09-28-2006, 11:57 AM
#91
VENDOR - Centrafuse
Quote: Originally Posted by justintime
David,
If you are not able to reproduce this yet, it might be because the default skin for web plugin does NOT cover the bottom bar where the random button is located. My skin does cover that area with fullscreen web vieweing, so apparently that is what causes the random button not to refresh correctly....
got it... on section change I willl run an update random button function
david
09-28-2006, 12:11 PM
#92
I have a new one... you're gonna love this.
So, given the bug with not being able to refresh XM channels, I replaced my satchannels.xml file with one from a fresh install of RC3 (not RC3.1). My channels are back (which of course makes sense) and I'm back to using the XM plugin instead of AIMEE. But, here's the fun...
CF is set to startup in XM. It does, and I get audio right at startup. But, it's VERY loud and distorted. Hunting around, I can trace this back to the MIC level being set to 50 when CF loads. So, I turn down the level like I've been doing. _BUT_ when I go BACK into the XM plugin, the MIC level goes back to 50. No lie. 100% repeatable.
As well, when I come back out to MIXER, the MIC level slider is still at 0, but the level is clearly up. I drag the slider up, then back down, and the level goes back to 0. I click back into the XM plugin and... The MIC level comes back to 50.
What's VERY strange is that this didn't happen before. "Before" is defined as RC3 (NOT RC3.1) and before I first clicked on "refresh channel list" for the XM plugin under RC3.
Since I first did that, I upgraded to RC3.1, so is it possible that something changed at 3.1 in how you manage the audio when a plugin gets focus?
:: Mark
09-28-2006, 12:21 PM
#93
This is the same thing that is happening to me.
97 Firebird 7" Lilliput Touch Screen
AMD Athlon 3800+ DSATX
Centrafuse RC5
PPC 6700 Sprint Phone w/Bluetooth
Bluetooth GPS
09-28-2006, 12:23 PM
#94
 ! Dood... I think you're the first person to have the same XM issues that I am. David will be so happy! (seriously - I think he thinks I've been making all this up!)
:: Mark
09-28-2006, 02:37 PM
#95
VENDOR - Centrafuse
I believe you... I will focus on these XM issues as soon as I get the next release out...
It will be my main focus...
david
09-28-2006, 02:59 PM
#96
Quote: Originally Posted by veetid
I will look into it, but we are not working on supporting Greek on our first initial release, but will shortly after...
i have spoken with Destinator and everything can be worked out, just not enough time in the day!!
david
Thank you David, I am waiting anxiously to hear what you find out.
Given that it is only the city names problematic, whereas everything else encodes perfectly ok (like streetnames and all the rest), I feel optimistic
Harry
EDIT: This is what error.log says right after trying to display the city names
28/9/2006 11:13:10 μμ
Object reference not set to an instance of an object.
at DESTSDKLib.DestClass.LoadCheckedPOI()
at GPS.menudialog.menudialog_Load(Object sender, EventArgs e)
and this is what it reads after browsing through POIs, History etc.
28/9/2006 11:13:25 μμ
at DESTSDKLib.DestClass.get_CategoryName(Int32 Index)
at GPS.menudialog.loadPOIFolders()
28/9/2006 11:13:36 μμ
at DESTSDKLib.DestClass.GetMapHistoryPointArray()
at GPS.menudialog.loadMapHistory()
28/9/2006 11:19:28 μμ
28/9/2006 11:19:47 μμ
at DESTSDKLib.DestClass.SaveCheckedPOI()
at GPS.menudialog.menudialog_Closed(Object sender, EventArgs e)
Cheers
09-28-2006, 06:23 PM
#97
I'm pretty positive it's related to the visuals, especially after seeing your error.log... If the music is playing, the visuals are loaded in memory and ready to render if you to the media screen...
I known where to start looking now... great job!
Cheered too soon I guess...
I've disabled the music autostart, restarted CF and did absolutely nothing and now got this in the errorlog at the moment of startup:
9/28/2006 11:56:31 PM
at centrafuse.obdii.resetChip()
and CF crashing with the same error after about 20 min of sitting idle...
Trying to reproduce this behaviour, it just resorted to putting in the
at centrafuse.main.loadVisuals()
right after startup.
Dunno if it's gonna crash again as it has only been a few minutes.
I must say: with RC2 (I think) I've made a roadtrip (on a different machine also) and didn't come across this error. Didn't play any music, only used the navigation, was actually a test  (needed to pickup something 300km from home and could use some navigation).
Not much of a help I guess... isn't there a way to intercept that general .net error and have CF log what it was doing or something? Or maybe I could run it through some tracer? I have no .net experience, but I have basic debugging skills
CarPC: "Carma" (Car Audio & Route Management) (about 70% ready)
P4 1.8GHz / 512MB / 4GB CF
Asus TVFM + B/W camera
15" touchscreen 1024x768
BU303
2x 100Ah
reinstalling
And all this in a Dutch 1972 Citroën HY van called "MurpHY".
09-28-2006, 11:06 PM
#98
VENDOR - Centrafuse
It actually is a lot of help....
try removing the OBDII plugin by deleting the directory in the plugins folder... Then see if you still get the error...
david
09-28-2006, 11:15 PM
#99
VENDOR - Centrafuse
I have fixed both the errors you have seen in your error.log as well as made some changes I think were causing the issue... RC4 will be out soon and we will see...
david
09-28-2006, 11:30 PM
#100
Delete your main.dat file, and re index your music library. Worked for me!
ya didnt work, it just F**ked up cf :/
09-29-2006, 06:16 AM
#101
david
Hi David, gotta report the same bug here. Occuring irregularly, haven't had the chance to kick visuals out yet to see whether then it'd be allright. To be a tad annoying: any chance of an option whether visuals are loading at all or not? I know that a lot of people love them, but I just hate them and kick them out on every installation of CF..
Oh, by the way: the OBDII is out of my plugins folders and it's still got issues, so it's not related to this.
09-29-2006, 07:14 AM
#102
david
[Asking_Too_Much Mode ON]
Any chance to have a look into the Greek cities character thing until then?
I attached the error.log contents in my previous post, not quite sure if they help you though..
[Asking_Too_Much mode OFF]
/Harry
09-29-2006, 01:30 PM
#103
VENDOR - Centrafuse
/Harry
I will not have chance to speak with Destinator before then, this is an issue within their SDK, not Centrafuse...
I have a call setup with them next week, but I plan to release RC4 before then...
david
09-29-2006, 03:13 PM
#104
I have a call setup with them next week, ... ...
david
ok David, I 'm keeping my fingers crossed
Thnx
/Harry
09-29-2006, 06:23 PM
#105
Raw Wave
David,
Not sure if this is due to CF, but every time I resume from Hibernate, the COnnection status icon is "ON" by default, and then after about 30 seconds it turns of (which is the correct status in this case, given that there is not really an internet connection).
This happens even when I know there is no inet connection. Not sure if it is WINDOWS that assumes connection (and CF by inheritance), or if its CF that is doing that....
| Thread Tools |
| Display Modes |
Linear Mode
