Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 08-14-2006, 07:41 AM   #61
badmike's Avatar
badmike is on a distinguished road
Quote: Originally Posted by clemen View Post
## DID anyone got a GPS lock in METRIC mode?? ##
Yes, 11 Satelites (BU-303)
I got it with a trick. Go to setup and choose the port, speed and protocol (nmea, 48xxx) and save. Restart, do it again and this time press cancel not save.
worked for me!
badmike is offline   Reply With Quote
Old 08-14-2006, 07:57 AM   #62
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Yes, I agree, RC1 was mor usable. I hope David is real hot to try out the new Auto Update feature!!!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 08-14-2006, 12:07 PM   #63
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
Quote: Originally Posted by coucouillu View Post
Little SYNCH bugg.
I don't know HOW I arrive to this.
This is showing you are in currently going to set your destination which is currently in shortest route mode... The button on the right would switch it to quickest route...
I don't love it, but it's the way it is right now...
david
veetid is offline   Reply With Quote
Old 08-14-2006, 12:39 PM   #64
VENDOR - Centrafuse
veetid's Avatar
I do want to test it this week... What is causing the biggest issue? My list of bugs is not very large, but more strange actually...
I'm working to find this weird sticky button problem now, is this what is causing the most instability?
david
Old 08-14-2006, 12:59 PM   #65
Raw Wave
justintime's Avatar
Hi David,
What's making it unusable to me is primarily the button sticking issue as you have mentioned. Also, still no reliable single-click support keeps me from installing CF in my car. Third, is the strange Web plugin bug, but that's no showstopper.
You know what is ridiculous? I have spent countless hours making a cool new skin, hacking iG3, etc etc., but I still don't have it all in my car LOL!
Words of encouragement: The current feature set and user interface enhancements put CF at the top of the list not only in overall look/feel, but also usability in the car. You really took the time to listen to all of us and enhanced CF for the 'better good'
2002 Honda CR-V
Old 08-14-2006, 03:00 PM   #66
VENDOR - Centrafuse
veetid's Avatar
Hi David,
That is good, these are the two things I am focused on... I have all the single click issues resolved, still working on finding the sticky button issue, which is weird because I do not believe I changed any code relating to this, but there were close to 60 bugs fixed and almost 30 enhancements in RC2 all added in about a 2 week period and released...
I will get them all worked out... I plan to test the updater atleast twice in the next two weeks...
The web bugs are related somehow to the code I added to decrease loading time... I do not init the web browser until you first click on the web button, which drastically decreased load time, but caused some issues with the web browser...
david
Old 08-14-2006, 03:47 PM   #67
Josephine is an unknown quantity at this point
Quote: Originally Posted by zorro View Post
This may happen if the uninstall has left some files in the PhoCo folder for any reason.
Do this: Backup the PhoneCtl.Config.xml from PhoCo folder, uninstall CF, wipe out the directory then re-install.
Put the backupd PhoneCtl.Config.xml back in the PhoCo folder, create a file called "wizard" (without extension) within the PhoCo folder and you'll be fine.
Zorro, I tried your solution but I still get that exception. Did anyone else manage to get Phoco running in rc2? Or did this fix it for you?
Josephine is offline   Reply With Quote
Old 08-14-2006, 04:25 PM   #68
Phone Control Moderator
zorro's Avatar
zorro is on a distinguished road
I'd recommend that you re-install the .NET Framework. It might fix it.
I'm testing all releases from David to make sure that PhoCo is working. It must be something related to the Framework.
Skinning to go... VisualDesigner2!
zorro is offline   Reply With Quote
Old 08-14-2006, 04:39 PM   #69
zorro's Avatar
Found it.
For some reason the setup is thinking that the zControls library isn't used and it didn't add it to the package. It will be fixed in the next setup.
Meanwhile you can download the missing library here and copy it into the PhoneControl.NET folder of CF.
Sorry for that.
Old 08-14-2006, 05:28 PM   #70
Yep, that fixed that error. Now the next one it now *****es about another missing file, Interop.SpeechLib (which is not to be found in the Phoco dir). Download link pretty please?
Old 08-14-2006, 06:09 PM   #71
Harro is an unknown quantity at this point
Had this problem as well, after downloading and installing the missing files, the problem with zcontrols is solved now, but an other big error message appears now instead:
Can't find file or assembly InteropSpeechLib etc.....
It seems to handle about a missing .dll and .exe file
I guess there have to be added more files?
Harro
Harro is offline   Reply With Quote
Old 08-14-2006, 06:21 PM   #72
EMT2B is on a distinguished road
I'm still having trouble with external applications-
I launched S&T2K6 in a window, and when i close it, the window remains open. I can never return to the main menu from there. (can you maybe add a "main" feature to the dropdown menu as a temporary workaround?). I can never close the white window without killing CF & restarting it.
on the plus side, trying to close the window no longer acts as a play/pause button like it did with RC1.
EMT2B is offline   Reply With Quote
Old 08-14-2006, 06:24 PM   #73
VENDOR - Centrafuse
veetid's Avatar
You can easily add Main menu to the drop down by going to Settings/Button Layout...
Some applications do not like to be closed externally... I will review my code, but I have tried many things and some apps just do not like to be closed...
I thought I had code to continue to look for the application and force a kill if it waited too long, but if it half way closes then I might be detecting that as a close...
david
Old 08-14-2006, 06:25 PM   #74
VENDOR - Centrafuse
veetid's Avatar
Harro
That file is used by Centrafuse as well so try and copy the InteropSpeechLib from the main Centrafuse directory into the PhoneControl.NET directory and see if that works until we build a new installer...
david
Old 08-14-2006, 06:28 PM   #75
zorro's Avatar
Damn *****ing compiler
I've added it to the same ZIP file. Please re-download, extract it and let me know if something else is missing.
New Release, Centrafuse RC1 (1.7) veetid Centrafuse 62 08-02-2006 01:14 PM
Centrafuse 1.6 Bugs Mbai2 CF Bug Reports 57 05-10-2006 11:30 AM
Centrafuse 1.5 Bugs veetid CF Bug Reports 162 01-14-2006 08:03 PM
Centrafuse 1.4 Bugs veetid CF Bug Reports 270 09-27-2005 10:58 PM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
