The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Thread Tools Display Modes
Old 09-19-2006, 05:25 PM   #1
My Photos: (0)
Kx Project and CF?
Anyone else have the kx project drivers for their Soundblaster card? I am having problems with the new update RC3 and the volume control. Whenever I try to do volume up/down it sets the volume to the minimum level.
David.. The kx project drivers are drivers created by people that enable more control over soundblaster cards. Instead of installing the SB drivers you would just install the kx project drivers to operate the soundcard. I had no problems in previous versions with my volume control. I would really like to solve this, so if there is any information I need to look up I will gladly do it. Thanks.
hornyleprechaun is offline   Reply With Quote
Sponsored Links
Old 09-20-2006, 11:17 AM   #2
My Photos: (0)
I posted in the main bug report thread but just for continuity's sake I'll post here also. I'm using KX (I think p3rv3rt b3ar is also) and with RC3 came the nasty volume bug you describe.
I also have trouble with audio hanging on track switch (requiring restart of CF) and no audio upon resume from hibernation or standby (requiring track skip fwd/back - pause/unpause does not bring audio back).
I've found little support from KX users/developers because their real motivation is to use the kxdriver set for recording and music production applications. My reason for using the kx set is that I can implement DSP filters on my outputs - in particular, I have placed crossover filters on the multiple outputs of my Audigy2zs, so I have dedicated high / mid / subwoofer outputs directly to my amplifiers. Losing kx means I have to add another expensive component to my signal chain.
I have no trouble with any of these issues if I use Roadrunner or any other winamp-based frontend (or other media player for that matter) with kx installed, so it seems a reasonable conclusion that CF is addressing the audio hardware in some non-typical way. But it's obviously not a priority for David (with only a few users overlapping CF and KX) so I suspect there's little hope for any solution in the future.
zerodb is offline   Reply With Quote
Old 09-20-2006, 12:52 PM   #3
bns2000's CarPC Specs
bns2000's Avatar
Vehicle: 2001 Ford Focus ZX3 Green (Removed PC from my old car 2000 Ford Focus SE)
My Photos: (2)
Mabe you can try turning off or on "Logarithmic Volume" in the General settings Page 2/4. Or turn off or on "Use pre as master Volume" page 2/3 or select "Speaker Output" Page 3/3 of Audio/Video Settings. Thats what I would try. But im just guessing. Mabe it will work for you.
CENTRAFUSE™ From Flux Media
The Ultimate Infotainment Interface
Download V1.20 from there site now!!!!
Download the new 2.0 RC1 From here Linky
bns2000 is offline   Reply With Quote
Old 09-20-2006, 03:17 PM   #4
My Photos: (0)
I've tried all those options, it doesn't help. But good ideas.
Old 09-20-2006, 05:47 PM   #5
My Photos: (0)
I've gone ahead and made the switch to RR.. I love CF and all the capabilities of it, but for now I need something that will not fail me. Maybe once CF gets all the bugs worked out I'll try it again.
Old 09-21-2006, 03:06 AM   #6
Frankino's Avatar
Vehicle: Peugeot 206 HDi 2003
My Photos: (0)
same situation here, switch back to creative stuff is not an option, at all. I hope David will fix these issues o I will be forced to switch to rr... I surely hope not
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Sb Live 5.1 w/ KXProject Drivers
Opus 150w WTF
8" Lilliput TS LCD
40% installing (monitor ok, pc KO, audio KO)
damn car accident
Frankino is offline   Reply With Quote
Old 09-26-2006, 04:28 PM   #7
Frankino's Avatar
My Photos: (0)
bump
david tell us something please
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Opus 150w WTF
8" Lilliput TS LCD
damn car accident
Old 09-26-2006, 05:19 PM   #8
MySQL Error
veetid's Avatar
My Photos: (0)
Quote: Originally Posted by Frankino View Post
bump
nothing to tell... I do not own any of this hardware and it's a small amount of people using it...
It's special drivers that use their own mixer I assume... Centrafuse talks with the windows mixer... Somewhere their is a disconnect...
I have nothing for testing and many things in front of this...
I will take a look into supporting it, but after everything else is done...
david
veetid is offline   Reply With Quote
Old 09-28-2006, 11:44 AM   #9
Frankino's Avatar
My Photos: (0)
I understand perfectly, but I also understand that centrafuse is the only frontend which gives problems with kxproject.. it's very sad
you know, even my stupid logitech keyboard is capable of control kxproject master volume without problems.. not to mention the well known "next track" issue, that seems really far away from a core 3rd part driver feature
and by the way, the goodold volume setting mode was working flawlessly even on kxdrivers, why not, maybe, put it back where it was and make it selectable for us kxowners? something like "alternate volume settings"...it's a long shot I know...
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Opus 150w WTF
8" Lilliput TS LCD
damn car accident
Old 09-28-2006, 11:57 AM   #10
My Photos: (0)
I swear, if I could have the CF frontend working through a Winamp backbone I would be one happy camper.
Sponsored Links
Old 09-28-2006, 12:08 PM   #11
Frankino's Avatar
My Photos: (0)
it would be enough to have it to work like wmp, which does not have neither next track nor volume problems
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Opus 150w WTF
8" Lilliput TS LCD
damn car accident
Old 09-28-2006, 01:36 PM   #12
MySQL Error
veetid's Avatar
My Photos: (0)
does it create an error.log file when you try to change the volume?
what if you go to the mixer in Centrafuse, then open the windows mixer and slide the volume up/down, or any of the inputs... Do the sliders in Centrafuse move?
Can it control anything, WAV, CD, MIC?
What about PRE, when you move WAVE in the windows mixer does the slider for PRE move?
The fix I put in place that changed the volume made it work very well with all the 5.1 features for VIA boards, the ones most people use...
but it also caused no issues with 4 other sound cards I use... It appears on this driver set...
david
Old 09-28-2006, 02:53 PM   #13
Frankino's Avatar
My Photos: (0)
my car is in maintenance right now, I'll have it back in a couple of days..
I'll let you know asap
thank you
namaste
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Opus 150w WTF
8" Lilliput TS LCD
damn car accident
Old 09-28-2006, 04:34 PM   #14
My Photos: (0)
I've not seen an error.log related to the volume issue. I'll check mine again. I will say that I use a Griffin Powermate for volume control (which appears to issue a "volume up/down" command to windows just like a multimedia keyboard) and when I use this, I can see not the Pre, but the Front volume slider move in CF's mixer. With CF's new options for output channels, I can only use "MAIN" - I tried using "FRONT" and it stopped working - not just absence of sound... CF wouldn't even indicate that it was playing a track at all (which is eerily similar to what happens when it hangs on "next track")
Old 09-28-2006, 06:23 PM   #15
Vehicle: 2001/Golf
My Photos: (0)
I use a griffin Powermate too, and I've managed to use it very comfortly by assigning "sendkey" F8, F9 and F10 to "click", "turn left" and "turn right" for the centrafuse app.
this way you keep whatever volume control (PRE, FRONT, ... )works fine for centrafuse.
hope this helps
Larsen is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
booting from CF card slower than HDD, disappointed. what's wrong? mattress General Hardware Discussion 14 08-25-2006 01:11 PM
suggestion to increase boot performance CF 1.6 David pls bishooman Centrafuse 24 03-14-2006 11:42 AM
Problems booting from CF card dcdc Operating System Optimization 8 01-16-2006 06:10 PM
2004 Mazda 3S Project Subwoofer87 Worklogs 5 09-11-2005 03:28 PM
my new carputer/ipodLinux project. churnopol General Hardware Discussion 0 11-30-2003 04:49 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
