Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Closed Thread
Old 11-26-2006, 05:28 PM   #16
WhateverWorks is an unknown quantity at this point
I have a couple bugs to report..
First one is that when playing a list of videos off the hard drive, If I start at one, double click the little video to make it fullscreen, then use the bar at the bottom to skip to the next, then try to black out the screen by holding the gamma button down it leaps forward in the video like I was fast forwarding. also, if I happened to press the track back ( << ) button before trying to black out the screen it would jump back while blacking out the screen.. if the previous button press is either volume up or down, I can't black out the screen at all in the next button press.
Also in this same mode, when switching back and forth, the video's seem to get squished and are no longer in their origanal resolution.. pressing the <-> button twice fixes it so they are back to their origanal shape.
Second one is that the visualizations don't seem to work when playing a CD.. they just act as if no music is playing at all.
Other than those little things.. no probs at all.
WhateverWorks is offline
Old 11-26-2006, 11:43 PM   #17
midiwall is on a distinguished road
I have a number of electronica tracks as MP3s, most are 80meg in size, some are over 100meg. When selecting one to play, I get the "Loading" banner for quite a while, (20-30 seconds on a 2ghz machine with 1.5gig of RAM) before the track starts to play. What are you "Loading"?
WMP starts the playback of any of these tracks in under a second.
:: Mark
midiwall is offline
Old 11-26-2006, 11:49 PM   #18
Quote: Originally Posted by veetid View Post
There are known XM issues, I have not done any XM programming in awhile...
The clearbuffer error is another XM error, again I have not worked on it in some time... I will get back to it as soon as I can...
Two things... a) the "won't save XM favorites" wasn't a problem in RC4.1; b) please add these (and the "confused data elements" issue) to your "known issues" list so they're not forgotten.
(so, three new items... 1) "Won't save XM favorites"; 2) "XM display elements get confused"; 3) "Clearbuffer error on module load")
:: Mark
midiwall is offline
Old 11-27-2006, 03:20 AM   #19
AlienEclipse's Avatar
AlienEclipse
email one of the files that the tag are not reading from to support@fluxmedia.net so we can try and figure out why they don't read...
david
I'm uploading some albums now. I will email you when complete.
We are, will have and forever will be...
But not tommorrow!
AlienEclipse is offline
Old 11-27-2006, 09:20 AM   #20
ahew is an unknown quantity at this point
David, the aussie maps are a bit strange. i had the old maps and they were ok. the new 2006 maps make you take right turns on no right turns, or left turns on through malls that you can't drive through, you don't get an option to skip toll roads, and there's no general map browsing. the GPS side needs a bit more work on CF. i've also had issues with tracking and response delays with the voice.
ahew is offline
Old 11-27-2006, 09:29 AM   #21
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
The Aussie maps were broken that Destinator released... They just fixed them a abou 2 weeks ago... I have had them tested and they are fixed... So the Aussie maps that will be coming with Centrafuse do not have this problem...
tracking and response delays is something with your system speed and what GPS issues need work that are not related to your bad maps?
It did take awhile for Flux and others to convince Destinator they had broken Aussie maps, but we finally did and got them recompiled just weeks ago...
david
veetid is offline
Old 11-27-2006, 10:34 AM   #22
hatton920 is on a distinguished road
Postcode search still takes too long to display the list. Over 1min on my carpc and over 30 secs on my desktop
Carpc is a m10000 with 512mb ram
Desktop is a Amd 3200+ with 1GB ram
hatton920 is offline
Old 11-27-2006, 11:44 AM   #23
VENDOR - Centrafuse
veetid's Avatar
What map are you loading? It works fine on my M10000 for all the North American maps. What country and map? Must be a very large list... If that is the case I will have to come up with some way to not fully populate it...
The UK is the one I noticed being very large and taking too much time, are you using UK maps? If so you guys have a lot of postcodes
I will check it out...
david
veetid is offline
Old 11-27-2006, 11:44 AM   #24
Updates...
