Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF FAQs
Old 12-06-2004, 01:51 AM   #1
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
GPS window names
Here is a list of the current GPS window names that have worked. I have not personally tested all of these, so let me know if there are any corrections. Please post any knew applications and window names you get to work.
Application / Window Name
iGuidance / iGuidance
Routis / Routis
Street Atlas 2004 / DeLorme Street Atlas USA%trade 2004 - Map File 1
D3 Front End / Destinator 3 - [Dest3.1]
I have written a small application for searching for window names. Download here:
http://www.fluxmedia.net/downloads/windownames.zip
Run the application you are trying to embed and then this application. It will list the main window titles of all running processes. You will see some blank lines, but these are just processes without window titles. Find your application and copy/paste it into CENTRAFUSE. Some special characters will not properly work. Currently I have put measures in place for one. Let me know if I need to add more.
Replace
® / %trade
veetid is offline   Reply With Quote
Old 12-06-2004, 02:10 AM   #2
Dominik is on a distinguished road
When you say Destinator 3, are you referring to Ninja Monkey's front-end?
Dominik is offline   Reply With Quote
Old 12-06-2004, 02:11 AM   #3
VENDOR - Centrafuse
veetid's Avatar
Not sure... I will have to find out... Zorro gave me that window name and I am not sure what he was running..
david
Old 12-06-2004, 02:26 AM   #4
djmickyg's Avatar
djmickyg is on a distinguished road
Quote: Originally Posted by veetid
Destinator 3 / Destinator_3_ [Dest3.1]
im guessing it is.. it has 3.1 in it
djmickyg is offline   Reply With Quote
Old 12-06-2004, 02:33 AM   #5
Map Monkey Creator
Ninja Monkey's Avatar
Ninja Monkey is on a distinguished road
Not sure why there are slashes and underscores in there...
"Destinator 3 - [Dest3.1]"
works fine
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Ninja Monkey is offline   Reply With Quote
Old 12-06-2004, 03:37 AM   #6
Phone Control Moderator
zorro's Avatar
zorro is on a distinguished road
Yes, referring to Ninja Monkeys frontend.
My post was:
Quote:
Check your Window Title for D3 in CF. It has to be "Destinator_3_[Dest3.1]" (Spaces replaced with "_")
Skinning to go... VisualDesigner2!
zorro is offline   Reply With Quote
Old 12-06-2004, 01:50 PM   #7
Map Monkey Creator
My post was:
That's still wrong - you missed the hyphen
Old 12-06-2004, 01:54 PM   #8
VENDOR - Centrafuse
veetid's Avatar
NM: updated it... thanks..
david
Old 12-06-2004, 02:02 PM   #9
skydiver's Avatar
skydiver is on a distinguished road
what file in the destinator frontend are you pointing it at ?
im still having problems
and are you using NM new beta frontend?
and if i run that name program it comes up with "Destinator3" & "Dest3Client"
no _ or - anywhere
skydiver is offline   Reply With Quote
Old 12-06-2004, 02:21 PM   #10
skydiver's Avatar
hay got it but i cant move the map
if i move the map the screen doesnt refresh the pic untill i touch the zoom
and if you close centrafuse it doesnt kill destinator or the destclient so the next time you run it it deosnt work unless you kill them both in memory first
Old 12-06-2004, 03:29 PM   #11
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
When embedding... you need to input what the window is called of the app.. so if u check the 3.1 prev of D3 then it says Destinator 3 - [Dest3.1] on the taskbar.. this is the text you put in. It goes for all programs. Just start up the app you want to embed and see what the actual name is on the taskbar. Its easy !
cdr
CdRsKuLL is offline   Reply With Quote
Old 12-06-2004, 04:11 PM   #12
microbionic's Avatar
microbionic is on a distinguished road
yes, i am having the same problem, this happens to both 1.2 and 1.3 prev
CarPuter ProgressO meterO
[+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
visit me on the web at
http://gozips.uakron.edu/~cmk23/
microbionic is offline   Reply With Quote
Old 12-08-2004, 01:53 AM   #13
weekendowel's Avatar
weekendowel is on a distinguished road
Also have this problem, when I drive around the map wont refresh until I use the zoombar, or use some buttons on the destinator app. It works when I run it standalone or embedded in FP.
weekendowel is offline   Reply With Quote
Old 12-08-2004, 02:49 AM   #14
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
HELP! I can't seem to get iGuidance embedded in win98 install of centrafuse.
GizmoQ is offline   Reply With Quote
Old 12-08-2004, 03:21 AM   #15
VENDOR - Centrafuse
veetid's Avatar
GizmoQ: I haven't tried iGuidance in win98, but it's what I use on my XP machine. Did you set the window name to iGuidance? When loaded on win98 does the title of the application say someting different?
david
Emmbeding gps into frodo player window? jermkesler FrodoPlayer 3 08-15-2004 07:01 PM
Window Tint's effect on GPS signal MoFo GPS 3 07-19-2004 06:08 PM
Can the GPS mouse work in the back window? carpcnoobie GPS 7 05-10-2004 09:36 AM
IS this a bug? when in GPS the MP3 tage names never change bertybassett MediaCar 3 01-14-2004 02:56 PM
Delorme Streetatlas and the GPS Tab window size gfoulks GPS 0 08-28-2002 05:23 PM
