The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF FAQs
Thread Tools Display Modes
Old 12-26-2006, 04:18 PM   #1
My Photos: (5)
HOWTO: Install CF on Windows Vista RTM
I installed Windows Vista on my carputer and was having problems with the CF installer rolling back the install on me. I tracked the problem down to UAC and DEP killing the installer.
I thought I would post how I got things running for everyone.
1. Install .NET Framework 1.1 (Duh!).
2. Run the command prompt with elevated privliges (as administrator).
3. Enter the following command:
bcdedit.exe /set {current} nx AlwaysOff
4. Press Windows key + R to get run dialog box
5. Type "msconfig" (without qoutes) and press enter key.
6. Click the Tools tab.
7. Scroll towards the bottom of the list and choose Disable UAC.
8. Click the launch button. (You should see a command prompt confirming the command executed successfully.)
9. Reboot computer.
10. Run CF setup.
11. (Optional) If you wish to turn DEP back on, Run the command prompt and enter the following command:
bcdedit.exe /set {current} nx Optin
12. (Optional) If you wish to turn UAC back on, complete steps 5-8 but reverse step 7.
13. Reboot computer.
Hope this helps anyone else out there who is going to/was having problems.
JWise1203 is offline   Reply With Quote
Sponsored Links
Old 01-09-2007, 08:19 PM   #2
Redian's CarPC Specs
Redian's Avatar
Vehicle: 2004 Subaru Impreza WRX
My Photos: (0)
but why would you put vista on it?
who cares if its RTM, its still not compatible with so many programs.
such as installers =p, you are going to ahve a pain installing stuff for your carPC
2004 Subaru Impreza WRX CarPC Install
Install: 90%
"When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
Redian is offline   Reply With Quote
Old 02-13-2007, 04:19 AM   #3
Omen's Avatar
Vehicle: 1989 MR2 Mk 1
My Photos: (0)
Did you get CF Nvaigation to work?
I had the same problem and sorted out that - thanks for the info.
Question - Did you get CF's Nvaigation (Destinator) to work? I found that Destinator does not appear - just a blank black square box to the top right hand side.
Also, the Error log has enteries that shows CF looking for Locale info - perhaps via a windows dll within older versions of Windows??
It is a shame - I do like the new Sleep feature whereby it will standby for a while and then hibernate if it needs to...
Must agree with Redian thou - Vista RTM is still pretty crap when it comes to support for XP apps... :P
>>> MR2 AW11 / Karmeleon Project in AU >>> http://www.hybridproject.net
Omen is offline   Reply With Quote
Old 02-13-2007, 12:07 PM   #4
My Photos: (0)
Destinator doesn't works for me too.
stric is offline   Reply With Quote
Old 09-13-2007, 03:00 PM   #5
BrianFerry's Avatar
Vehicle: 2002/Subaru/Forester
My Photos: (8)
I've installed 1.2 on Vista and everything works great! No troubles at all.
Subaru Forester SG5 2.0 XT - 2002г
Made in Japan, Made for Japan.
http://board.forester-moscowclub.ru/...ead.php?t=2031
BrianFerry is offline   Reply With Quote
Old 02-08-2008, 07:08 AM   #6
My Photos: (0)
FAQ Centrafuse 1.47 under Vista on the Infill G4
Hi!
I just formatted my CarPC (Infill G4) as there was some stuff messed up due to playing around with settings and other software...
I decided to install Windows Vista, as the standby options are said to be better using Vista.
So far everything seems to work quite well, besides one thing: I can't hear the radio. Due to the changed architecture of Windows' volume mangement, I can't see the line in slider on the Windows mixer panel. In CF, the mixer shows a slider named Line, but when I increase volume there, the slider goes back to 0% immedeatly.
Maybe I should try to use the mixer application that came with the G4...
Any other suggestions?
Balu is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
How to install Media Center on Windows XP Home Defiler XP MCE 3 12-23-2007 07:39 AM
Windows XP LAN Boot install – no floppy or CD-ROM Zip-Lock Software & Software Development 25 08-16-2006 02:13 PM
windows vista walkthrough video fventura03 Off Topic 1 09-01-2005 10:02 PM
install windows 95 in 4.47mb churnopol Software & Software Development 3 09-30-2003 06:36 AM
windows install Stine161 Software & Software Development 2 09-21-2002 10:43 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
