12-19-2004, 02:52 PM
#31
Admin. Don't bug or I'll byte.
Quote: Originally Posted by roleary
Well, for what it's worth, I still can't get SA 2005 to embed.
Win 2k, SP4
I'm running XP and like I said in my earlier post, I'm not exactly sure how I did it but I think it had to do with having a saved route. SA loaded up with that saved route everytime and the window name was different -even if I selected new route and quit. Until I selected new route and then hit the Save button it didn't work. After that, it did.
Good luck!
12-19-2004, 03:55 PM
#32
yeah, i've tried everything posted here and everywhere else. maybe its a win2k thing?
2004 Toyota 4Runner Sport 4WD
Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
01-14-2005, 04:56 AM
#33
New Destinator Window Name
whats the name for the latest update of destinator???
thanks
Nick
01-14-2005, 07:02 AM
#34
Same as before:
Destinator 3 - [Dest3.1]
01-14-2005, 09:17 AM
#35
Rub One Out
Well, theres one problem, Theres not enough room in centrafuse for Destinator, it embeds perfectly but centra fuse takes up to much space and some buttons overlap and u can barely see the favorites window.
CarPC status: iPod, 3,456,217 songs so **** you
01-14-2005, 10:57 AM
#36
Registered User
My God... I have same problem here. I am just about to peel the skin off my head but I do not get it working. Its the NMs Destinator 3 (1.1.3 b3) frontend which does not embed in Centrafuse 1.1b for me, despite the fact I have 10x checked GPC window title in config.xml. It IS SET to "Destinator 3 - [Dest3.1]" without the quotes. All the spaces checked, spelling checked, it still launches as separate APPS and it will not embed. *****.
HELP ME!!!!
01-14-2005, 11:10 AM
#37
Confusion Master
I have found in Mediacar I just put Destinator3 or is it destinator 3 and it embeds. When I tried the whole - [3.1] bit it wouldn't embed.
Will check when I get home tonight
*edit, just loaded it on the PC at work.
*destinator 3*
is what works in mediacar. NB the '*'s are specific to mediacar
01-14-2005, 11:18 AM
#38
Registered User
Nope, Destinator3 nor destinator 3 strings dont work for me either.
01-14-2005, 11:41 AM
#39
Rub One Out
retstart the program, turn it off then back on.
01-14-2005, 12:37 PM
#40
VENDOR - Centrafuse
Motoko: Click the title bar to toggle between fullscreen/non-fullscreen mode...
01-16-2005, 08:51 AM
#41
Registered User
No luck either.
01-20-2005, 12:28 AM
#42
I've had no luck either getting destinator 3 to embed in Centrafuse. I've just done a fresh install of everything including windows
EDIT: I fixed it. It looks like I had the wrong Destinator.exe selected. I needed the one in the Frontend_BETA3 folder, not the Destinator folder.
01-20-2005, 09:16 AM
#43
Registered User
Like this one?
<GPSPATH>C:\DestinatorApps\Frontend_BETA3\Destinat or3.exe</GPSPATH>
<GPSWINDOWNAME>Destinator 3 - [Dest3.1]</GPSWINDOWNAME>
It STILL DOES NOT embed for me from some f***ing reason.
01-20-2005, 01:58 PM
#44
Registered User
I have found using CF 1.1 beta, and Dest 1.1.3 hotfix 3 from ninja M, don't use Destinator 3 - [Dest3.1], it won't embed, just use Destinator 3 and it embeds fine.
4x4 in a turbo stylee.
01-22-2005, 11:01 PM
#45
I have Streets and trips and the window name is "Map - Microsoft Streets & Trips" how could i input this.
Carputer Status:
{▓__________} 10%
Its not original, its just something no one has failed yet!
| Thread Tools |
| Display Modes |
Linear Mode
