Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 12-16-2007, 09:26 AM   #1
AzN_Tuan is an unknown quantity at this point
BMW E46 steering wheels (ibus) + centrafuse?
Hi, i'm looking a way to use my steering wheels on my 2000 E46 convertible. Actually I'm using RR with the Franck Touanen's RR Ibus pluggin and it work fine.
Where is my IBusComM.ini, normally I just have to change something inside it...
Code:
; =================================================================================================== ; IBUS Communication Manager. ; Configuration File. ; Franck Touanen, September 2003. ; ftouanen@yahoo.fr ; V1.0. ; =================================================================================================== ; --------------------------------------------------------------------------------------------------- ; ; General IBUSCOMM Setting ; ; --------------------------------------------------------------------------------------------------- [Settings] ; IBusComm can be totally invisible... SetVisible=false SetMinimized=False ;SetBackGround=True <-TODO ; COM port. 1 means COM1. 2 means COM2... ComPort=1 ; Contention Management ; ; IBusCOMM is able to manage contention problems by testing the bus line before sending ; a message to another device. ; ; 0 : By software (simple Interface 1/2) ; 1 : CTS/RTS (T.Woods or Melexis chips based interfaces). NOT CURRENTLY SUPPORTED. ; 2 : RING High (Simpe Interface 3)NOT CURRENTLY SUPPORTED. ; 3 : CTS High " NOT CURRENTLY SUPPORTED. ; 4 : CD High "NOT CURRENTLY SUPPORTED. ; 5 : DSR High "NOT CURRENTLY SUPPORTED. ; ; 0 mode is a pure software contention detection, working enough well if you already have ; a basic interface. ; 1 mode is a hardware contention management. ; 2 to 5 is a mix beetween hardware and software, more accurate than the 0 mode as it works at ; a bit resolution rather than character resolution. ; ContentionManagement=0 ; Switched Line ; ; The switched line can be used to activate a relay to switch on for example, the ; video line to the PC and the Navigation computer. ; ; 0 : No switched line used ; 1 : RTS line used ; 2 : DTR line used ; ; A ProcessEvent=Enable will set the line to HIGH. ; A ProcessEvent=Disable will set the line to LOW. ; Status is LOW by default. ; SwitchedLine=0 ; Time for shutdown in minutes ; This will trig the Shutdown event. IBusIdleTime=1000 ; Time between 2 IBus messages in miliseconds. ; Used if no contention detection hardware (mode 0) ; Usually set to 11 millisecs. InterMsgDelay=11 ; Activate LogMode. Reset each 500 events. LogMode=True ; Synchronize PC Clock and OBC Clock every 5 minutes ; Note : The PC is master and set the OBC clock.NOT CURRENTLY SUPPORTED. SYnchronizeClock=True ; Application to send event to (Windows Title) ; Note that application must be started before IBusComm in that case. ;AppCaptionSendEventTo="<* BeBoX Multimedia Player *>" ;AppCaptionSendEventTo="Sans titre - Bloc-notes" AppCaptionSendEventTo="RoadRunner" ;AppClassSendEventTo="Winamp" ; Force Application to ForeGround ID (only when using AppCaptionSendEventTo) ; Sometimes, it is necessary to force the application to foreground, as some windows application ; can keep focus. AppForceForeGround=BUT_TAPEDOLBY_PRESS ; The following parameter will make IBUSCOMM to set the focus to the application window