The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Thread Tools Display Modes
Old 06-01-2007, 05:28 PM   #1
smeesseman's CarPC Specs
smeesseman's Avatar
Vehicle: http://www.fluxmedia.net/
My Photos: (0)
OBDII Plugin Changes/Fixes - BETA Testers Needed
Hello all,
I am working on the current OBDII plugin trying to resolve some of the past reported issues that some users have experienced. Please help fix the OBDII plugin by testing the updated obdii.dll file (posted below) and posting back any issues or suggestions.
EDIT: 6/9/2007 (Build 7, 9:30AM)
* Added support for handling "SEARCHING..." responses from ECU.
* Improved receiveComData() code
* PID 0x1C now only sent once, that's all that's needed.
* Screen labels now only update when screen is visible.
EDIT: 6/6/2007 (Build 6)
* Added timestamps to logging routine for easier debugging of user problems.
EDIT: 6/6/2007 (Build 5)
* Added another small fix to MIL processing code.
* Fixed logging routine that was broken in last build.
EDIT: 6/4/2007 #2 (Build 4)
* Added support for reading more than 2 message responses from 1 PID request.
* Added support for clearing DTC's. It really works now!
* Info box popup when clearing DTC's showing error or success
* Added processing support for PID Group 2, not used
* Added processing support for PID Group 3, not used
* Improved MIL handling
EDIT: 6/4/2007 (Build 3)
* Improved current code for reading MIL status
EDIT: 6/3/2007 (Build 2)
* First attempt to read multiple messages from multiple ECU's per PID (2 max)
- Tested and working in a '06 CTS with 2 ECU's
* More code cleanup
* Fixed issue in handling of ECU prompts
* Added more debug tracing for diagnosing user problems
* Added code to clear log file when back from hibernation
* Modified code to possibly ease burst CPU usage
6/1/2007 (Build 1)
* First updated release
* Major changes and cleanup for better performance, save copy of original obdii.dll before using
* Fixed issues in reading fragmented vehicle responses
* Fixed issue with some PID's incorrectly being reported as unsupported
EDIT: 6/9/2007 (Known Issues)
* Report of connection made but no readings
* Reports of MIL coming on/off intermittently when no DTC's are stored
* Reports that on AutoConnect, connection drops after 10-20 minutes
* Reports of plugin not working when coming out of hibernation
* Reports of sporradic serial port disconnect
* Reports of taking up to 2 minutes to populate all sensors with data
* Logs showing "SEARCHING..." respnse, not handled by application
The download is a ZIP file containing only the file obdii.dll. Place this file into the c:\Program Files\Centrafuse\Plugins\OBDII directory, make a backup of your original incase the updated version does not work for you.
NOTE: When dropping this in, be sure that if you want to keep the original DLL around, then you need to rename it to something like "obdii_v114.dll.xxx". If you use "obdii_v114.dll", then CF will load BOTH DLLs but only one will get the COM port. If the new one happens to be the one to get shafted, then it will not work. THANKS TO MIDIWALL for that tip...
-------- DOWNLOAD LINK ------------------------------------------------------------
http://www.scottpm.com/cf/plugins/obdii-dll.zip
Thanks...
smeesseman is offline   Reply With Quote
Sponsored Links
Old 06-03-2007, 07:11 PM   #2
smeesseman's Avatar
My Photos: (0)
Release 2 OBDII.dll with multi-message support. See Post #1 for details...
Old 06-04-2007, 08:13 AM   #3
smeesseman's Avatar
My Photos: (0)
Updated DLL - Release 3
Release 3 OBDII.dll with improved code to read MIL status. Anyone having trouble with MIL on when it shouldn't be please try this release... Any problems please post your Plugins/OBDII/log.txt file back to me... See Post #1 for details...
Old 06-08-2007, 04:57 PM   #4
f1anatic's CarPC Specs
Vehicle: 2005 Subaru Legacy GT
My Photos: (0)
Hey man, would this plugin allow me to use an Accessport Cable and directly access the ECU info without the actual need of an OBD-2 Scanner ? That is my dream...because I can do it with other software...but to make it work in Centrafuse, I need the scanner. When I bought and tested an ELM scanner - I found its performance completely unsatisfactory.
