08-24-2006, 02:04 PM
#16
Vehicle: Caddy Seville
I do have the MIC selected and enabled. I get sound from the XMD, but it's blaring until I can get to the controls to turn it down. Oddly enough, I'm experiencing this on both implementations of CF. If the issue is just me, then I'm obviously not doing something right, but I was pretty careful about setting everything up. Heck, worst-case scenario, I can pad the inputs with resistors and just let it roll. The only issue I have with this is the potential distortion I'll get from running it at full-tilt.
In any case, thanks for everything - David and everyone else. Kudos to a very supportive developer and forum!
To find your favorite restaurants in Houston, check out http://www.thehubgrub.com.
If it's not fun, you're not doing it right!
08-24-2006, 02:21 PM
#17
MySQL Error
I set the level when you enter radio or XM, I thought I set it closer to 80%, but I will check.. Maybe I shouldn't adjust the level at all and all the user to adust it themselves...
I will look into it, but it didn't seem to cause any distortion on my test machines...
david
08-24-2006, 03:05 PM
#18
Vehicle: 97 Firebird
I am having the same thing happen to my system when I listen to XM. Mine is set to the Line In and it goes full tilt also. Turn it down and when you leave the XM and return full blast again.
97 Firebird 7" Lilliput Touch Screen
AMD Athlon 3800+ DSATX
Centrafuse RC5
PPC 6700 Sprint Phone w/Bluetooth
Bluetooth GPS
08-24-2006, 05:45 PM
#19
Geez David, I sure wish my code-monkeys at work were this responsive - you are *awesome*!!!
08-28-2006, 07:04 PM
#20
oh yea, can 2.1 please be made to install over 2? ... i HATE re-configging
09-04-2006, 06:55 PM
#21
^^^ im with you!!
09-04-2006, 07:11 PM
#22
MySQL Error
Quote: Originally Posted by Bboy_jon
^^^ im with you!!
This is the whole plan behind the updater... There was an issue that caused it not to work in RC2 found after the release, but it has been fixed in RC2.1 (now called RC3), so this shouldn't be an issue moving forward...
david
09-06-2006, 05:31 AM
#23
sounds good so can we just update to RC3 with RC2 updater?
09-06-2006, 10:31 AM
#24
MySQL Error
There was a bug in the RC2 updater I found, which has been fixed... So you will need to download RC3...
david
09-10-2006, 11:56 AM
#26
just thought i'd add my two cents, i get the sticky button too, but only on the "next track" selection, i click nrext and the button stays held and fastforwards through the next track. i dont use a mouse i use a single click touch screen
| Thread Tools |
| Display Modes |
Linear Mode