Quote: Originally Posted by midiwall View Post
[*]XM Favorites not being saved. 100% repro. This was not an issue in RC 4.1
This is now a 95% repro. My XM presets decided to save today. It did happen to be an instance of my not exiting CF before killing the ignition, so it hung on coming back from hibernate ("XM displays 'Loading' banner on restore") and I had to get the keyboard out, kill CF, and restart it.
Maybe that's a clue? Maybe the fav's are actually getting saved but then cleared on a proper exit?
[*]Add (music/video) folders dialog broken. (possibly only with single click enabled) e.g. I want to add "c:\data\music",
  • Select Add Music Folder
  • Click "c:\"
  • Click "data"
  • Click "music"
  • Click "save"
  • Nothing happens
I found the repro for this... This will happen when you try to add a folder that has nothing in it. The way your listbox works, it wants to highlight something in the folder for it to think that there's a reason for you to click "Save". If there's nothing there, it won't allow the "Save".
New stuff...
- XM isn't saving Last Channel. It's always defaulting to "1".
:: Mark
midiwall is offline
Old 11-27-2006, 11:54 AM   #25
VENDOR - Centrafuse
veetid's Avatar
Updates...
New stuff...
Thanks for tracking down the folder issue, that will help me get it fixed quicker...
I apologize for all the XM issues... I have not touched the code in quite some time... We initially were waiting to hear back from XM about a new device they wanted us to use for the PC that was encrypted, we can all thank TimeTraxs for that issue...
They have plans to try and stop all this XMDirect PC front-end software, but are busy getting sued by the RIAA right now I believe, over their newer device that did all the recording. But for now I'm sick of waiting and I will just fix it all.. I have to renew my subscription it's been so long since I worked on it...
Also since XM is a US only feature, I felt I needed to get everything else fixed first...
I will get them all fixed for you and thanks for the testing everyone!!!!
david
veetid is offline
Old 11-27-2006, 11:59 AM   #26
Also since XM is a US only...
and officially Canada too now.
:: Mark
midiwall is offline
Old 11-27-2006, 05:26 PM   #27
David, the History on the sat nav doesn't save any history for me. what is it supposed to save actually? i'm not too sure myself. the little buttons on the left hand side can get a little annoying as i've pressed the map and accidentally cancelled the rout many times when trying to fiddle with those buttons.
ahew is offline
Old 11-27-2006, 06:02 PM   #28
VENDOR - Centrafuse
veetid's Avatar
What version are you using? Which little buttons are you talking about? There were small buttons on the left side of the map in RC4.1, but they have been removed for the exact reason you mention...
History is a history of all the places you have routed too... I will double check it, but it worked last time I checked it...
david
veetid is offline
Old 11-28-2006, 02:09 PM   #29
fatejd is on a distinguished road
I would just like to express my appreciation to David for his work - I know some people get frustrated with bugs, but this is how software development works, we are all beta (or RC now) testers. The only real bug I've run into on my machine is the skin hibernation Nav button issue which is known, I don't see any of these taskbar or other issues reported with crashing and errors, but maybe I'm just lucky. I have a VIA EPIA M10000 with a laptop 40GB HD - take that for what it's worth I guess.
Carputer Progress:
Re-do fabrication of screen [DONE]
Upgrade screen and PC [70%]
Wood faceplate for computer in glovebox [0%]
fatejd is offline
Old 11-28-2006, 03:34 PM   #30
david
Yep Uk maps here. Just checked google and it says there are 2.1 million postcodes. So very very very big list lol
Also history is not working for me in the lastest version. I fact I dont I have ever seen it work.
Closed Thread
Centrafuse RC4 Bugs veetid CF Bug Reports 113 10-18-2006 04:10 PM
Centrafuse RC3.1 Bugs veetid CF Bug Reports 135 10-06-2006 06:11 PM
Centrafuse 1.5 Bugs veetid CF Bug Reports 162 01-14-2006 08:03 PM
Centrafuse 1.4 Bugs veetid CF Bug Reports 270 09-27-2005 10:58 PM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
