Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Closed Thread
Old 12-03-2006, 04:54 AM   #61
nessie is an unknown quantity at this point
Failed to load resources from resources ... etc
XP Home (minimized, nLite), Dutch, Dotnet 1 till 3, PIII, 666, 250Mb, latest CF, default skin
At first got the error when trying to build a library
Lowered the amount of files, error happened a little while after building the library.
Saw on the forum the same error appeared in 3.x and had to do something with viz ? Didn't know what was meant exactly, but got rid of the buttons I don't need in the main. Surprise was great when I was able to build the library, and play for more than 2 hours.
Funny thing is, I played around with CF for a while BEFORE I tried to build the library. I played around with the settings for the navigation, no error came up, and this took me a couple of hours.
There's one thing I'll try (cuz CF didn't give any error at all at my other machine, an AMD64 3400 though), reinstall the whole windows bunch (FULL) and stick to dotnet 1.1. See what it gives, won't be for today I suppose.
Any idea is welcome
nessie is offline
Old 12-03-2006, 02:38 PM   #62
proximo is on a distinguished road
I've had to reinstall CF a couple of times since RC4.2 was released. After a day or two of use, it brings me to the Setup screen again and I have to reinstall to get things to work.
I'm not sure if this has been reported, but everytime I load my entire music library (about 1450 songs now), and restart the computer, most of the songs disappear from the playlist. The number of song still present in the list after a reboot varies between 50-250 songs.. It almost never resumes the actual song that was playing either.
proximo is offline
Old 12-04-2006, 01:00 PM   #63
Red face
[....cut]
Any idea is welcome
ok, don't know whether this is uselfull or not,
installed XP Home Dutch, full, only 1.1, mapsource soft and that's about it, it works like a breeze
so apparently I removed something critical with my nlite version ... question is: what ?
cheers
nessie is offline
Old 12-04-2006, 01:28 PM   #64
midiwall is on a distinguished road
There have been a few discussions about nLite versions, and the net result is that CF is hooked into enough stuff that it's not really worth the headaches to figure out what you can get away with ripping out.
Thee last time this was mentioned, someone piped up saying that he's been able to strip something out, but he didn't offer up an nLite config to share.
Bottom line, I think 99.9% of the CF users are running a full install.
:: Mark
midiwall is offline
Old 12-05-2006, 01:22 AM   #65
AlienEclipse's Avatar
AlienEclipse
My last ISO was down to 333MB including ~50MB of drivers. and it works fine with CF 4.2.
I'm still working on getting it down.
We are, will have and forever will be...
But not tommorrow!
AlienEclipse is offline
Old 12-05-2006, 02:50 AM   #66
Smile
Would you be so kind to provide me your conf-settings (supposed you're using nLite) ?
I might compare with mine then I suppose,
Thanks in advance,
cheers
nessie is offline
Old 12-05-2006, 05:50 AM   #67
AlienEclipse
Thanks in advance,
cheers
Sure. you'll need to rename it by removing the .txt
EDIT:
This is for the latest nlite 1.2.1
I started with XP Corp with slipstreamed SP2
RyanVM Integrator:
RVMUpdatePack2.1.4
RVMAddonsDX9_1.0
Boooggy_WMP11Addon
But not tommorrow!
Old 12-05-2006, 01:19 PM   #68
Right on dude... WELL DONE.
I thought you had given up on this a while back... Obviously I was wrong!
:: Mark
midiwall is offline
Old 12-05-2006, 06:00 PM   #69
AlienEclipse
Its a long and painfull process, but i'm getting there.
But not tommorrow!
Old 12-05-2006, 06:14 PM   #70
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
I have updated the threads...
Here they are.
RC4.3 Release Notes
http://www.mp3car.com/vbulletin/centrafuse/91699-centrafuse-rc4-3-release-notes.html
Known Issues
http://www.mp3car.com/vbulletin/centrafuse/80817-centrafuse-known-issues.html
All the major issues have been fixed... Still working on the HQCT some and trying to fix a couple of the issues listed under "Known Issues being looked into", I was able to remove a couple from this list, but of course add a couple more at the same time
I still have to double check some code, package the installer, and test it...
I know about the serial expiration issue and I'm working hard to get this out fast, but a good release...
david
veetid is offline
Old 12-05-2006, 11:56 PM   #71
Dude..
Known Satellite Radio Issues
- hibernate from XM favorites screen, on resume loading shows up and hangs application
REALLY???? You can't find time to fix this ONE issue?
The only good thing at this point is my truck is down while I rebuild the engine. That saves me from constantly having to deal with this 10+ times a day.
ARGH
:: Mark
midiwall is offline
Old 12-06-2006, 01:52 AM   #72
VENDOR - Centrafuse
veetid's Avatar
Quote: Originally Posted by midiwall View Post
Dude..
ARGH
I'm not done yet, hence the known issues... There are many people around the world that use Centrafuse, XM and the US is a very small part, so those bugs come last...
I WILL get all the XM issues fixed... my releases are coming out very fast, expect it to all be fixed soon...
I hope to get even less bugs with RC4.3, therefore giving me time to focus on XM and knock it all out at one time...
Not to mention I don't have an XM subscription anymore at the time, but I plan to renew once I start to fix...
I understand your frustration... I hope that RC4.3 will have few bugs reported and I can focus on the few and XM for RC4.4...
david
veetid is offline
Old 12-06-2006, 02:20 AM   #73
As you've said before, but of all the bugs left across ALL the modules, this one is crippling for those folks that don't ride with a keyboard so that they can "safely" reboot (versus just yanking the power).
Wanna me to add you to my plan for a month or two? I'd be willing to drop one of my four receivers to get you activated.
:: Mark
midiwall is offline
Old 12-06-2006, 02:51 AM   #74
VENDOR - Centrafuse
veetid's Avatar
I'll sign up and get it all fixed... once I load XM, I will be fixing it all... Hopefully next release for sure...
I personally hate XM, which doesn't help with programming it
david
veetid is offline
Old 12-06-2006, 09:27 AM   #75
And I hate DRM, but I wrote the porting kit for MSFT anyway.
How about handing off the source for the XM module to me and you can stick with the HQ radio module?
:: Mark
midiwall is offline
Closed Thread
Centrafuse RC4 Bugs veetid CF Bug Reports 113 10-18-2006 04:10 PM
Centrafuse RC3.1 Bugs veetid CF Bug Reports 135 10-06-2006 06:11 PM
Centrafuse 1.5 Bugs veetid CF Bug Reports 162 01-14-2006 08:03 PM
Centrafuse 1.4 Bugs veetid CF Bug Reports 270 09-27-2005 10:58 PM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
