01-24-2007, 04:51 AM
#31
Vehicle: Mazda 323F BG 1.6 16V
But destinator 3 and 6 do not install the program in the same directory?
Because when i installed 3 a few months back, it overwrote 6 and the plugin did not start anymore...
01-24-2007, 06:56 AM
#32
Thats maybe when you use Destinator standalone.
Desti6 is integrated in CF Folder so both Destis should work parallel.
Edit: You was right. CF and FreeDrive wont work parallel. Every programm needs different destinator system files, so only one programm can be used. I had installed CF and Desti6 map, checken Navi, worked. Then i installed FD and Desti3 map, worked. But the FD installation has overwriten some needed desti files from CF. So CFs navi is not working anymore
We need a programm where we can save pois, which is scanning gps data and when we are on the position it makes an alert. Sounds easy but i found nothing like this
Alternative should work a FreeDrive with desti6 support work to
02-22-2007, 02:12 PM
#33
how do I apply a speed camera CSV file for mapmonkey?
I have tried to figure out how I can apply a speed camera CSV file for mapmonkey? I cannot find any import or other CSV files in my mapmonkey or freedrive folders.
02-28-2007, 09:41 AM
#34
i have the same trouble
i also tried gatsohunter, but it won't eat any of the 4 csv formats provided by poi-edit. same goes for mapmonkey, it won't import any csv file from poi-edit.
03-19-2007, 02:00 PM
#35
I still cannot import them!
i tryed converting tomtom files to .dat and tryed freedrive .csv...
It keeps on saying: "import failed, make sure the right map is loaded"
I use destinator 6 maps for PDA (Version 2006.Q1.4155 - map of NAVTEQ)
Or do i need different maps?
03-19-2007, 05:23 PM
#36
MySQL Error
you have to have the map loaded that the lat/long are in from the CSV...
so if the CSV is full of lat/longs from say Munich, then you have to have the German map loaded or it can't verify and get the points to save them...
you can go into planner mode to change maps and have it no auto switch back becuase of your GPS receiver...
david
03-20-2007, 02:02 AM
#37
well i have the Benelux map loaded and am importing the csv file for the benelux...
also tryed the planner mode, keeps on saying the same...
03-20-2007, 02:39 AM
#38
Vehicle: 1986/chevy/PU crewcab
I have the same problem, too.
I try poi´s from poihandler.com for germany and use a D3 german map and get the error message.
Now I will try to build a file with only berlin poi´s and use the cf berlin map.
I will give you the results later.
Matthias
03-20-2007, 11:26 AM
#39
rember centrafuse nav is made voor D6 and not D3...
But what you said, i trued... tonight i am going to try to cut the maps, so i only have the netherlands, then see what happens...
03-20-2007, 03:20 PM
#40
MySQL Error
I doubt it will work with D3 maps...
please post the file you are trying to import so I can see what is going on...
just a piece of it should be fine, like 20 rows or something....
david
03-21-2007, 02:10 AM
#41
This is the file i have been using...
Code:
3.71425,51.64220,GATSO:1@100
4.30440,51.30307,GATSO:2@100
4.33368,51.31319,GATSO:3@100
4.38876,52.05723,GATSO:4@100
4.40634,50.68469,GATSO:5@100
4.41306,50.69278,GATSO:6@100
4.41327,50.69343,GATSO:7@100
4.53661,51.91281,GATSO:8@100
4.53693,51.92264,GATSO:9@100
4.56303,51.88848,GATSO:10@100
4.57615,52.12242,GATSO:11@100
4.65023,51.78602,GATSO:12@100
4.83035,52.30691,GATSO:13@100
4.85104,52.33829,GATSO:14@100
4.88199,52.29621,GATSO:15@100
4.90119,52.29166,GATSO:16@100
4.92226,52.28718,GATSO:17@100
4.92404,52.33074,GATSO:18@100
4.96124,52.39652,GATSO:19@100
4.96129,52.30459,GATSO:20@100
03-22-2007, 04:43 PM
#42
MySQL Error
Code:
I will take a look...
david
03-25-2007, 05:00 AM
#43
MySQL Error
Code:
I tried to figure out what location this was for with google and virtual earth mapping the lat/long... I tried both as lat/long and long/lat, neither pull up a map...
what are the two numbers and how can I map them to see what location they are in?
david
03-26-2007, 03:11 AM
#44
Vehicle: '97 Toyota Supra TT
Looks like they're just off the East coast of Africa according to Google Maps.
The locations show up in Netherlands if reversed though...
51.64220,3.71425 - Google Maps
03-26-2007, 03:45 AM
#45
well actually they are in the netherlands, belgium and luxembourg...
If i import them in freedrive, they work fine...
| Thread Tools |
| Display Modes |
Linear Mode