each time ; a message is detected and a keyboard event has to be sent. AppForceForeGroundOnEvent=true ; Startup Process Events state when detecting message ; False by default (except system messages) ProcessEvents=true ; Urgent REBOOT message ID; ; When the system needs to be rebooted, specify the IBus ID here. ; The reboot action will BE the first action processed for the Event, so ; all others actions specified will be ignored. UrgentReboot=BUT_TAPEREV_HOLD [AppEventsDefine] PLAY=1 STOP=2 PAUSE=3 FAST_FORWARD=4 FAST_BACkWARD=5 NEXT_SONG=7 PREV_SONG=8 NEXT_ALBUM=9 PREV_ALBUM=10 ; --------------------------------------------------------------------------------------------------- ; ; Message definition syntax ; ; --------------------------------------------------------------------------------------------------- ; ; [ID:<Message ID>], MsgTemplate=<MsgTemplate>, Label=<Label>, Parse=<0/1> ; ; IBus Message ID : This ID is one the IBUS ID known by the IBUS COM module. ; ; MsgTemplate : The message template. wildcard "XX" can be used to replace ; : a specific character for variable content messages. ; : If wildcars are used, set the checksum byte to XX also. ; ; Message Label : A clear text for debuging session, or monitoring. ; ; Parse : If 0 (default), the message is not parsed by IBUSCOM (but can be sent) ; : If the message MsgTemplate is empty, Parse will be forced to 0. ; : If 1 the message is parsed and generate an event. ; ; System : If True, then the message is always processed, whatever is the state of ProcessEvents ; ; ; KeyBoardMap : If Set, Generate the keystroke sequence when ID recognized ; ; ProcessEvents : If set to "Disable", then IBuscomm will stop to send ReplyMsg, & Events + keystrokes ; : to the application Until a message with ProcessEvents "Enable"s again (flip/flop). ; : When IBusComm is launched, initial state of ProcessEvents is can be set in the main section. ; ; ReplyMsgID : If Set to a valid ID, will send the message <ID> on the bus ; : Message wil be sent only if no XX wildcards contained. ; ; ButtonState : If Set to true, the PRESSED state will be managed automatically. ; : The ReleaseID value must be set with a valid ID for this parameter. ; ; ButtonReleaseID : If set to a valid ID, will wait the msg ID before processing ; : This can be used especially when a button PRESS/HOLD state is needed. ; ; WMUserEvent : If a windows message has to be sent also. ; ; About Keystrokes definition (keyboardMap) : ; ; Each key is represented by one or more characters. ; To specify a single keyboard character, use the character itself. ; For example, to represent the letter A, use "A" for string. ; To represent more than one character, append each additional character to the one preceding it. ; To represent the letters A, B, and C, use "ABC" for string. : The plus sign (+), caret (^), percent sign (%), tilde (~), and parentheses ( ) have special ; meanings to SendKeys. ; To specify one of these characters, enclose it within braces ({}). ; For example, to specify the plus sign, use {+}. Brackets ([ ]) have no special meaning to SendKeys, ; but you must enclose them in braces. In other applications, brackets do have a special meaning that ; may be significant when dynamic data exchange (DDE) occurs. To specify brace characters, ; use {{} and {}}. ; To specify