RC4 Phoco issue / SE K800I
I have my SE K800i connected via BT and serial, and this works just fine.
When going through the config wizard, i get all the way up to selecting preconfigured profiles, and I choose Sony Ericssson K800i and get the error: //Options/SonyEricsson New has an invalid token with the details attached at the bottom.
If I choose continue it looks like itīs working though, but :-)
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Xml.XPath.XPathException: '//Options/SonyEricsson New' has an
invalid token.
at System.Xml.XPath.XPathParser.ParseXPathExpresion(String xpathExpresion)
at System.Xml.XPath.XPathNavigator.Compile(String xpath)
at System.Xml.XPath.XPathNavigator.Select(String xpath)
at System.Xml.XmlNode.SelectSingleNode(String xpath)
at PhoneCtlWizard.Form1.listBoxProfiles_SelectedIndexChanged(Object
sender, EventArgs e)
at System.Windows.Forms.ListBox.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ListBox.WmReflectCommand(Message& m)
at System.Windows.Forms.ListBox.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase:
file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
PhoneCtlWizard
Assembly Version: 1.7.5.39208
Win32 Version: 1.7.5.39208
CodeBase:
file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/PhoneCtlWizard.exe
CodeBase:
file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase:
file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
OpenNETCF.Desktop.Communication
Assembly Version: 2.9.2455.20183
Win32 Version: 2.9.2455.20183
CodeBase:
file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/OpenNETCF.Desktop.Communication.DLL
System.Xml
CodeBase:
file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Data
CodeBase:
file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
zBTHelper
Assembly Version: 1.0.1.19907
Win32 Version: 1.0.1.19907
CodeBase:
file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/zBTHelper.DLL
System.Drawing
CodeBase:
file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Infragistics.Win.v3.1
Assembly Version: 3.1.20041.15
Win32 Version: 3.1.20041.15
CodeBase:
file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.v3.1.DLL
Infragistics.Shared.v3.1
CodeBase:
file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Shared.v3.1.DLL
Infragistics.Win.UltraWinTabControl.v3.1
CodeBase:
file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.UltraWinTabControl.v3.1.DLL
Infragistics.Win.Misc.v3.1
CodeBase:
file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.Misc.v3.1.DLL
OpenNETCF.Net.Bluetooth
Assembly Version: 1.4.50709.0
Win32 Version: 1.4.50709.0
CodeBase:
file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/OpenNETCF.Net.Bluetooth.DLL
Interop.BTSTACKSERVERLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase:
file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Interop.BTSTACKSERVERLib.DLL
Accessibility
Win32 Version: 1.1.4322.573
CodeBase:
file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
/SOS/
XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
