Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Closed Thread
Old 01-14-2007, 05:02 AM   #46
Phone Control Moderator
zorro's Avatar
zorro is on a distinguished road
Quote: Originally Posted by coucouillu View Post
On Centrafuse Known Issues
On my HTC TyTN Phoco program blocked after a few minutes (it doesn't exit but freezes with the little icon in green mode, Zorro would inderstand the green mode)
Please send me the PhoCoAdapter.log after it freezes (into my forum).
Skinning to go... VisualDesigner2!
zorro is offline
Old 01-14-2007, 05:15 AM   #47
coucouillu's Avatar
coucouillu is an unknown quantity at this point
Wow your are reactiv..
I wil try but where is the .log file on WM5?
coucouillu is offline
Old 01-14-2007, 05:19 AM   #48
zorro's Avatar
It's on the root folder \ of your phone called PhoCoAdapter.log.
Please post in here: http://zhorvat.dyndns.org/PCForums/S...spx?ForumID=44
zorro is offline
Old 01-14-2007, 05:45 AM   #49
Alfredbra is an unknown quantity at this point
cant get bluetooth gprs working through my phone. I have set up the bluetooth modem in windows xp, and can connect to the internet fine. When trying to connect using centrafuse it connects to the phone all ok, then trys to authenticate. Then after a period of time it just says error connecting. In the internet setup of centrafuse, all the details are correct the dialing number
*99# etc. but cf seems to automatically put a 8 or more digit password in the password field even though there should not be one. if you erase the password it will come back again after closing down and reopening cf. Whether this has something to do with the problem i dont know.
I am using an o2 mini xda phone (windows mobile 2003) and using the Widcomm bluetooth stack.
Alfredbra is offline
Old 01-14-2007, 06:12 AM   #50
I own destinator PN on pocket pc and have loaded the maps into centrafuse. I can navigate by city-street, but not street-city, postcode-street etc. I realise perhaps these maps may not be supported, but would be quite nice if somehow us australians could get it to work.
Xport3 worked like a charm thanx!
Old 01-14-2007, 12:50 PM   #51
AngryMan's Avatar
AngryMan is on a distinguished road
OK David, Ill send you one of mine. they are not in pretty little cases so the wiring on them is easy to examine. Ill even box it up right now just PM me an address to mail it to.
.______
/ '__|__\____ VW CarPC project
\(o)_____(o)/ Full Spead Ahead!
Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
www.summitadventuresystems.com
AngryMan is offline
Old 01-14-2007, 01:43 PM   #52
coucouillu's Avatar
Very difficult to reproduce.
Sometimes (I think after hibrenate wake up) if you change skin when reading a video, the video goes to fast forward alone.
Old 01-14-2007, 03:25 PM   #53
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
It doesn't work for me on 2 machines (Jetway 7F2WE-2G-OC and Fujitsu Pentium 4 2.6GHz HT).
It doesn't work if your setteings are :
Settings-->General-->Startup location-->Main menu
but if the settings are :
Settings-->General-->Startup location-->Media its works!
weird... If I exit and I was playing media, radio, or sat radio it always starts the music back up no matter what my section is...
I will look back through the code and try to reproduce...
david
veetid is offline
Old 01-14-2007, 03:25 PM   #54
VENDOR - Centrafuse
veetid's Avatar
with my tests it actually stops showing up in task manager all together and it has to be launched again, or phone rebooted...
david
veetid is offline
Old 01-14-2007, 03:27 PM   #55
LEiPiE's Avatar
LEiPiE is an unknown quantity at this point
RC5 runs perfectly here... except (this is the bug thread ) the mp3 library seems to get messed up a little bit here. I've rebuild it, but get the same problem over and over: some artists have been randomly replaced by other names. They appear in the library list in the correct order, that is: based on the real name (erm ok, order is by the filename, doh )).