characters that aren't displayed when you press a key, such as ENTER or TAB, ; and keys that represent actions rather than characters, use the codes shown below: ; ; BACKSPACE {BACKSPACE}, {BS}, or {BKSP} BREAK {BREAK} ; CAPS LOCK {CAPSLOCK} DEL or DELETE {DELETE} or {DEL} ; DOWN ARROW {DOWN} END {END} ; ENTER {ENTER}or ~ ESC {ESC} ; HELP {HELP} HOME {HOME} ; INS or INSERT {INSERT} or {INS} LEFT ARROW {LEFT} ; NUM LOCK {NUMLOCK} PAGE DOWN {PGDN} ; PAGE UP {PGUP} PRINT SCREEN {PRTSC} ; RIGHT ARROW {RIGHT} SCROLL LOCK {SCROLLLOCK} ; TAB {TAB} UP ARROW {UP} ; F1 {F1} F2 {F2} ; F3 {F3} F4 {F4} ; F5 {F5} F6 {F6} ; F7 {F7} F8 {F8} ; F9 {F9} F10 {F10} ; F11 {F11} F12 {F12} ; F13 {F13} F14 {F14} ; F15 {F15} F16 {F16} ; ; To specify keys combined with any combination of the SHIFT, CTRL, and ALT keys, ; precede the key code with one or more of the following codes: ; ; SHIFT + CTRL ^ ALT % ; ; To specify that any combination of SHIFT, CTRL, and ALT should be held down while several other keys ; are pressed, enclose the code for those keys in parentheses. ; For example, to specify to hold down SHIFT while E and C are pressed, use "+(EC)". ; To specify to hold down SHIFT while E is pressed, followed by C without SHIFT, use "+EC". ; ; To specify repeating keys, use the form {key number}. You must put a space between key and number. ; For example, {LEFT 42} means press the LEFT ARROW key 42 times; {h 10} means press H 10 times. ; ; Note SendKeys can't send keystrokes to an application that is not designed to run in Microsoft Windows. ; Sendkeys also can't send the PRINT SCREEN key {PRTSC} to any application. ; ================================================================================= ; IBUS Messages ------------------------------------------------------------------- ; ================================================================================= ; --------------------------------------------------------------------------------- ; ID declaration ; Syntax is <Id name>=Id # (a byte from 0 to 255) ; --------------------------------------------------------------------------------- [IBusIdsDefine] ; - - - - - - - - - - - - - - - ; Message from 0 to 5 are reserved. IBUS_IDLE=0 IBUS_SHUTDOWN=1 RESERVED_2=2 RESERVED_3=3 RESERVED_4=4 RESERVED_5=5 ; - - - - - - - - - - - - - - - CD_POLLRESP=10 CD_RADSTARTPLAY_100=11 CD_RADSTARTPLAY_200=12 CD_RADSTARTPLAY_300=13 CD_RADSTARTPLAY_400=14 CD_RADSTARTPLAY_500=15 CD_RADSTARTPLAY_600=16 CD_NOTPLAY_100=17 ; - - - - - - - - - - - - - - - RAD_CDPOLL=20 RAD_CDSTOP=21 RAD_CDPLAY=22 RAD_CDSTAT=23 RAD_CDSCANF=24 RAD_CDSCANB=25 RAD_SETMENU=26 RAD_MENUTIMED=27 ; - - - - - - - - - - - - - - - BUT_NAVTKN_LEFT1=100 BUT_NAVTKN_LEFT2=101 BUT_NAVTKN_LEFT3=102 BUT_NAVTKN_LEFT4=103 BUT_NAVTKN_LEFT5=104 BUT_NAVTKN_LEFT6=105 BUT_NAVTKN_LEFT7=106 BUT_NAVTKN_RIGHT1=107 BUT_NAVTKN_RIGHT2=108 BUT_NAVTKN_RIGHT3=109 BUT_NAVTKN_RIGHT4=110 BUT_NAVTKN_RIGHT5=111 BUT_NAVTKN_RIGHT6=112 BUT_NAVTKN_RIGHT7=113 BUT_NAVTKN_PRES=114 BUT_NAVTKN_REL=115 ; - - - - - - - - - - - - - - - BUT_RADTKN_PRESS=120 BUT_RADTKN_REL=121 ; - - - - - - - - - - - - - - - BUT_MODE_PRESS=122 BUT_MODE_REL=123 ; - - - - - - - - - - - - - - - BUT_1_PRES=127 BUT_1_REL=128 BUT_1_HOLD=129 ; - - - - - - - - - - - - - - - BUT_2_PRES=130 BUT_2_HOLD=131 BUT_2_REL=132 ; - - - - - - - - - - - - - - - BUT_3_PRES=133 