The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Thread Tools Display Modes
Old 04-04-2007, 12:58 PM   #1
smeesseman's CarPC Specs
smeesseman's Avatar
Vehicle: http://www.fluxmedia.net/
My Photos: (0)
Filesystem Sync Plugin
Hello all,
I have put up the graphical filesystem sync plugin on my server, available to use and test for anyone who is interested. This plugin will sync a remote windows share to a directory on your car pc, and graphically display status and progress, and also allows the user to stop Sync before it is complete... This is only done in English and Danish languages as of right now (anyone who can help with the other language translations please feel free ). Please note the following for usage:
1) You must configure the Settings, go to Settings -> SyncFS
2) "Remote Media Share' must be entered (ex. \\Server\Share)
3) "Local Media Path" must be entered (ex. c:\media)
4) "Character Patterns to Sync" must be entered (ex. mp3,mpg,mpeg,wav)
>> Sorry, as of right now all of these settings must be typed in from the OSK, I will add directory browsing later in development.
EDIT 6/1/2007 Directory Browsing and ListViews Added !!
EDIT 6/23/07 ListView added for character pattern list
5) A button must be set up for SyncFS. Go to Settings -> Button Layout and set the button for the SyncFS action.
6) You should be able to go to the Sync screen and sync right away. Please note that I have not tested the "AutoConnect" feature yet, so if you're not currently connected to a network I can't guarantee what will happen...
WORKLOG :
EDIT: 7/10/2007
Version 1.03, Compiled for CF 1.20 ...
1) As requested by Flux Media, LLC., the "SyncFS" plugin has been renamed to "FileSync" plugin. After installing this zip, you can move your old plugins/SyncFS/config.xml file into the new plugins/FileSync directory to preserve your settings.
EDIT: 6/23/2007
Version 1.02, Compiled for CF 1.14+ ...
1) Added listview selection mechanism for adding/removing "character patterns to sync" in setup screen.
2) Added code to constantly check for network connection during sync.
3) Removed "AutoDial" button from Settings.
EDIT: 6/1/2007 (Setup screen improvements)
Version 1.01, Compiled for CF 1.14 ...
1) Removed Nexus skin..
2) Added filesystem browser to select local paths in setup screen.
3) Added listview selection mechanism for adding/removing remote shares in setup screen.
4) Fixed issue with display name saving in setup screen (???).
EDIT: 5/14/2007
Version 1.0, Compiled for CF 1.12 ...
1) Improved user logon function for connection to remote share.
2) Added support for Nexus skin, simply using weather skin background.
3) Fixed network share logout function
4) Improved Progress Bar Incrementing algorithm.
5) Fixed issue with incorrect username/domain combinations being used in logon actions.
6) Fixed issue with corrupted config.xml file, CF not seeing SyncFS in Button Layout Settings.
EDIT: 4/14/2007
1) Added true character pattern searching for files to sync.
2) Added new setting for ignored character patterns (for overriding the character pattern to sync, ex. I want jpg files but I don't want jpg files that start with "AlbumArt")
3) User logon working
4) Added removal of folders on local filesystem when the corresponding remote folder is no longer in existence.
5) Added update support in code so that Settings do not get reset when updating to new version
6) Added autocheck for removal of files based on new entries for the ignored character patterns
7) Added option in Settings to not remove/delete anything from local filesystem, regardless if it was deleted of remote share.
8) Added dynamic creation/updating of config.xml file so as future updates will not erase currently saved syncfs user settings.
EDIT: 4/8/2007
1) Onyx Day Skin
2) File Removal on Sync
3) Added Debug Logging
4) Corrected text size problem
EDIT: 4/6/2007
1. Clears file list when successive syncs are performed
2. plugin icons
3. spinning sync wheel for use while sync in progress
TODO LIST
1. Add code to make sure media files being overwritten/deleted during sync are not currently in use.
2. Nicer, professional looking progress bars.
3. Graphical buttons to replace text buttons "Start", "Stop", and "Clear".
4. New graphics for sync wheel animation.
5. New icon (for displaying on CF button).
DOWNLOAD LINK
http://www.scottpm.com/cf/plugins/CF_FileSystemSync.zip
NOTE FOR USERS WHO ALREADY HAVE SYNCFS INSTALLED TO THE CF PLUGINS DIRECTORY:
You can extract this zip over the existing syncfs install, it will not erase your saved settings.
Please let me know of any feedback, troubles, bugs, requests, etc... This plugin is almost complete... Enjoy
- Scott
Last edited by smeesseman : 07-10-2007 at 03:11 PM. Reason: Updated new version log...
smeesseman is offline   Reply With Quote
Sponsored Links
Old 04-04-2007, 05:10 PM   #2
Raw Wave
justintime's Avatar
Vehicle: 2002 Honda CR-V
My Photos: (0)
IF FLuxmedia ever released a Photoshop template for their Onyx skin, then I am absolutely sure you would have people jumping to help you with a skin.