We are talking about a Subaru Legacy GT 2005 and my question addresses anyone with a Legacy 05-06; WRX and STi 2002-2006.
f1anatic is offline   Reply With Quote
Old 06-09-2007, 12:01 PM   #5
smeesseman's Avatar
My Photos: (0)
Sorry, no, you need an ELM based device to work with this plugin.
Old 06-09-2007, 12:02 PM   #6
smeesseman's Avatar
My Photos: (0)
Updated DLL - Build 7
Updated build, see post #1 for details. Added support for processing "SEARCHING..." response which seems to come from older model vehicles.
Old 06-11-2007, 12:42 PM   #7
My Photos: (2)
I would love the plug-in to support the br-3 device. A lot of people have this device...
Dwaine
2003 Black Impala
Dwaine is offline   Reply With Quote
Old 07-26-2007, 10:08 AM   #8
My Photos: (0)
I have a VW Jetta. I believe the controller I bought uses KWP-2000. Will Centrafuse's obdii software work with this?
If not, should i buy something else? If so, what?
Thanks in advance, this is a confusing subject for me.
mscappa is offline   Reply With Quote
Old 07-26-2007, 11:46 AM   #9
MySQL Error
veetid's Avatar
My Photos: (0)
you need an ELM based device...
david
veetid is offline   Reply With Quote
Old 07-28-2007, 01:26 AM   #10
mrbean_phillip's CarPC Specs
Vehicle: Ford F6 Tornado UTE
My Photos: (0)
Hello MSCAPPA,
KWP-2000 is one of the protocols of OBD-II standard, there is also CAN, ISO, PWM.....
As long as you buy an ELM-based device with KWP-2000 support for your vehicle, you will be ok.
mrbean_phillip is offline   Reply With Quote
Sponsored Links
Old 08-14-2007, 08:12 PM   #11
Lithoss's CarPC Specs
Vehicle: '06 Impreza WRX TR
My Photos: (0)
smeesseman and/or veetid, i just got my Elmscan ISO USB (elm323) today and hooked it up.
the problem is that the obdII plugin cannot connect to the ecu. it communicated back and forth a couple times (lights on the unit), but never connects and gives up after about 30 seconds.
however, the scantool program works just fine, no problems. i have the plugin set up exactly like the scantool program is set up, com4 baud 9600.
i even tried launching the scantool program from CF... works fine. no dice for the plugin though
my elmscan firmware is revision 2.0 if that helps... car is '06 subaru impreza
any ideas?
Lithoss is offline   Reply With Quote
Old 08-15-2007, 09:05 AM   #12
MySQL Error
veetid's Avatar
My Photos: (0)
any ideas?
make sure you do not have navigation set to COM4... You can also enable logging in OBDII and post the log for more information...
david
Old 08-15-2007, 09:10 AM   #13
My Photos: (0)
nav is COM3. i know its not a problem with the obdii interfering or getting interfered w/ because the scantool program works fine with everything else running.... but the plugin doesn't work no matter what.
I'll have the log either after lunch when i can run out to my car (i love my carpc muhaha) or after work.
Old 08-15-2007, 10:18 AM   #14
My Photos: (0)
Well, i got bored so here is the log. i also threw in the config.xml (rename to .txt so i could upload it) for good measure.
note that this is with the beta obdii.dll in this thread... before that i tried the dll that came with 2.0 of CF (not sure if they were the same one or not).. same result....
the log looks like it cant communicate past the device ID query....
File Type: txt config.txt (319 Bytes, 50 views)
Old 08-15-2007, 02:59 PM   #15
smeesseman's Avatar
My Photos: (0)
I will look into this when I get a chance. Your obdii is reporting an error when sending the ATSI command. I'll get back to you within a few days...
EDIT:
The Elm323 Spec states that the ATSI command must be sent for initialization. However in your case when we send this command we are receiving a bus init error. I will build you a test plugin that will bypass this init command to see what results you get, keep watching the thread I'll post a download link when I have time to recompile everything...
Sponsored Links
vB code is On
Trackbacks are Off
RR 04-08-05 .. BETA Base Plugin ... guino Road Runner 37 04-10-2005 11:39 PM
slide show plugin for winamp 3 needed babas151 Software & Software Development 0 02-01-2003 11:24 AM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 05:39 AM
winamp audio CD plugin needed babas151 Software & Software Development 4 05-14-2002 03:47 PM
Blackwind's keypad plugin v2.0 beta released Blackwind Software & Software Development 14 02-11-2001 03:54 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
