The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF FAQs
Thread Tools Display Modes
Old 10-12-2006, 12:55 AM   #16
My Photos: (0)
Yes there was a empty line after the last cam. But even after removing that and saving the file I still get "incorrect file format" with both your code and the file I had.
Cirion is offline   Reply With Quote
Sponsored Links
Old 10-12-2006, 01:01 AM   #17
My Photos: (0)
Within the Flux Media folder I find only 1 .log file, and that is called update.log.
I cant find a error.log anywhere.
Old 10-12-2006, 08:28 AM   #18
Vehicle: 03 Fiesta Zetec
My Photos: (0)
i got them imported via a .dat conversion but how do i show all the favs on that list on not just one at a time
would be great if you could add custom POI i think this would be a great advantage to use all
deathduck is offline   Reply With Quote
Old 11-29-2006, 10:14 AM   #19
Vehicle: 1986/chevy/PU crewcab
My Photos: (0)
same problem here.
I get the "wrong file format" error by using a .csv file (destinator format from poihandler.com). cf tries to import any other file like .inf or .bmp without the "wrong file format" error, but cant import because of corrupted file.
favorites are only working without import and copying a destinator .dat file into the common/favorites folder.
chevyunger is offline   Reply With Quote
Old 11-29-2006, 10:32 AM   #20
MySQL Error
veetid's Avatar
My Photos: (0)
Quote: Originally Posted by chevyunger View Post
same problem here.
I will check the format at poihandler.com, I used the format that mapmonkey was using...
I also could have an error in their somewhere... loading a INF shouls incorrect file format, makes me think some code is backwards somewhere...
will get it in the next update...
david
veetid is offline   Reply With Quote
Sponsored Links
Old 11-30-2006, 06:11 AM   #21
lazy_g's Avatar
Vehicle: Mazda 323F BG 1.6 16V
My Photos: (0)
does 4.2 have the alert functio on already?
Check out my website!!!
Check out my company site!!!
lazy_g is offline   Reply With Quote
Old 11-30-2006, 11:15 AM   #22
MySQL Error
veetid's Avatar
My Photos: (0)
It will alerts your favorites, but I'm working on managing it...
david
Old 01-13-2007, 01:13 PM   #23
My Photos: (1)
Impoting POIs via .dat in favorites folder is working. But i cant show the favorites on the map
btw: RC5
dudeness is offline   Reply With Quote
Old 01-23-2007, 05:04 AM   #24
My Photos: (0)
With Destinator6 Italy maps and Centarfuse RC5, import speedcamera don't work... *.csv
kawaninja72 is offline   Reply With Quote
Old 01-23-2007, 07:34 AM   #25
My Photos: (1)
It seems there are some bugs in the .csv import. But you can convert the .csv into .dat and put them in the common/favorite folder. So they are imported as favorites but you cant set a voice sound or something right now
Old 01-23-2007, 12:20 PM   #26
MySQL Error
veetid's Avatar
My Photos: (0)
what format is your CSV file? post a section of it... I might not support the format...
david
Old 01-24-2007, 02:13 AM   #27
My Photos: (0)
david
I don't know other than... I convert a TOM TOM POI's database with POIEDIT in CSV CommaSeparated for Destinator
Audio Alert is not actually supported in RC5? and visual alert?
Old 01-24-2007, 03:22 AM   #28
My Photos: (1)
Convert the TomTom files with poiedit in .dat and copy them into common/favorite folder. That works.
And yes, no audio und no viual alerts atm.
Another way to get warned from pois is, use freedrive in the background with imported speedcams and use the sound alerts. You only have to split your com port via xport.
Old 01-24-2007, 03:56 AM   #29
lazy_g's Avatar
My Photos: (0)
But freedrive uses destinator 3 and not 6...
And if you install freedrive, the destinator plugin of centrafuse will not work right?
Or has that changed?
Old 01-24-2007, 04:23 AM   #30
My Photos: (1)
The FreeDrive maps are in c:/DestinatorApps/blabla with Destinator 3.
The Centrafuse maps are in c:/Flux Media/Centrafuse with Destinator 6.
So i think they are using different Maps with a different Destinator.exe and it will work. I cant test it atm because my car is in hibernation.
Sponsored Links
vB code is On
Trackbacks are Off
Structure of speed camera file pijo1971 Map Monkey 2 10-27-2005 02:39 AM
Map Monkey v1.1.3 BETA 3 Ninja Monkey Map Monkey 72 03-29-2005 08:50 AM
please add a Cancel-button to "Add Speed camera" window AlCapone Map Monkey 7 02-26-2005 12:46 PM
GATSO Hunter v0.1 (Beta) - Standalone speed camera detection Engram Map Monkey 5 02-23-2005 05:36 PM
Speed Camera problem weekendowel Map Monkey 2 01-14-2005 03:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
