Microsoft Streets & Trips and Centrafuse
The issue with using Microsoft Streets& Trips in Centrafuse in my case had to do with the default installation path. I could not get CF to launch it with the "&" in the path. When installing, change the path to "C:\Program Files\Microsoft Streets and Trips"
If you already installed Streets & Trips in the default path, uninstall it and reinstall it in the new path, or you will end up with a duplicate installation and/or an error message when trying to launch.
If you are using USAPhotoMaps or another program that can call to S&T, or if you want to prepare it to be used with another program that calls S&T (just in case), convert your hard drive to NTFS, if it isn't already. Create "C:\Program Files\Microsoft Streets & Trips" and then use the LinkD tool from the Windows 2003 Resource Kit to create and link "C:\Program Files\Microsoft Streets and Trips" to "C:\Program Files\Microsoft Streets & Trips". Install as usual, and it will "appear" to be at both places, but is actually only on your hard drive once.
The application name you can use in CF is "Map", unless you call to a specific saved map in the parameters blank in the external application setup, then use the name of the saved file (usually without the extension).
I seem to have problems in CF with anything that contains an "&", so try your best to get around them.
Hope this helps!!!:
"Carvergence" Current Carputer Project(s):
- The ever-going quest for over-air FM radio receiver with acceptable reception
