Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Closed Thread
Old 10-07-2006, 05:16 AM   #16
kASz's Avatar
kASz is on a distinguished road
Quote: Originally Posted by veetid View Post
working on your first issue, but not sure about "The second one is that sometimes search don't show the address but it exists"
So you see it in the list, but my buttons do not go to it? Or it's not in the list at all?
david
It is in the list, but when I type it it does not appear. I only can see the street when I look for it with the arrows.
kASz is offline
Old 10-07-2006, 05:30 AM   #17
Maximus is on a distinguished road
The out parameter is for when it returns CF_Actions.Plugin, the out string is populated with the name of the plugin...
Let me know if it works...
DOH !
As with most things, it works just fine if you use them the way it was intended.
But hey, I'm a C# noob so I'm allowed to make mistakes
Thank you very much !
/M
Maximus is offline
Old 10-07-2006, 05:38 AM   #18
chevyunger is on a distinguished road
favorites problem
Hi David,
thanks for making it possible to sort favorites by distance.
next problem is that the keyboard has no funktion in search address screen, only the osk works.
thx
Matthias
Last edited by chevyunger; 10-07-2006 at 06:01 AM. Reason: my fault, using corrupted favorites.dat
chevyunger is offline
Old 10-07-2006, 06:18 AM   #19
Cirion is on a distinguished road
I'm not able to delete favorites. They do disappear, but when entering favorites again they reappear.
Cirion is offline
Old 10-07-2006, 08:48 AM   #20
DaKyy's Avatar
DaKyy is on a distinguished road
Quote: Originally Posted by DaKyy View Post
I'm not sure if this is a known bug, but still here goes, again.
I complained couple of days ago that after 3.1 update failed my mp3:s didn't automaticly do the next track procedure after the song ended. I noticed that it was because of certain MP3 files when it did that. They are variable bitrate MP3s. Centrafuse seems unable to calculate correct lenght of the VBR files as the bitrate changes constantly. When I setup CF to show how much is left of the song - It'll show for example when the song is almost at the end that there is still -1:12 left of the song. Then it just jumps to zero and doesn't go the next track.
Also I noticed today that the option to change Destinator color scheme with the day night skin didn't work when coming out of hibernate. The night skin changed to day skin normally but the night scheme in Destinator stayed.
The GPS speed was OK when I first installed the RC4, after hibernate it just shows 0 km/h while driving. Restart probably fixes that.
DaKyy is offline
Old 10-07-2006, 10:52 AM   #21
GReeToZ is on a distinguished road
Installed RC4 on a winxp system (dutch) but with US time/date/language settings.
1. GPS speed still doesn't really work (using metric mode) sometimes it just says 1 kph (when i'm doing 30) and lots of the times its about 20 kph off (destinator 3 and tomtom speeds are almost the same as my speedo!)
navigation in the city/street mode on the "benelux" maps seems to work fine.
edit and offtopic but i don't see anything about TMC in the future features.. is this scrapped or just very longterm?
my destinator map resource down permanently
GReeToZ is offline
Old 10-07-2006, 10:54 AM   #22
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
can we please be able to completely remove unwanted modules such as satelite rario? I have no intentions of ever using it, yet I cannot remove it.
Also sirrius, XM, Radio etc.
Surely these modules are slowing things down a little when they aren't required?
3D view still pretty much turns to 2d view when you zoom out
Can CF be made to grab new windows that an embedded program may spawn? Then use the back arrow to go back to the embedded app from new window.
John
ShawJohn is offline
Old 10-07-2006, 12:27 PM   #23
ont
ont is on a distinguished road
I still have box like characters after the album title for some mp3's. Neither Winamp's, Foobar's nor the Windows ID3tag editor show these.
ont is offline
Old 10-07-2006, 12:45 PM   #24
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
This was listed under things to look into... now I know what type of file is causing this, thanks...
david
veetid is offline
Old 10-07-2006, 12:48 PM   #25
VENDOR - Centrafuse
veetid's Avatar
Quote: Originally Posted by Merzbow View Post
Veetid, you can't be serious that you disabled the ability to use the microphone input on the primary sound card for voice? I haven't yet upgraded from RC2, where voice recognition works fine. I already have a very expensive external USB sound card with a very high-quality microphone attached. There is no way I'm going to shove more computer hardware in my car. If you disabled this to support radio or visualizations or whatnot, simply allow us to turn off that stuff (which I certainly don't use). This will be a deal-killer for me and certainly many customers, since there is no way I'm going to give up voice recognition on my front-end.
USB microphones work great, so do bluetooth... I will look into it... The only reason it worked again in RC2 was because I accidently had some visualization code commented out...
I could definetly add an option to disable visuals, radio, and XM completly...
I will look for some workaround, but it's how I get the data to feed to the visual...
david
veetid is offline
Old 10-07-2006, 12:50 PM   #26
VENDOR - Centrafuse
veetid's Avatar
Quote: Originally Posted by Shonky* View Post
The Street/City method of entering a new destination still doesn't work. After selecting the street, right arrow, the city selector remains on the streets.
You can't type using a regular keyboard - it jumps in the list only. Is that the "keyboard control doesn't work when you use web browser, navigation, or external application because they take over keyboard control" problem?
When selecting "Go" it should use the currently selected destination rather than having to use right arrow
eg. I use suburb/street -> enter suburb, right arrow, enter street, right arrow, select number, go OR right arrow. "go" ignores the selected number.
I am using older Destinator Australian maps. Could that be the problem?
street name issue works fine with the maps I have from Destinator, depends on your maps and if they are compatible and working...
keyboard control will work, list views get focus automatically, hit <tab> and you will have control of the buttons again.
GO does do this, something must be wrong... You can select just a City and hit GO, it will go to just that city, same with a street, except it will auto go to the next screen because it needs to know atleast the city for that street...
david
veetid is offline
Old 10-07-2006, 12:53 PM   #27
VENDOR - Centrafuse
veetid's Avatar
can you give me the map, city, and street so I can reproduce?
I did use loop from beginging initially, too slow.. Then binary, which doesn't work correctly, then I wrote my own search this method.. Seems to work, but nothing the exact map, city, and street will let me see the error and fix it quickly...
david
veetid is offline
Old 10-07-2006, 12:55 PM   #28
VENDOR - Centrafuse
veetid's Avatar
Quote: Originally Posted by chevyunger View Post
Hi David,
thx
Matthias
hit <tab> to take focus away from the list view... When you go to any page with a list view I default the focus to the list view... You use <tab> to get out of this focus... hit it again and you will have focus on the main controls on the bottom, then again back to the list view, and so on...
david
veetid is offline
Old 10-07-2006, 12:56 PM   #29
VENDOR - Centrafuse
veetid's Avatar
is this with all favorites you add? for example add one with a new address, current destination, current location, and see which one you can't remove, or all of them...
david
veetid is offline
Old 10-07-2006, 12:57 PM   #30
VENDOR - Centrafuse
veetid's Avatar
still talking about TMC... It's more on Destinator's end, nothing left for me to integrate really... I am working on it...
Speed is a known constant issue... Their damn SDK can't seem to give me the right numbers or tell me what they are in...
david
veetid is offline
Closed Thread
Centrafuse RC3.1 Bugs veetid CF Bug Reports 135 10-06-2006 06:11 PM
Centrafuse RC4 Release Notes veetid Centrafuse 0 09-29-2006 04:27 PM
Centrafuse 1.5 Bugs veetid CF Bug Reports 162 01-14-2006 08:03 PM
Centrafuse 1.4 Bugs veetid CF Bug Reports 270 09-27-2005 10:58 PM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
