03-15-2007, 08:03 AM
#2
Raw Wave
David,
I have a minimize.png file in my Skins\Nexus WS Amber\icons\ folder, and it still does not show with v 1.11
03-15-2007, 12:43 PM
#3
VENDOR - Centrafuse
Quote: Originally Posted by justintime
David,
strange, I added it to my bugs and I will look into it...
david
03-15-2007, 12:52 PM
#4
Stuff from 1.11, some of this is probably old and I just didn't notice it. - Updater needs a progress bar. Knowing the size of the download is nice, but having an progress bar lets me know how soon before I can pull out of my driveway.
- If you turn off the buffer for XM, the audio level jumps up quite a bit. I understand this is 'cause of the "LINE IN" level setting in the mixer, but what I find curious is that there's obviously a substantial gain LOSS when using the buffer.
- The top entry in the XM channel list is redundant. I figure it's basically a "now playing", but you already have that with the highlight bar on the station. I vote to remove it, thus freeing up space to show 6 channels in the list versus 5.
- Buffer must be ON for EQ to work. This makes sense, but you may want to enforce this in code. i.e., if the user sets EQ = ON, then run through the modules and make sure that all of the audio inputs are being buffered (e.g., XM).
- Turning EQ ON or OFF requires a reload of CF before it takes effect. If this is "how it needs to be" then you may want to pop up a dialog to let the user know.
- EQ slider positions are not being saved across a reload of CF.
On the good side... THE UPDATER WORKS!!!!! WOOHOO!
:: Mark
03-15-2007, 01:21 PM
#5
VENDOR - Centrafuse
I will look into a progress bar, but bugs are more of a priority right now... most updates should come down pretty fast even on a phone download speed... I don't plan to send entire skins or plugins out through the downloader...
This is all about your levels and just how it works for now... The playback of the buffer should be at the same audio level as the playback of all your audio files, or close to it... This is where you should set your level for the input... With buffering off it's windows pass through and not using Centrafuse at all for anything...
You can still have the EQ on and use it for all your media, but have radio or XM not use the buffer and this how you want it to be... So I won't force the use of the buffer just to have EQ on...
I will make it not require a reload, it should be this way...
The EQ positions should be saved, is it creating an error.log file? Did they every save for you or did you just notice?
david
03-15-2007, 01:39 PM
#6
Yeup, I know, that was more of a suggestion.
Hmm... okay. I'll level set along side of some MP3s.
Ahh, that makes sense. Is this mentioned in the manual? (I haven't looked). The point being that this could be a point of confusion for people that turn on EQ but can't affect a change in the audio.
I'm 97% sure that it's always been like this. I remember playing with EQ before and seeing the issue. I haven't had EQ enabled for a while, I only turned it on now to see about audio quality issues.
Lemme walk out to the truck and look for an error log...
...got one. Nothing about the EQ, just reams (2800 lines since the 4th) of:
Code:
Font 'Century Gothic' doesn't support style 'Regular'.
at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
at System.Drawing.Font..ctor(String familyName, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet)
at centrafuse.Plugins.CFPlugin.setlabelskin(String whichlbl, MouseEventHandler clickEvent, MouseEventHandler downEvent)
:: Mark
03-16-2007, 12:58 AM
#7
Volume dialog box issue
Once again the volume dialog box is not closing. The good news is the setup error no longer comes up, where you are forced to close Centrafuse. Basically the Volume dialog box does not close, but otherwise the program works normally.
The bad news of course, is now it is not generating an error log.
One observation is that I did not start having this problem until I connected to the Internet.
My father was borrowing my EVDO router earlier today, so I had been running Centrafuse all day without an Internet connection. Once I hooked the router up later this evening is when I started having the volume dialog box issue.
So, I'm assuming something could be happening when it is pulling down the weather, or the Internet detection.
Reason: Automerged Doublepost
03-16-2007, 01:33 PM
#8
VENDOR - Centrafuse
Code:
Did you modify the skin? This would only happen if the font did not get installed right or you modified the skin.xml file, or you are using another skin that try's to call on a font that doesn't support bold...
I will look into explaining the EQ, you are probably right...
david
strange... This is with the udpate and 1.11 right? I did modify some code how the weather and the internet connection is detected...
if you simply hit the volume key again after it gets stuck it doesn't close?
I cannot reproduce this, I am hitting it really fast with and without internet...
david
03-16-2007, 04:26 PM
#9
Nope, I've had this problem for many versions now, first reported back in late November against RC 4.1:
http://www.mp3car.com/vbulletin/cf-bug-reports/89133-centrafuse-rc4-1-bugs-post967200.html
In this latest case this is a pure stock install of XP SP 2 onto a virgin system (formatted the HD) with a virgin copy of CF. The font IS there, and I can create a document that uses it. CF looks "fine", it doesn't seem to be suffering from the error outside of it happening 6 times/second at startup.
:: Mark
03-16-2007, 05:46 PM
#10
VENDOR - Centrafuse
http://www.mp3car.com/vbulletin/showthread.php?p=967200
open up your skin.xml file from the skin you are using and search for the text
Regular
It should return no results at all, if it does then you have a different skin.xml somehow than I do...
The font doesn't support regular and I have been emailed many error.logs over the versions and never seen that error...
only way is if Regular is typed as the font style somewhere in the skin.xml file, which I don't see anywhere...
david
03-16-2007, 08:03 PM
#11
Regular
Nope, it's not there...
Code:
c:\winapps\centrafuse>dir Skins\*.xml /s
Directory of C:\winapps\Centrafuse\Skins\Onyx WS Day\*.xml
11/18/06 21:39 211,146 skin.xml
211,146 bytes in 1 file and 0 dirs 212,992 bytes allocated
Directory of C:\winapps\Centrafuse\Skins\Onyx WS Night\*.xml
12/04/06 21:40 211,145 skin.xml
211,145 bytes in 1 file and 0 dirs 212,992 bytes allocated
:: Mark
03-17-2007, 01:43 PM
#12
david
Yes,
It was with version 1.11. Hitting the volume up or down does not get rid of it. The dialog box does continue you display the volume changes, but does not go away.
The setup error did eventually come up and an error log has been created...
The bad news is now Centrafuse will no longer come up. It gets stuck on the spash screen at building controls.
So I guess I'm stuck with roadrunner for now.
Error Log Below:
3/14/2007 9:32:03 PM
Object reference not set to an instance of an object.
at centrafuse.Music.loadSong(String filename, String songname, Int32 songindex, Boolean iscd)
at centrafuse.Music.mp3next(Boolean nextclick)
03-17-2007, 02:18 PM
#13
VENDOR - Centrafuse
Yes,
Error Log Below:
Try 1.1 and see if your issues go away... I believe most of this is being caused by bad internet detection code and lagging out the loading of the application...
not sure about your volume issues, anyone else seeing this??
david
03-17-2007, 04:50 PM
#14
david
I had the same volume problem with 1.1, as well. I posted the error logs in the 1.1 problem thread.
03-17-2007, 10:24 PM
#15
New one: - OBD won't catch the MIL lamp, nor read codes.
I threw an MIL twice today (this is normal for me right now, I'm tuning) and both times CF never saw the lamp (i.e., the engine icon didn't light up), nor would it read the codes if I clicked on the engine anyway. It WOULD clear the code.
In both cases I was able to read the code with another app in Windows, and another OBD device I have.
This is an OBDPro USB box.
:: Mark
| Thread Tools |
| Display Modes |
Linear Mode