Sadly, I have not yet seen a template for Flux, and I get no joy out of skinning Onyx without proper and exact templates.
Great work on the plugin. I think Flux is working on something similar though, just a head's up!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 04-04-2007, 06:26 PM   #3
MySQL Error
veetid's Avatar
My Photos: (0)
This looks great... I hope to add it to the website downloads once tested...
I will look into creating a basic photoshop template with assets once I get 1.12 released...
It would be included in the SDK...
david
veetid is offline   Reply With Quote
Old 04-04-2007, 09:20 PM   #4
smeesseman's Avatar
My Photos: (0)
"In progress" screenshot from initial testing:
Old 04-08-2007, 08:07 AM   #5
smeesseman's Avatar
My Photos: (0)
New Update Available
Finished in this update:
1) Onyx Day Skin
Remaining Items :
1) Replace block progress bars with professional looking progress bar images
2) Redo sync icons
3) Test User Impersonation
4) Translate to languages other than English
5) Add option to sync from more than one remote folder (maybe)
6) Replace OSK in settings on path options with Explorer style input (i.e. like setting paths for the Media Library)
7) Code cleanup
Known Bugs:
1) Sync Icon on mainscreen Centrafuse button being resized/displaced in different Centrafuse resolutions.
2) Progress Bars overlaying text in Sync screen in different Centrafuse resolutions, on some systems.
Old 04-14-2007, 01:30 AM   #6
smeesseman's Avatar
My Photos: (0)
Remaining Items :
1) Redo syncfs graphics and icons
2) Translate to languages other than English/Danish (Danish not completely updated as of now)
3) Add option to sync from more than one remote folder (maybe)
4) Replace OSK in settings on path options with Explorer style input (i.e. like setting paths for the Media Library)
5) Code cleanup
Known Bugs:
Old 04-14-2007, 09:20 AM   #7
Raw Wave
justintime's Avatar
My Photos: (0)
I tried this version out, but after I hit START it just stays there and says 'computing tasks' with only about 2% on the progress bar.
2002 Honda CR-V
Old 04-14-2007, 10:42 PM   #8
smeesseman's Avatar
My Photos: (0)
That's pretty good with the 2% guess, that's what it is
Anyway, yeah, I am noticing some problems with the network logon, if you're using username and password to access the remote share. I put a new version up, try downloading that and try again. If problem persists, please let me know, it's a security problem with gaining access to the share...
You can also try manually to see if you can get access to the share from the command line like below:
Using username and password:
# net use \\<machinename>\<sharename> /User:<username> <password>
Without username and password:
If those are faling then it's definitely security issue...
Also if you use the Flux Forums, I keep the thread over there more up to date than this one (just an fyi).
Old 05-27-2007, 12:22 PM   #9
Vehicle: Opel Astra G 2001
My Photos: (1)
Hi, just downloaded the plugin and i like it
would it be possible to add another option?
when sync is complete, automaticly update the library...
if this would be possible that would be great!
Greetz
Dj NRG
Dj-[NRG] is offline   Reply With Quote
Old 05-27-2007, 01:49 PM   #10
Vehicle: '06 350z
My Photos: (0)
Greetz
Dj NRG
yea that would be VERY usefull
SKiTLz is offline   Reply With Quote
Sponsored Links
Old 05-27-2007, 03:39 PM   #11
Raw Wave
justintime's Avatar
My Photos: (0)
Dj NRG
That's not needed. CF automatically updates the library with anything new you copy to the music folders. It does it on the fly, behind the scenes.
2002 Honda CR-V
Old 05-27-2007, 03:41 PM   #12
My Photos: (1)
ow, nice
so the plugin is perfect as it is
Greetz
Dj NRG
Old 05-27-2007, 08:40 PM   #13
Vehicle: '06 350z
My Photos: (0)
Ok i found another problem.
You cannot rename the plugin title. I don't want my Button to read SYNCFS but even if you rename it. Save it. It never holds. I can rename any other plugin/module.
Old 05-28-2007, 01:31 PM   #14
MySQL Error
veetid's Avatar
My Photos: (0)
Try opening the language file and changing it, this might work... I have not tried, but just a suggestion...
david
Old 05-28-2007, 05:10 PM   #15
Vehicle: '06 350z
My Photos: (0)
david
That did the job. Thank you.
Sponsored Links
vB code is On
Trackbacks are Off
Graphical Filesystem Sync Plugin , Skin/Language help needed... smeesseman CF Plugins 0 03-31-2007 10:12 PM
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 12:32 PM
IRMAN plugin knyarko StreetDeck 3 01-05-2007 08:26 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 03:43 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 05:39 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
