Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 03-23-2007, 09:03 PM   #1
Bluetooth Internet causes Centrafuse to Freeze
David,
I've reported this issue before, but please hear me out again.
When try to connect to the internet from centrafuse, the program freezes when it gets to "Connected". It used to give an error message, but now it just freezes.
I can connect perfectly from Windows without Centrafuse running.
I have tried reinstalling my bluetooth, Centrafuse, and several drivers.
Below is the contents of my Error.log file. I think the list error is the one that has something to do with the bluetooth, but I'm not sure. Please note, I had to force the program to quit when it hung, so that alone may have caused the error in the log?
Please let me know if there is anything I can do to fix this issue.
Thanks,
Scott
error.log:
3/23/2007 12:46:56 PM
Object reference not set to an instance of an object.
at Un4seen.Bass.Bass.BASS_Stop()
at centrafuse.main.mainExit()
3/23/2007 1:04:24 PM
at centrafuse.Music.loadSong(String filename, String songname, Int32 songindex, Boolean iscd)
at centrafuse.Music.mp3next(Boolean nextclick)
3/23/2007 6:46:30 PM
Cannot access a disposed object named "main".
Object name: "main".
at System.Windows.Forms.Control.CreateHandle()
at System.Windows.Forms.Form.CreateHandle()
at System.Windows.Forms.Control.get_Handle()
at System.Windows.Forms.Control.CreateGraphicsInterna l()
at System.Windows.Forms.Control.CreateGraphics()
at centrafuse.main.updateMainTitle(String text, Boolean scroller)
spdyscotty is offline   Reply With Quote
Old 03-23-2007, 09:53 PM   #2
MySQL Error
veetid's Avatar
most likely the same internet detection issue in 1.11, this has been fixed...
david
veetid is offline   Reply With Quote
Old 03-25-2007, 06:00 PM   #3
David,
I just tried the new update. The computer still froze, but it got past the "Connected" dialog box. The dialog box closed, but CF was then unresponsive.
Scott
Old 04-01-2007, 07:33 PM   #4
Mine freezes on the Connected notification as well - this will be fixed in 1.12, correct?
Carputer Progress:
Re-do fabrication of screen [DONE]
Wood faceplate for computer in glovebox [0%]
fatejd is offline   Reply With Quote
Old 04-01-2007, 07:52 PM   #5
MySQL Error
veetid's Avatar
still looking into it... hoping it was the bad code in the last release causing some of the issue...
I will look into it more if still broken after 1.12, which is ready but I'm waiting for one update from Destinator...
1.12 will also come with a MapPoint plugin as well so you can choose your navigation...
david
Old 04-05-2007, 06:31 PM   #6
David, I'd like to see if this problem is caused by the new versions, or if maybe it is just my system.
Any way you could send me a link to an old version that you know would work? I think I maybe Have RC4 or something like that saved. Would you like me to give it a try and report back?
Scott
Old 04-05-2007, 07:50 PM   #7
MySQL Error
veetid's Avatar
Scott
sure, that might help...
once I get 1.12 out I will look into the last few issues that are being reported...
david
Old 04-16-2007, 07:19 PM   #8
DaKyy's Avatar
I updated from 1.10 to 1.11 through internet updater. The BT internet worked ok with 1.10. With 1.11 I've got the same issue as it gets stuck to the connected dialog.
edit: I also tried to connect to internet before starting up Centrafuse, won't work that way either. Will freeze on startup. Eventually it does come alive though - if I shut my phone bt connection off.
Volvo 480 Restoration Project
DaKyy is offline   Reply With Quote
Old 04-17-2007, 07:28 PM   #9
MySQL Error
veetid's Avatar
The internet issue is a known issue... there is a temp fix posted towards the end of the above bugs thread..
it should also work fine in the upcoming 1.12 release..
david
Old 05-03-2007, 07:48 PM   #10
David,
I'm still having the same issue with 1.12. Actually, it also freezes when it connects to my home wireless network as well.
Scott
Old 05-09-2007, 02:11 AM   #11
also have this problem still with 1.12
jwrpalmer is offline   Reply With Quote
Old 05-09-2007, 04:56 PM   #12
David, is this going to be fixed for the retail system? Is there anything I can try on my system?
Old 05-10-2007, 11:33 AM   #13
MySQL Error
veetid's Avatar
it will be fixed... I have it on my list of issues...
it is at the top of my list after the upcoming update...
david
Old 05-31-2007, 12:19 AM   #14
David, any update?
Old 05-31-2007, 09:55 AM   #15
MySQL Error
veetid's Avatar
still never reproduced this issue... I did add a new internet detection method so you can enter a URL in System\config.xml to use to check internet instead of the CF method, which might have caused some issues...
david
Bluetooth Dongle Not Working correctly KingsDude Wireless Communications 6 05-17-2007 01:30 PM
Listening on XM radio stations via internet directly in Centrafuse - is it possible? urosbe Centrafuse 2 08-21-2006 11:06 PM
Cell/PDA Internet without tying up the phone line (internet, calling simultaneously)? jedymastyr Wireless Communications 2 06-28-2006 02:16 AM
What Bluetooth software? pijo1971 GPS 1 04-05-2005 02:37 PM