So between Guns 'n Roses and J.J. Cale there's a sudden appearance of Air while in reality it's Hooverphonic... the two files that are by Air are correctly in the list though. In a list of 135 mp3s I now have 7 tracks where the artist's name has been replaced in some way.
Rebuilding the library gives the same 7 errors.
Haven't found a pattern: it's not the name of the track before it, it's sometimes an artist name that's ahead and sometimes behind in the alphabet.
Also it's not that 1 artist name is completely replaced by another, though if it happens multiple times for the same artist it's by the same other artist.
Multiple times the substitute name was the same by the way.
I have not seen any other tag substitutions.
See here for a list (that's one directory of a couple of dirs, there's only one other dir where there's only one substitution (MC Hammer by Earth & Fire (again!)).
The artists are also not in the list if I browse by Artist (I usually browse by Music folder).
What could this be? Willing to provide extra info if needed
(and no: Earth & Fire is not Earth, Wind & Fire typed wrong... Earth & Fire was a Dutch Progressive Rock (later more pop though))
(need to install the PC in my car again to see if satnav and such still work and if I have to complain about the resolution of the Cam plugin )
CarPC: "Carma" (Car Audio & Route Management) (about 70% ready)
P4 1.8GHz / 512MB / 4GB CF
Asus TVFM + B/W camera
15" touchscreen 1024x768
BU303
2x 100Ah
reinstalling
And all this in a Dutch 1972 Citroën HY van called "MurpHY".
LEiPiE is offline
Old 01-14-2007, 03:28 PM   #56
VENDOR - Centrafuse
veetid's Avatar
This is on my list of known issues, DUN issues... The password is normal, I encrypt the passwords so people cannot see them if they open the text files, even a blank password has characters, that is not the issue....
It works for me on dialup modems, but I have to look into issues with bluetooth dial up networking, that seems to be the issue...
I will get it fixed...
david
veetid is offline
Old 01-14-2007, 03:28 PM   #57
VENDOR - Centrafuse
veetid's Avatar
only D6 maps are fully compatible...
david
veetid is offline
Old 01-14-2007, 11:54 PM   #58
hari-bhari can only hope to improve
i am still getting the square block after my album names. i went through and deleted EVERYTHING from the id3 tags, including comments, year, etc etc. all i left was artist, title, album, track number, and genre..
hari-bhari is offline
Old 01-15-2007, 12:56 AM   #59
Raw Wave
justintime's Avatar
justintime is on a distinguished road
What tag editor did you use? Some basic editors do not show you the extended ID3 tags. I think you might be deleting all the tags EXCEPT for the ones that really are causing the 'square' issue.
Grab The Godfather and follow my instructions from this thread...
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline
Old 01-15-2007, 10:19 AM   #60
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
If I go into setting via the side menu, edit nav settings... When I click save (settings) it then shows the map over the settings screen with the close button at the bottom, close button removes the bottom row of settings menu buttons and returns to NAV.
It has done this since RC3 but I have been offline to post due to house move
POI warning function also warns about every POI And no way to select what is warns for or what it says as a warning!
Address lookups in NAV still take WAY WAY TOO LONG - 30seconds plus.
Also still suffering the screen flashing issue on resume from standby and Hibernate. Clicking NAV when button is visible stops it - When all my hardware and PC in house is set up I'll do a video to show this problem for you
It would also be handy IMO to have back and forward buttons on the playlist thingy on the left in Media player instead of just a back/eject button. You know, so you can skip forwards through playlists, not just go backwards.
ShawJohn is offline
Closed Thread
Centrafuse RC4.3 Bugs veetid CF Bug Reports 28 12-10-2006 02:48 PM
Centrafuse RC4 Bugs veetid CF Bug Reports 113 10-18-2006 04:10 PM
Centrafuse RC3.1 Bugs veetid CF Bug Reports 135 10-06-2006 06:11 PM
Centrafuse 1.4 Bugs veetid CF Bug Reports 270 09-27-2005 10:58 PM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
