10-08-2006, 03:19 PM
#61
this is what my gps screen looks like:
even in fullscreen this is what happens, it's just easyer to tell this way
the gps screen is wider than centrafuse. When displayed on the 7" screen part of it is left out.
2005 S40 2.0D - Sport Body Kit
Ipod 100%
Carpc 95%
10-08-2006, 06:27 PM
#62
Quote: Originally Posted by veetid
USB microphones work great, so do bluetooth... I will look into it... The only reason it worked again in RC2 was because I accidently had some visualization code commented out...
I could definetly add an option to disable visuals, radio, and XM completly...
I will look for some workaround, but it's how I get the data to feed to the visual...
david
It would be great if you could add that option. No other media program I've seen takes over the microphone input to run stuff like visuals...
10-08-2006, 07:13 PM
#63
Any Video, This happens if its just 1 video in the playlist.
Shell mode quits into explorer for me, weird... Is it the same video everytime, or any video?
david
10-08-2006, 07:17 PM
#64
We got the same bug for nav skin. I found that the buttons didn't show but if you press in the area where it should be, it will still work. I think this happens when changing skins.
Quote: Originally Posted by GReeToZ
I had a very strange bug yesterday
parked the car in the afternoon.. hibernated. then in the evening i started it up and the nav screen was not working anymore the buttons (the eye, the cancel route etc) they where very small (about 1/6 of the size) in the left hand top corner also the map did not change into the night mode (the CF skin did!) gps was still updating the map but i could do anything in it.. the rest of CF seemed to work without any problem.
another thing. when i press the map in any place i get the menu where you can set "set as destination", "add to favorites" for one this menu is NOT touchscreen friendly and when i press add to favorites i get the normal windows window and not a skinned OSK etc.
the last thing isn't really a but but just not very nice.. when running as shell and then start the navigation for the first time you get a Loading "window" in windows style in the left hand bottom corner.
10-09-2006, 02:56 AM
#65
I dont know, if its a bug, but if phoco dont find the phone (cause it is not there or off), cf closes without closing phoco (the phocoicon dont disappear after closing cf). after restarting cf, phoco dont work.
10-09-2006, 04:39 AM
#66
Raw Wave
well I thought it was defo down to a SIMM as it didn't repeat all yesterday after changing them, yet today on the way to work it happened again - whilst it is stammering and sounding the button click noise the CPU never went above 40% which is strange as everything takes 20seconds plus to respond
Then a minute or so later its back to normal again
10-09-2006, 06:25 AM
#67
ahh oke well yesterday i hibernated in the evening and used it this morning the skin from CF changed and the buttons of the NAV where still there but it did NOT switch the map skin (i could do this manually)
my destinator map resource down permanently
10-09-2006, 06:36 AM
#68
If you hibernate again, it should be back to normal.
10-09-2006, 08:03 AM
#69
Raw Wave
map changes from night to day skin when you exit setup too
10-09-2006, 10:53 AM
#70
Gapless playback doesn't seem present, I've heard it's supposed to be a feature - correct me if I'm wrong. I've tried both FLAC and MP3 and there is about .25 second gap or so between tracks, just as it would be on the older iPods (I think they fixed this in 5.5G).
Carputer Progress:
Re-do fabrication of screen [DONE]
Upgrade screen and PC [70%]
Wood faceplate for computer in glovebox [0%]
10-09-2006, 02:22 PM
#71
Seconded. I thought this was actually working back around 1.7?
:: Mark
10-09-2006, 07:33 PM
#72
Got this when trying to hibernate today...after hitting OK CF just closes.
10-10-2006, 02:34 AM
#73
Got the same problem, but mine happens randomly. I've had RC4 for 2 days on the PC and its the first time i got it. One you get it, you seem to get it more and more often. Can you look into this david?
10-10-2006, 09:09 AM
#74
Just to clarify, This was the first time I got that, and I've hibernated just fine since then.
10-10-2006, 11:55 AM
#75
I got that same message box as I tried if the DUN now works as it didn't with RC3 (the box just stayed on the screen after connection). I pressed the red button and... Well it didn't work (connected to internet ok) and the box stayed on the screen. However about 5 minutes of wait and that box appeared. After pressing ok CF closed. Restarted CF and everything was fine.
| Thread Tools |
| Display Modes |
Linear Mode
