quote: Originally Posted by tj!2k4
I realize that this is probably another "uninstall the previous version prior to installation deal" but when attempting to install RC2 over RC1, I get "Unable to install because a newer version of this product is already installed."
Oviously RC1 is not newer than RC2, so the message should probably tell me to uninstall the old version as opposed to telling me that it's newer.
The versioning changed with RC2, so this would have happened... The finished commercial version will be 1.0, so RC2 became 0.96 officially...
I know that is weird, but it was to match logging, the updater, and other various reasons... It shouldn't be a problem moving forward...
david
08-12-2006, 04:52 PM
#30
VENDOR - Centrafuse
I'm looking into all these issues...
I like the idea of the 5 second hold down, I will look into it...
david
| Thread Tools |
| Display Modes |
Linear Mode
