Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Closed Thread
Old 01-07-2007, 02:46 PM   #16
Phone Control Moderator
zorro's Avatar
zorro is on a distinguished road
Quote: Originally Posted by coucouillu View Post
I think WE need Zorro here.
If you have wrong parameters for Phone control in Centrafuse and get the message on Centrafuse startup "Opening the communication port failed..." (look at the joined picture) PhoCo will write several times per second the following message in error.log file in Centrafuse directory :
Code:
---------------------------------------------------------------------------------------------------------- 07/01/2007 17:43:11 Une connexion existante a dû être fermée par l'hôte distant at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at PhoneControl.PhoCoInterface.ReceiverThread() ----------------------------------------------------------------------------------------------------------
It writes about 1,5Mo/minute !!!!
After a few day with my com port failed message I have my error.log file which is 230Mo big!!!!
I know that disabling the phone in settings solve the problem but I think PhoneControl should be fixed for this case.
I'm sorry, this has to be done by David. PhoCo isn't writing anything into the CF error.log.
However, there is a PhoCo Bug in this release that will not show the contacts from the phonebooks. To get rif of it, download these two files:
PhoneCtlInterface.zip -> goes into the CF folder
PhoneCtlWizard.zip -> goes into the CF\PhoneControl.NET folder
After that rerun the Wizard to correct the settings in the configuration file and everything's good.
Skinning to go... VisualDesigner2!
zorro is offline
Old 01-07-2007, 03:18 PM   #17
coucouillu's Avatar
coucouillu is an unknown quantity at this point
Thank you for the joined files.
coucouillu is offline
Old 01-07-2007, 06:33 PM   #18
ivanmx6's Avatar
ivanmx6 is an unknown quantity at this point
Quote: Originally Posted by justintime View Post
ivanmx6:
When you upgraded to RC5, are you seeing the same issues with squares in titles that I see? How about the Genres with 'commas' in them? See my posts above...
Not seeing either of those here problems Justin, sorry.
ivanmx6 is offline
Old 01-07-2007, 07:32 PM   #19
Alfredbra is an unknown quantity at this point
Cant send SMS. I have an o2 mini xda (windows mobile 2003 SE) phone. I can recieve SMS messages, calls, dial, view inbox and everything BUT send an sms message. I have downloaded phonecontrol.net and have tryed using that software but the problem still occurs.... Dunno if its a bug i should be posting here or on the phoncontrol.net site. Or perhaps i have something not quite right? I have tryed setting up the phone as just a windows mobile 2003 handset but i still get the same issue.
Using widcomm stack. Headset working fine everything but sms.
Thanx
Alfredbra is offline
Old 01-07-2007, 11:46 PM   #20
midiwall is on a distinguished road
Quote: Originally Posted by Alfredbra View Post
Cant send SMS....
Did it work in a previous release or is this your first foray into CentraFuse?
Check for an "error.log" file in the CF install directory. If it's a problem with CF there may be some info there.
:: Mark
midiwall is offline
Old 01-08-2007, 04:34 AM   #21
first time using centrafuse used the version before this, now bout to try the new version. But i dont think its a problem with centrafuse as it does it with Phonecontrol.net (the latest one i have downloaded from there website)
Old 01-08-2007, 06:41 AM   #22
i still recieve the problem when i press media the volume goes back to "min"
Using realtek HD audio. I was emailed that this problem was fixed in this release but i am still getting this one. Had to resort to installing a PCI sound card to get by.
Had problems with viewing SMS messages on my o2 mini phone. Could view the contact list and call out but thats about it.
At the moment i just reverted back to previous version....
Old 01-08-2007, 06:46 AM   #23
damn it cant even system restore! makes me angry when this crap happens and have to reinstall centrafuse and get everything up the way i like it again. so very frustrating.
PLEASE FIX THE SOUND ISSUE!
Old 01-08-2007, 10:23 AM   #24
DaKyy's Avatar
DaKyy is on a distinguished road
Quote: Originally Posted by jarred View Post
I'm still having the issue of mute being applied when I go to media. I have a EPIA MII 12000 motherboard, using a Silverstone DAC for audio.
Thanks,
Jarred
This has been around since RC4.2 and david hasn't even listed it as known bugs yet. And I've mentioned it for about three times now (in bug threads) without any reply from david.
Volvo 480 Restoration Project
DaKyy is offline
Old 01-09-2007, 03:55 AM   #25
VMS
VMS's Avatar
VMS is on a distinguished road
his at CES at the moment
Vehicle Media Systems
Australia Car PCs www.vmscarpc.com.au
VMS is offline
Old 01-10-2007, 12:14 PM   #26
chevyunger is on a distinguished road
language confusion
I dont know whether its a new bug, becaus I tried this the first time.
I want to see a video (.avi) which has two language streams, german and english. In mpc you can choose between both streams and hear what you want. CF mixes both streams and you hear german and english together. Its funny, but not what I want.
chevyunger is offline
Old 01-10-2007, 03:03 PM   #27
coucouillu's Avatar
Start full screen on "ON" in CAM plugin option won't save.
Auto Start menu on "ON" doesn't work.
Old 01-10-2007, 06:36 PM   #28
SUVputer is on a distinguished road
Visualizations
hey david, excellent work!
I just found a tiny bug that has to be mentioned:
1-play an mp3 file with a name/artist/album filled
next, play a normal audio CD and choose a track
now "full screen" the visualization,
it will show the track number with the details (artist + album) of the last mp3 file played before playing the CD.
good luck!
thanks again
VIA EN15000 C7 // CTF700 7" Screen // Morex 3688 Black Case
M2-ATX // 80GB HD
DVD-RW // PowerMate
Belkin Bluetooth V1.2 // Hauppauge WinTV FM
Centrafuse RC5
JBL GTO 75.4 520W // Pionneer Kevlar 260w Speakers
SUVputer is offline
Old 01-11-2007, 04:31 AM   #29
using a bluetooth GPS and the Widcomm drivers. CF will connect to the bluetooth gps when you press navigation. If you put the computer into standby or hibernation. The bluetooth connection will be lost to the gps and you have to exit Centrafuse and enter centrafuse again. Or by manually connecting to the device and entering back into centrafuse. It seems like it doesnt refresh the com port that the bluetooth gps is assigned to.
Old 01-11-2007, 08:29 AM   #30
VMS
VMS's Avatar
Thats a windows and WIDCOMM issue, happens with phoco sometimes as well. Use a usb device, much more reliable. we recommend BU353.
VMS is offline
Closed Thread
Centrafuse RC4.3 Bugs veetid CF Bug Reports 28 12-10-2006 02:48 PM
Centrafuse RC4 Bugs veetid CF Bug Reports 113 10-18-2006 04:10 PM
Centrafuse RC3.1 Bugs veetid CF Bug Reports 135 10-06-2006 06:11 PM
Centrafuse 1.4 Bugs veetid CF Bug Reports 270 09-27-2005 10:58 PM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
