Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 08-12-2006, 05:07 PM   #31
sivart321 is on a distinguished road
Another few issues...
I have gotten the skip button stuck a few more times.
Also, I am having a TON of problems in the media mode with the CD and USB playlists. I have a DVD drive plugged into a USB converter and upon clicking the CD icon, CF loads all of the media (which I must say is rather slow, and seemingly uneccesary?) I recall in frodoplayer if I went to the CD, everything would appear automatically. There was no loading neccesary. The problem I have is I am using some DVD data discs, and it takes a few minutes to load all of the songs... and I want to say that the music stops playing while its loading?
Anyway, the real 'issue' comes after it has finished loading and I go back to the HDD media. The counter on CD never increases, but the USB one does. However, once I click USB, it tells me there is no USB device loaded. So I click CD instead, and it starts loading again!! It has done this everytime I have tried using the CD drive.
More issues with the web browser. Sometimes when viewing pages, the up and down arrows stop working. Only the scroll bar on the side allows me to scroll through the page. THis happens even when I click on the page to bring the cursor out of any text box it may have been in.
I was unable to duplicate the loading crash I got upon resuming from hibernation, but have since removed the XM plugin until I have it wired up with the new soundcard.
sivart321 is offline   Reply With Quote
Old 08-12-2006, 05:29 PM   #32
Banned
RPM_VR4's Avatar
RPM_VR4 is on a distinguished road
Quote: Originally Posted by RPM_VR4 View Post
REQUEST: More hot-keys. Specifically, "Y" or [Enter] for Yes and "N" or [Esc] for No in Yes/No Prompts. "+" and "-" work in screens with +/- buttons (setup).
...and I need a hot-key for FullScreen On/Off in Embedded Apps too (Alt-Enter would be my default).
RPM_VR4 is offline   Reply With Quote
Old 08-12-2006, 07:49 PM   #33
VMS
VMS's Avatar
VMS is on a distinguished road
I'm having a sticky click problem where if i click something, it will double click it for some reason. Didn't happen in RC1. For example, if i hit next rack, it will go to the next track then fast forward. If i hit favourates button, it will add the song to favourates and then load the favourates playlists. If i hit up or down, it will start scrolling automatically. I don't have single click on.
Vehicle Media Systems
Australia Car PCs www.vmscarpc.com.au
VMS is offline   Reply With Quote
Old 08-12-2006, 11:05 PM   #34
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Same problem as VMS here....
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 08-13-2006, 02:26 AM   #35
L-U-R-C-H is on a distinguished road
Same here.
Also I noticed a few other problems. When I was trying to get the internet page to load and it says "loading", when I hit the back button to go to other menus, the loading dialog was still in the middle of the screen and wouldn't go away.
Another problem I had when I was in iGuidance... When I held down the full screen button the screen jumped to the media browser and the top and bottom edges of the application were messed up.
Also, is there a way to make it so that when you close out of centrafuse that it remembers your music selection you were playing? I noticed if I close out of centrafuse and then come back in that I have to reload the music I was listening to.
L-U-R-C-H is offline   Reply With Quote
Old 08-13-2006, 02:47 AM   #36
I noticed this too. RC1 didn't do this.
I also have to mention that my XMdirect does not work. It appeared to be working initially, and loaded the channels, and then started to load the song titles. I went back in and selected no device to try and elleviate a different issue, and upon going back and renabling the xmdirect unit, no channel names appear, and nothing loads no matter what settings I change.
Old 08-13-2006, 02:52 AM   #37
bishooman's Avatar
bishooman is on a distinguished road
i found some bugs
1- when you are playing video in full screen and you changed the skin so it will go back to media main screen when going to next vedio.
2- if you are in media viewing photos try to go back to main change skin and hit media again and see what will happen.
3- holding back button givs a beep after 2 sec but it just function as normal, if you changed the skin it will not give the beep at all.
4- i can't find go to previous section hot key !!
5- top bar of NAV, CAM, NOTEPAD, and others (i cant remeber now) should be shiftted up by 3 or 4 pixels.
6- TV resets setting when CF restarts.
7- if i am playing video with original Aspect Ratio enabled, when going to next or previous video i have click Aspect Ratio button twice (disable then enable) to get correct Aspect Ratio for file being played.
We Exist because there is no patch for human Stupidity !!
We need you ALL Here !!
bishooman is offline   Reply With Quote
Old 08-13-2006, 05:24 PM   #38
clemen is on a distinguished road
1 -> Cant get a lock in navi, when centrafuse is in Metric mode, only if its in imperial units.
2-> pressing next song results some time in that the button jams, and stays in fast forward mode, (tryed this 3times now, and never in previus releases)
3-> Some time when holding down the change skin button, and releasing it too soon, the screen just turns black?
clemen is offline   Reply With Quote
Old 08-13-2006, 05:25 PM   #39
4-> the random plays the same song before it has played them all-
Old 08-13-2006, 06:01 PM   #40
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
Try to manually delete your satchannels.xml file in the system folder and make sure all your settings are correct and reload...
david
veetid is offline   Reply With Quote
Old 08-13-2006, 06:04 PM   #41
VENDOR - Centrafuse
veetid's Avatar
Quote: Originally Posted by bishooman View Post
i found some bugs
I'm looking into these.. What do you mean in #1 though... If you change the skin after loading media section, then start watching full screen videos it does not play the next video in full screen?
david
Old 08-13-2006, 06:06 PM   #42
VENDOR - Centrafuse
veetid's Avatar
#3 is a feature for blacking out the screen... When you hear the beep at 2 seconds that means if you let go then the screen goes black... If you continue to hold it down past 4 seconds, then skin will change automatically... So when you want to change skins, just hold it down until it happens...
If you want to black out the screen, let go after the beep and before the skin changes...
david
Old 08-13-2006, 06:07 PM   #43
VENDOR - Centrafuse
veetid's Avatar
How big was your playlist? I tested with 25 items in the list and wrote down every song number that was played about 8 times and it did not repeat..
note: The random will reset if you load any new playlist or add to the current playing playlist (this might not should happen)
david
Old 08-13-2006, 06:38 PM   #44
Banned
RPM_VR4's Avatar
I just tested it. It definitely repeats still. I loaded 708 songs. I then turned on random and clicked next track twice a second for about 2 min (trying to remember as many names as I could). Within 30 seconds I suspected having seen a few songs re-played, but after 2 min I am absolutely positive that at least 5 different songs were (could be as much as 30 songs though).
How do you have random implemented David? It is really easy to copy the list array, then pass it to a procedure to randomize it, then play it in that order. Why don't you just implement it the easy, best, correct, infinate history in both directions, impossible to play the same song twice way
Old 08-13-2006, 07:09 PM   #45
hornyleprechaun is on a distinguished road
I am having the most frustrating problem with the FF/next song button. If I have it on single or double click it will go to the next song and keep fast-forwarding through the song.. I love CF and I know you'll fix it but i'm going back till RC1
hornyleprechaun is offline   Reply With Quote
New Release, Centrafuse RC1 (1.7) veetid Centrafuse 62 08-02-2006 01:14 PM
Centrafuse 1.6 Bugs Mbai2 CF Bug Reports 57 05-10-2006 11:30 AM
Centrafuse 1.5 Bugs veetid CF Bug Reports 162 01-14-2006 08:03 PM
Centrafuse 1.4 Bugs veetid CF Bug Reports 270 09-27-2005 10:58 PM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
