Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF FAQs
Old 07-20-2006, 06:29 PM   #1
AIR-V is on a distinguished road
Bad french translation with CF1.7 installation
Hello David,
I've notify a lot of bad translation section specialy for Phonecontrol setup....
It sound to be translated by a software. Can i help you in this ?
Regards
Air-V
AIR-V is offline   Reply With Quote
Old 07-20-2006, 08:11 PM   #2
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
The french has not been translated at all.
The only two languages that have been translated are German and English. The other 4 are there because you needed to be able to select them in order to tell the navigation software what language to use.
So I went ahead and added, copies of the English XML files, in all the languages...
I could really use a French, Spanish, Italian, and Portuguese of all the XML files.
If someone makes them, please email them to support@fluxmedia.net
david
veetid is offline   Reply With Quote
Old 07-21-2006, 09:09 PM   #3
daemon is on a distinguished road
David,
If you need a French transalation, then I can offer my help if needed. Let me know.
daemon is offline   Reply With Quote
Old 07-22-2006, 05:24 AM   #4
Phone Control Moderator
zorro's Avatar
zorro is on a distinguished road
Quote: Originally Posted by AIR-V
Hello David,
Regards
Air-V
Do you mean the PhoCo Wizard?
Actually, this has been done by a French guy (well, at least he told me he was ) but it's hard for me to rate translations since I don't speak the language.
Skinning to go... VisualDesigner2!
zorro is offline   Reply With Quote
Old 07-22-2006, 07:38 AM   #5
Hello Zorro,
Excatly, you're wizard is very bad translate...if you want i can help in this issue ?
Regards
AIR-V
Old 07-22-2006, 08:13 AM   #6
zorro's Avatar
Hello Zorro,
Regards
AIR-V
I would be glad if you could do that.
The language files are contained in the Localization directory under PhoneControl.NET. You can use eihter the Extended Configurator to edit the files or any XML editor (Notepad will do also).
I can offer you a free PhoCo license key for the job in case you'd like to run it standalone some day.
Old 07-22-2006, 02:01 PM   #7
coucouillu's Avatar
coucouillu is an unknown quantity at this point
I have noticed the bad translation too....I have begun to translate CF RC1 (90 finished). Hopping it will be needed...
coucouillu is offline   Reply With Quote
Old 07-22-2006, 03:44 PM   #8
VENDOR - Centrafuse
veetid's Avatar
That would be great, please email to support if you get it done...
thanks!
david
Old 07-23-2006, 12:31 PM   #9
coucouillu's Avatar
thanks!
david
OK.
Just got some problems for the translation...
French words are a bit longer than english, to faor some words, I was obliged to abbreviate:
save :sauvegarder (in french)--> sauv.
All words would be understandable for allfrenchies...
Old 07-24-2006, 04:33 AM   #10
OK.
Ouais ......bon boulot mon gars....
David is it possible to have autoresizable font for button or other ?
As Coucouillu said french words are sometime very long.. it could be understood by abreviation but when you drive it's more easy when word is complete .....if it's not possible, we need to learn SMS language.
Regards
Old 07-24-2006, 03:46 PM   #11
coucouillu's Avatar
I have some problem to translate these words/sentences :
MIXER
MAIN
PRESETS
MAIN
PLAY
TUNE -
FINETUNE -
FINETUNE +
TUNE +
TUNE
SCAN
RADIO PRESETS
LIVE
RANGE
TUNING STEPS
LINE IN DEVICES
TUNING RANGES
SELECT VFD DEVICE
SELECT VFD PORT
SELECT MAP LABEL SIZE
SELECT VISUAL NOTIFICATIONS
SELECT VOICE PROMPTS
ENTER VFD COLUMNS
ENTER VFD ROWS
ENTER CROSSFADE TIME
SELECT RADIO DEVICE
SELECT SATELLITE RADIO DEVICE
SELECT TUNING RANGE
SELECT LINE IN DEVICE
SELECT TUNING STEP
DEVICE
TUNING RANGE
LINE IN DEVICE
TUNING STEP
DEVICE
VFD
BAUD RATE
CROSS FADING
CONNECTION DEVICE
Voice Training Wizard
Microphone Training Wizard
VFD OUTPUT
CONFIGURE VFD OUTPUT
VFD OUTPUT DATA
ENTER CUSTOM VFD OUTPUT
SELECT VFD OUTPUT DATA
ARE YOU SURE YOU WANT TO REMOVE THIS VFD OUTPUT?
EQUALIZER
LEVELS
MAIN
AUDIO MIXER
PRE
FRONT
REAR
SUB
TREB
BASS
BAL
MIC
LINE
WAV
CD
CD IN
LINE IN
AUX
ARE YOU SURE YOU WANT TO REMOVE THIS TRIP LOCATION?
ENTER TRIP LOCATION NAME
Please help.
Some words like play, trebble, bass, etc...are also used in french for car audio...But i don't know what it would be in french...
Les frenchies, c est koi le mieux? trebble ou aigus, bass ou grave???
DAVID, what means exactly VFD in english. (moi j ai traduit par ecran LCD...un peu long je sais mais bon..d autres proposisions?)
Old 07-24-2006, 03:56 PM   #12
Salut Coucouillu,
Tu a du mal a les traduire ou du mal a mettre des abreviations comprehensible ???
Old 07-24-2006, 04:00 PM   #13
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
Vacuum Fluorescent Display (VFD)
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 07-25-2006, 07:39 AM   #14
SOS
SOS is on a distinguished road
Hi david, I would also like to update the Danish version now that we are in the final stage, and I can see that you removed the sticky language post.
I already have most of it ready from the previous updates I did including keyboard etc.
Should we mail them to you and then you will put them on the website?
As I asked previously, is there any plans on maybe making a mailinglist/forum post for us translaters where you could send out changes in the future, so we can keep them up to date?
/SOS/
XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
SOS is offline   Reply With Quote
Old 07-25-2006, 12:13 PM   #15
VENDOR - Centrafuse
veetid's Avatar
I will try to come up with something...
david
Auto power off accord General Hardware Discussion 29 08-15-2004 08:08 AM
French Military History smashr2k Off Topic 27 03-24-2003 09:44 PM
7" REDANT SCREENS (bad pixel) CHEAP dscustoms Classified Archive 20 06-26-2002 11:04 AM
