Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF FAQs
Old 12-11-2004, 10:40 AM   #16
DRWeside is on a distinguished road
NM's D3 frontend is awesome, but I can't get it to embed in centrafuse. I've tried all of the possible window names, but no dice.
Destinator 3 - [Dest3.1]
Destinator_3_-_[Dest3.1]
Destinator_3_[Dest3.1]
iGuidance and Routis can embed properly, now the question is which of the three is better? Someone replied to another posting, saying that iGuidance has more POIs, so how does it compare to D3?
DRWeside is offline   Reply With Quote
Old 12-11-2004, 01:24 PM   #17
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
Check out this thread:
http://www.mp3car.com/vbulletin/centrafuse/37777-destinator-centrifuse.html
There are lots of people who have gotten it to embed. Pretty sure you need to go download the latest version... They are discussing all this in the above thread...
david
veetid is offline   Reply With Quote
Old 12-12-2004, 06:16 AM   #18
Registered User
Skraggy_uk's Avatar
Skraggy_uk is on a distinguished road
Has anyone noticed that when using Ninja Monkeys D3 frontend, yes it can embed, but when you try to enter addresses, all sub windows open behind Centrafuse, rather than infront of Destinator. It does actually work properly if you disable "on Top" in Centrafuse, but then Destinator tries to load at it's default size, before embedding at it's correct size, and takes a second.
4x4 in a turbo stylee.
Skraggy_uk is offline   Reply With Quote
Old 12-12-2004, 01:35 PM   #19
VENDOR - Centrafuse
veetid's Avatar
Skraggy: I am checking into this ontop thing. When I set everything ontop, it has adverse effects relating to embedded applications. Currently if you are going to be embedding applications, the safest thing to do is disable my ontop feature, until I get it worked out... It only shows the fullscreen D3 for a second and its only the first time you click GPS...
david
Old 12-12-2004, 01:41 PM   #20
Registered User
Skraggy_uk's Avatar
Yep, noticed. That is what I have done.
It's weird while testing, as I'm using my desktop machine on high res, so Centrafuse sits in the top corner, with everything arround it, thats all.
Old 12-12-2004, 10:31 PM   #21
lerandell's Avatar
lerandell is on a distinguished road
Just an FYI.
I have tested Street Atlas 2005 and as you would assume works just as the tested 2004 does.
Street Atlas 2005 / DeLorme Street Atlas USA%trade 2005 - Map File 1
Randell Kelly
X-10 Media Remote
2003 Ford F-150 Harley Davidson Edition
SELECT * FROM users WHERE clue > 0;
0 rows returned
lerandell is offline   Reply With Quote
Old 12-14-2004, 01:46 PM   #22
roleary is on a distinguished road
lerandell - what OS is that on? what is your CF "on top" setting? i've been trying to embed SA 2005 with no luck so far.
thanks
2004 Toyota 4Runner Sport 4WD
Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
roleary is offline   Reply With Quote
Old 12-14-2004, 08:24 PM   #23
lerandell's Avatar
thanks
XP Pro SP2.
Below are screen shots of the config and the software embeded into Centrafuse.
I have had the on top setting on both and it still works the same.
Randell Kelly
X-10 Media Remote
0 rows returned
Old 12-14-2004, 10:15 PM   #24
VENDOR - Centrafuse
veetid's Avatar
lerandell: I see you actually put the trade symbol in the GPS window name. I never got it working that way, but I guess it does. how did you get the trade symbol there? that is what I added the %trade for, it is searched for and replaced with the trade symbol at runtime. If you can place trade symbols in the setup then I guess I didn't need to do it.
david
Old 12-14-2004, 10:40 PM   #25
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
thanks
I've had the same problem. I've got the window name correct (using the %trade) but when CF launches SA2005, it launches it in full screen. Also, when I exit SA, the Loading... screen is what CF displays and I have to use task manager to quit the program.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 12-14-2004, 11:08 PM   #26
lerandell's Avatar
Actually, I did put the %trade in there. I guess it converts it to the real deal when you go back into the setup after saving it.
try to copy and paist the line below into the setup and see if it works for you...
Randell Kelly
X-10 Media Remote
0 rows returned
Old 12-14-2004, 11:12 PM   #27
lerandell's Avatar
Thats weird.. I do see the SA2005 splash screen but it goes away. My GPS button never worked at all until I got the name right.
What OS and SP level are you running?
Randell Kelly
X-10 Media Remote
0 rows returned
Old 12-14-2004, 11:45 PM   #28
VENDOR - Centrafuse
veetid's Avatar
The loading screen staying loaded when it can't embed, which causes you to have to kill CENTRAFUSE was a bug on my part... Its been fixed already...
Now that I think about it, it will convert it for you once you get it into the program, so it is working properly and you should initially use the %trade and if you ever need to use an & for anything use %amp...
david
Old 12-15-2004, 12:39 AM   #29
Bugbyte's Avatar
Aha! I got it to work! Not sure exactly how but it embeds now. It may have had something to do with a stored route I had in it that changes the window name. I thought I cleared it out...but maybe not. In any case it's working now. Thanks for the help!
Want to:
-Where is the iBug?
Old 12-19-2004, 02:23 PM   #30
Well, for what it's worth, I still can't get SA 2005 to embed.
Win 2k, SP4
Emmbeding gps into frodo player window? jermkesler FrodoPlayer 3 08-15-2004 07:01 PM
Window Tint's effect on GPS signal MoFo GPS 3 07-19-2004 06:08 PM
Can the GPS mouse work in the back window? carpcnoobie GPS 7 05-10-2004 09:36 AM
IS this a bug? when in GPS the MP3 tage names never change bertybassett MediaCar 3 01-14-2004 02:56 PM
Delorme Streetatlas and the GPS Tab window size gfoulks GPS 0 08-28-2002 05:23 PM
