06-12-2007, 11:00 PM
#16
Vehicle: 2002 Nissan Altima
nice work Zorro!
Great idea for a plugin! will give this a try. thanks
06-13-2007, 12:53 AM
#17
Phone Control Moderator
Vehicle: 1998 Audi A3
Thanks. You're welcome.
Let me know if we can set up some interface for the "GO THERE" feature in your iGuidance plug-in.
Skinning to go... VisualDesigner2!
06-13-2007, 01:33 AM
#18
Vehicle: 1990 VW Corrado
I had two weird issues when I went to install it.
First, my CFIG plugin dissapeared. It was totally gone from CF. The icon was missing and the settings were missing. I had to uninstall both CFIG and the bluetooth control plugin to get cfig to reinstall. No matter what order I installed them, I couldnt have both and CFIG would always dissapear or not show up if bluetooth control was installed already.
Second, when I installed bluetooth control the window was higher than it should be. It covered part of the top menu bar and left a gap between the bottom menu bar and the bluetooth control area.
06-13-2007, 01:42 AM
#19
This is a known issue with the installer. I will fix that. Meanwhile, move the plugins you have installed to the PluginsInactive folder before you install this one, then after installing move them back.
What resolution are you running at?
06-13-2007, 02:26 AM
#20
Default res... 848x480?
06-13-2007, 02:31 AM
#21
Ok, never mind. Found the bug. Please re-download and try it again.
06-13-2007, 01:15 PM
#22
Will i need to do anything fancy with the installer? Or should it play nice with CFIG now, too?
06-13-2007, 01:19 PM
#23
Now it'll play nice with any of your plug-ins.
06-14-2007, 05:15 PM
#24
I tried the new release and got the same issue. It removes CFIG and wont allow me to have both plugins at the same time.
06-14-2007, 05:36 PM
#25
Vehicle: 2006 VW Passat 2.0t
Zoran, the bug definitely isn't fixed, just to confirm what sivart321 said. (unless the file that your first post links too is still an older version).
I tried your suggestion of manually moving the other plugs to the inactive folder then moving them back, but they are still "invisible" in CF as long as the BluetoothControl folder is in the Plugins folder (it's as if the other plugins don't exist at all, because not only do they not show up in the "Button Layout" list, but they also don't show up in the "Settings" list).
If you move the BluetoothControl folder out of the Plugins folder, all the other plugins re-appear in CF.
EDIT: Zoran, the problem has something to do with the CFplugin.dll file. I removed this from the BluetoothControl folder, and now all my plugins including BT can co-exist in CF peacefully.
06-14-2007, 05:40 PM
#26
Ok, thanks for that information. Strange is that I installed it myself and it worked. However, I will investigate further.
BTW: Is there anything mentioned in the Error.log of CF?
06-16-2007, 01:34 PM
#27
Vehicle: 2002 VW Jetta TDI - Rocketchipped - 185hp 314lbft
Same here....
06-16-2007, 01:41 PM
#28
Vehicle: 1999 Nissan 200sx S14a (280bhp)
will this be put up on the flux site?
06-16-2007, 02:03 PM
#29
MySQL Error
we have been very busy with building the XLE packages and then the server crashing... I plan to update all the current plugins with the new multi-language installers as well as host this Bluetooth Manager plugin very soon...
We hope to get the store running by tonight and then I will start on the plugins by Sunday...
david
06-17-2007, 01:36 AM
#30
You're right. I simply forgot to exculde that from the setup. Thank you for reminding me.
Update is online (see first post).
| Thread Tools |
| Display Modes |
Linear Mode
