01-19-2007, 03:33 PM
#76
Have just tried with a fresh installation. Same result as mentioned before also with the tap function for viewing cityes..
//Sunaj
01-19-2007, 04:16 PM
#77
Is gapless playback still in the works? I have never seen this work and still don't with this version.
Carputer Progress:
Re-do fabrication of screen [DONE]
Upgrade screen and PC [70%]
Wood faceplate for computer in glovebox [0%]
01-19-2007, 06:33 PM
#78
VENDOR - Centrafuse
I haven't looked into it in ahwhile... I will add it back on my list of things to look into, I mainly always leave fading on for a smooth transition...
are there any gaps in your mp3 files because I thought I already implemented this, but will have to verify...
david
01-19-2007, 06:49 PM
#79
Raw Wave
while on the subject, I would like to see gradual incresase/decrease of volume when pausing/resuming songs. I want this REGARDLESS of thecrossfade setting mode. Sorry if I already mentioned, I think I might have.  Low priority though.
01-19-2007, 07:13 PM
#80
Fading doesn't cut it though for long pieces that are meant to be listened to as a contiguous piece but yet have track markers for the consumer's sake. e.g., classical volumes and some electronic works.
:: Mark
01-20-2007, 04:51 PM
#81
Yes, exactly. And, no, there are no gaps in my FLAC or MP3 files, there just is no gapless playback unless my computer is too weak (doubt it). The crossfading seems to work well for live concerts that are all one piece of music broken up, but doesn't work to well for albums that already have crossfading on them between tracks.
Carputer Progress:
01-20-2007, 05:00 PM
#82
Raw Wave
crossfading and gapless playbacks are indeed 2 different things.
01-21-2007, 06:17 PM
#83
I unfortunately found a bug with your new single click dvd feature. If I try and click on a menu item on the dvd title page that is down where the dvd controls and info are, the CF bar pops up covering it, rendering me unable to click on the menu item. Does that make sense?
01-21-2007, 07:15 PM
#84
VENDOR - Centrafuse
will check it out...
david
01-21-2007, 08:59 PM
#85
Have you changed anything in relation to hibernation? I haven't changed my system at all, but now resume from hibernation takes forever and CF is unresponsive.
EDIT: I get a phoco setup error on resume, maybe this is the cause.....
EDIT2: My hub is having issues coming out of hibernation. It's not CF. Sorry for the red herring.
01-22-2007, 02:56 AM
#86
I upgrade my Carputer with an ATI Radeon 9550.
And setup cloning the main Display on the second displays on my Rearseats.
Also i activate the Theater mode, which plays videos in Fullscreen on the second Display.
That setup work like charme! But when i close the Video in Centrafuse, or switch back to Music, the Displays aren't cloned anymore on my Reardisplays. They show the first image of the Video.
I have to close / restart CF to clear the reardisplays.
Seems the Video-overlay isn't closed when stopping the Video?
01-22-2007, 03:04 AM
#87
VENDOR - Centrafuse
I do not know much about theater mode, works fine with just multiple monitors or standard TV out...
will need the hardware to test it out and reproduce...
david
01-23-2007, 04:01 AM
#88
Quote: Originally Posted by DaKyy
This has been around since RC4.2 and david hasn't even listed it as known bugs yet. And I've mentioned it for about three times now (in bug threads) without any reply from david.
have you tried to manually force "NONE" to the audio line for each plugin? I used to have this problem and I fixed doing this
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
01-23-2007, 04:03 AM
#89
what abount make fade in when coming back from pause? I's a must do..
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
01-23-2007, 12:48 PM
#90
On the subject of gapless playback and crossfading - is there any way to implement an option of crossfading tracks EXCEPT when the next song being played is the next track on the album? That would be a very cool thing to have
| Thread Tools |
| Display Modes |
Linear Mode
