09-10-2006, 12:07 PM
#1
GPS Bug
i've only recently noticed this bug,
first of when i turn of te pc i turn it off, no hirbirnation or anything fancy,
i click on the NAV button a wait, what started of as an odd occourance is now constance occurance, the GPG will not lock on any sat's ( i normally get 8 or 9 ) i restared the pc a few times and then i locks onto the sat's , i do not knwo why this happens....
Anyone else get this problem?
09-13-2006, 07:12 AM
#2
Vehicle: 96 Saab 900SE
I do. Same exact thing. After coming out of sleep it won't lock onto any sats until the PC has been restarted.
09-13-2006, 07:55 AM
#3
Use Xport3, it fixes the problem
09-13-2006, 12:02 PM
#4
MySQL Error
I found this issue and working on a fix...
I want to get it into RC3, all depends on if Destinator gets it to me today, which is going by fast...
david
09-16-2006, 11:39 AM
#5
hmmm Xport3 , never heard of it, only using com port 3 at the mo. i had alot of trouble geeting the GPS to work so being honest i dont want to mess about wit it . But hey at least i know i'm not te only one and a fix is on thte way , Yay to Dave. when ever you come to ireland i'll buy you a print m8 ;D
09-17-2006, 06:19 PM
#6
MySQL Error
This has been fixed and will be in RC3...
david
09-18-2006, 02:36 PM
#7
Vehicle: 06' Audi A3 2.0 TDI Exclusive Line 170HP
 COOOOOOLL....
02-12-2007, 02:32 AM
#8
i have the same problem but not on waking from sleep mode. I have the Globalsat BU-353 gps receiver and when i turn on the pc it doesn't necessarily lock to satellites every time i open centafuse. instead when i use the gpsinfo app it locks to 8-9 satellites. So when i have this lock problem i first open gpsinfo then close it and enter centrafuse.
02-12-2007, 10:38 AM
#9
MySQL Error
you in SiRF mode or NMEA? If not NMEA then try NMEA mode... there seems to be some issues with SiRF mode and some receivers...
david
02-12-2007, 06:13 PM
#10
i only use nmea mode because sirf doesn't work at all but it is not stable.
03-27-2007, 07:26 PM
#11
Vehicle: 2006 Mazda 3 5-door
I'm noticing that the GPS is very unpredictable in this manner for me as well. I have mine go into hibernation each time, and sometimes when it resumes, it doesn't lock onto any satellites at all in CF. Sometimes it takes a minute or 2, sometimes it's quick, within 30 seconds. I'm not sure the issue on this, but I'll continue to try to get a good repro...
Carputer Progress:
Re-do fabrication of screen [DONE]
Wood faceplate for computer in glovebox [0%]
03-28-2007, 08:56 AM
#12
MySQL Error
a new navigation engine will be in the next release that will hopefully improve the receiver connection issues...
it should have the SiRF issues fixed for sure...
david
03-29-2007, 06:39 PM
#13
Thanks for the update, looking forward to it.
It's only been recently that it had issues. Like today, when I booted up coming home from work, CF didn't connect to the receiver (I checked XPort and it had GPS info coming in) until I slowed down after about 10 minutes of driving, when I was almost at my destination. I've noticed a lot of time it updates once I slow down or stop after moving for a little while (5+ minutes, maybe?).
I figured out that my GPS was interfering with my Bluetooth (both using COM ports), so that was the problem I was having. I have disabled the bluetooth on my phone and it works much better now.
Carputer Progress:
05-21-2007, 09:44 AM
#14
Vehicle: 03 Fiesta Zetec
i still have this issue in 1.13 am i the only on or is there others.
Works fin on clean start but when i resume from hibernation i cant get a lock and if i do it only lasts a few mins.
05-21-2007, 12:27 PM
#15
MySQL Error
I will add code to close GPS port and reopen it on resume from hibernation/standby and I believe this will fix your issue...
I don't have the issue, but the extra code will not hurt anything...
david
| Thread Tools |
| Display Modes |
Linear Mode
