f1anatic-
I looked into the Accessport devices, and while they do support the OBD-II, I can't find anything that says they use the ELM chip to do it. If this is the case, then no, we do not yet support that device. It's a similar device to the VAG-COM I believe, which has OBD-II but is implemented using a different processor. We currently only support the ELM chipsets. A good device we can recommend is the ElmScan 327, which supports all versions of OBD-II plus the new CANBUS protocol. It can be found here:
www.scantool.net
hth
reagan
