08-13-2006, 07:36 PM
#46
VENDOR - Centrafuse
Quote: Originally Posted by RPM_VR4
I just tested it. It definitely repeats still. I loaded 708 songs. I then turned on random and clicked next track twice a second for about 2 min (trying to remember as many names as I could). Within 30 seconds I suspected having seen a few songs re-played, but after 2 min I am absolutely positive that at least 5 different songs were (could be as much as 30 songs though).
How do you have random implemented David? It is really easy to copy the list array, then pass it to a procedure to randomize it, then play it in that order. Why don't you just implement it the easy, best, correct, infinate history in both directions, impossible to play the same song twice way
It is implemented with an array... I have looked over the logic and it should be working...
Try loading just an album, 10 or so songs, and really seeing if it repeats... I cannot reproduce this loading albums and clicking next...
david
08-13-2006, 07:37 PM
#47
VENDOR - Centrafuse
Quote: Originally Posted by hornyleprechaun
I am having the most frustrating problem with the FF/next song button. If I have it on single or double click it will go to the next song and keep fast-forwarding through the song.. I love CF and I know you'll fix it but i'm going back till RC1
I'm still trying to figure this one out... I cannot reproduce this on any of the 4 machines I have...
david
08-13-2006, 08:31 PM
#48
Quote: Originally Posted by veetid
I'm looking into these.. What do you mean in #1 though... If you change the skin after loading media section, then start watching full screen videos it does not play the next video in full screen?
david
if you changed the skin and you are watching full screen videos it will go back for non full screen mod for 1/2 sec and then come back to full screen when it gose to next video !!
08-13-2006, 08:38 PM
#49
Banned
david
Yeah, but I never load just a single album. Right now I have just my Sublime songs loaded (80 songs). After listing for about 20 min, I had heard Santeria twice. I only have one copy of it and it is only loaded once. All I was doing was playing with GE-Nexus (external embedded app) and letting it play. It repeats songs before playing all songs, even with no interaction.
08-13-2006, 08:39 PM
#50
Banned
david
I have this FF after next-track bug too. I am using the newest Nexus release... maybe it is a skin issue?
08-13-2006, 09:15 PM
#51
Try to manually delete your satchannels.xml file in the system folder and make sure all your settings are correct and reload...
david
That didn't help. I unistalled and reinstalled, and was able to get the channels to appear, but it never updated with song info nor did it play any audio.
08-13-2006, 09:25 PM
#52
david
He means... When you have video media in full screen with the control bar at the bottom, if you click "next track" it will flash to the main list as if you weren't full screen then back to full screen. It isn't a fluid movement from full screen media to the next full screen media, it returns to the main Media Dir then back to full screen. Mine does the same. Annoying, but not a huge deal.
Jim
2005 Acura TL
2005 Honda VTX1800N
PreludePC 2.0 in the making...
Smaller, faster, better...
08-13-2006, 10:18 PM
#53
david
If it helps I def. notice it when I have shuffle songs on and am playing music for a little bit (30 min. - 1 hour) it doesn't happen right away but def. happens.. try with double click and shuffle on..
08-13-2006, 10:22 PM
#54
Raw Wave
david
If it helps, I wanted to say I have the same problem with RC2. I click FWD and it sticks. Or I click DOWN arrow on lists, and it sticks too! Im in regular click mode. (not single click)
EDIT: It happens only every now and then, but it does happen.
08-14-2006, 01:47 AM
#55
David: I am getting the fast forward bug as well. It has nothing to do with random being on or off or the nexus skin. It's hard to produce but it happens frequently. I have single click off.
It seems as though some of the buttons gets stuck on touch down. I had the volume get stuck on me a few times as well. It gets stuck with the volume going up or down. The only way to stop the volume is to exit out of centrefuse. I also notice the home/back button get stuck as well. I dont recall RC1 having this problem.
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
08-14-2006, 01:49 AM
#56
Yeah, I don't know...it seems like RC1 was more stable than RC2... It seems to have a lot of bugs still
08-14-2006, 03:38 AM
#57
Click Bug
This Click-Bug happens here too. It nearly always occures on double clicking the Fast Forward and Volume up/down buttons. Sometimes it also comes when double clicking on up/down in the media list. To do so, I must delay the second click a little bit - about half a second.
It is very annoying when the volume raises - and you can't stop it.
I can't reproduce it on my (fast) pc. (You gave me a shock, because i fitted the Touchscreen in a new housing at the same time i updated - and i first put the blame on the touch.)
08-14-2006, 06:30 AM
#58
Could this have anything to do with the single click function? it didn't do it in RC1 at all. Its not related to skins, i'm using the the defalt onyx skins.
08-14-2006, 06:54 AM
#59
Little SYNCH bugg.
I don't know HOW I arrive to this.
08-14-2006, 07:27 AM
#60
How big was your playlist? I tested with 25 items in the list and wrote down every song number that was played about 8 times and it did not repeat..
note: The random will reset if you load any new playlist or add to the current playing playlist (this might not should happen)
david
My playlist was 63 songs (3 albums), and i am the next song type, so i press next song until I hear somthing i like, for the first 20 next songs the 3 of them was a song already played.
And the fast forward bug did occure there also, if you want to reproduce it, just try to pres next a few hundred times.
## DID anyone got a GPS lock in METRIC mode?? ##
| Thread Tools |
| Display Modes |
Linear Mode