BUT_3_REL=134 BUT_3_HOLD=135 ; - - - - - - - - - - - - - - - BUT_4_PRES=136 BUT_4_REL=137 BUT_4_HOLD=138 ; - - - - - - - - - - - - - - - BUT_5_PRES=139 BUT_5_REL=140 BUT_5_HOLD=141 ; - - - - - - - - - - - - - - - BUT_6_PRES=142 BUT_6_REL=143 BUT_6_HOLD=144 ; - - - - - - - - - - - - - - - BUT_NEXT_PRES=145 BUT_PREV_PRES=146 BUT_MENU_PRES=147 ; - - - - - - - - - - - - - - - ;BUT_TAPEEJECT_PRESS=148 ;BUT_TAPEEJECT_REL=149 BUT_TAPEEJECT_HOLD=150 ; - - - - - - - - - - - - - - - BUT_TAPEDOLBY_PRESS=151 ;BUT_TAPEDOLBY_REL=152 ;BUT_TAPEDOLBY_HOLD=153 ; - - - - - - - - - - - - - - - ;BUT_TAPEREV_PRESS=154 ;BUT_TAPEREV_REL=155 BUT_TAPEREV_HOLD=156 ; - - - - - - - - - - - - - - - STW_NEXT_PRES=157 STW_PREV_PRES=158 STW_PLUS_PRES=159 STW_MINUS_PRES=160 STW_PHONE_PRES=161 STW_RT_PRES=162 ; - - - - - - - - - - - - - - - TEXT_MSGCD=200 ; --------------------------------------------------------------------------------- ; Messages to send when IBusComm starts up ; Syntaxe is : Message Id=True || False. ; False means do not send ; TO DO ! ; --------------------------------------------------------------------------------- [StartupIds] CD_ANNOUNCE=True ; --------------------------------------------------------------------------------- ; Internal Messages --------------------------------------------------------------- ; --------------------------------------------------------------------------------- [ID:IBUS_IDLE] Label="IBus Idle" System=True [ID:IBUS_SHUTDOWN] Label="IBus ShutDown" System=True KeyBoardMap="^{F12}" ; --------------------------------------------------------------------------------- ; CD Messages --------------------------------------------------------------------- ; --------------------------------------------------------------------------------- [ID:CD_POLLRESP] MsgTemplate="1804FF0200E1" Label="CD Poll Resp" [ID:CD_RADSTARTPLAY_100] MsgTemplate="180A68390209003F00010076" Label="CD Start Playing CD 01 00" [ID:CD_RADSTARTPLAY_200] MsgTemplate="180A68390209003F00020075" Label="CD Start Playing CD 02 00" [ID:CD_RADSTARTPLAY_300] MsgTemplate="180A68390209003F00030074" Label="CD Start Playing CD 03 00" [ID:CD_RADSTARTPLAY_400] MsgTemplate="180A68390209003F00040073" Label="CD Start Playing CD 04 00" [ID:CD_RADSTARTPLAY_500] MsgTemplate="180A68390209003F00050072" Label="CD Start Playing CD 05 00" [ID:CD_RADSTARTPLAY_600] MsgTemplate="180A68390209003F00060071" Label="CD Start Playing CD 06 00" [ID:CD_RADNOTPLAY_100] MsgTemplate= "180A68390002003F0001007F" Label="CD Not Playing CD 01 00" ; --------------------------------------------------------------------------------- ; RADIO Messages ------------------------------------------------------------------ ; --------------------------------------------------------------------------------- [ID:RAD_CDPOLL] MsgTemplate="6803180172" Label="Radio Polls CD" Parse=True System=True ReplyMsgID=CD_POLLRESP [ID:RAD_CDPLAY] MsgTemplate="6805183803004E" Label="Radio asks CD Play" Parse=True System=True ProcessEvents=Enable ReplyMsgID=CD_RADSTARTPLAY_100 KeyBoardMap="{F9}" [ID:RAD_CDSTOP] MsgTemplate="6805183801004C" Label="Radio asks CD Stop" Parse=True System=True ProcessEvents=Disable ReplyMsgID=CD_NOTPLAY_100 KeyBoardMap="{F10}" [ID:RAD_CDSTAT] MsgTemplate="6805183800004D" Label="Radio Asks CD Status" Parse=True System=True [ID:RAD_CDSCANF] MsgTemplate="68051838040148" Label="Radio Asks CD Scan Forward" Parse=True [ID:RAD_CDSCANB] MsgTemplate="68051838040049" Label="Radio Asks CD Scan Backward" Parse=True [ID:RAD_SETMENU] MsgTemplate="68043B460110" Label="Radio Sets Menu" Parse=True System=True ProcessEvents=Disable [ID:RAD_MENUTIMED] MsgTemplate="68043B460213" Label="Radio Sets Menu" Parse=True System=True ProcessEvents=Disable ; --------------------------------------------------------------------------------- ; When this message, that means the CD screen is displayed. [ID:TEXT_MSGCD] MsgTemplate="07202020202008434420" Label="Text Message CD" Parse=True System=True ProcessEvents=Enable ; ' ---------- Parsed Messages (generally, messages to be received and filtered)u ; ; ' Light Control ; ; ' D0 07 BF 5B 01 00 00 00 32 : Affichage Ecran de nuit ; ' D0 05 BF 5C 97 00 A1 : Allumage volant ; --------------------------------------------------------------------------------- ; Board Buttons Messages ---------------------------------------------------------- ; --------------------------------------------------------------------------------- [ID:BUT_MENU_PRES] MsgTemplate="F004FF483477" Label="MENU Press" Parse=True System=True ProcessEvents=Disable ; Nav Turnknob ; [ID:BUT_NAVTKN_LEFT1] MsgTemplate="F0043B490187" Label="Nav Knob Left (1)" Parse=True ;KeyBoardMap="{UP}" KeyBoardMap="NAVLEFT" [ID:BUT_NAVTKN_LEFT2] MsgTemplate="F0043B490284" Label="Nav Knob Left (2)" Parse=True KeyBoardMap="{UP 2}" [ID:BUT_NAVTKN_LEFT3] MsgTemplate="F0043B490385" Label="Nav Knob Left (3)" Parse=True KeyBoardMap="{PGUP}" [ID:BUT_NAVTKN_LEFT4] MsgTemplate="F0043B490482" Label="Nav Knob Left (4)" Parse=True KeyBoardMap="{PGUP 2}" [ID:BUT_NAVTKN_LEFT5] MsgTemplate="F0043B490583" Label="Nav Knob Left (5)" Parse=True KeyboardMap="{HOME}" [ID:BUT_NAVTKN_LEFT6] MsgTemplate="F0043B490680" Label="Nav Knob Left (6)" Parse=True KeyboardMap="{HOME}" [ID:BUT_NAVTKN_LEFT7] MsgTemplate="F0043B490781" Label="Nav Knob Left (7)" Parse=True KeyboardMap="{HOME}" [ID:BUT_NAVTKN_RIGHT1] MsgTemplate="F0043B498107" Label="Nav Knob Right (1)" Parse=True KeyboardMap="{DOWN}" [ID:BUT_NAVTKN_RIGHT2] MsgTemplate="F0043B498204" Label="Nav Knob Right (2)" Parse=True KeyboardMap="{DOWN 2}" [ID:BUT_NAVTKN_RIGHT3] MsgTemplate="F0043B498305" Label="Nav Knob Right (3)" Parse=True KeyboardMap="{PGDN}" [ID:BUT_NAVTKN_RIGHT4] MsgTemplate="F0043B498402" Label="Nav Knob Right (4)" Parse=True KeyboardMap="{PGDN 2}" [ID:BUT_NAVTKN_RIGHT5] MsgTemplate="F0043B498503" Label="Nav Knob Right (5)" Parse=True KeyboardMap="{END}" [ID:BUT_NAVTKN_RIGHT6] MsgTemplate="F0043B498600" Label="Nav Knob Right (6)" Parse=True KeyboardMap="{END}" [ID:BUT_NAVTKN_RIGHT7] MsgTemplate="F0043B498701" Label="Nav Knob Right (7)" Parse=True KeyboardMap="{END}" [ID:BUT_NAVTKN_PRES] MsgTemplate="F0043B480582" Label="Nav Knob Press" Parse=True KeyboardMap="{ENTER}" [ID:BUT_NAVTKN_REL] MsgTemplate="F0043B488502" Label="Nav Knob Release" Parse=True ; Radio Turnknob ; [ID:BUT_RADTKN_PRESS] MsgTemplate="F004684806D2" "Radio Knob Press" Parse=True [ID:BUT_RADTKN_REL] MsgTemplate="F00468488652" Label="Radio Knob Release" Parse=True [ID:BUT_MODE_PRESS] MsgTemplate="F004684823F7" Label="MODE Press" Parse=True [ID:BUT_MODE_REL] MsgTemplate="F0046848A377" Label="MODE Release" Parse=True ; Radio Buttons ; [ID:BUT_TP_PRES] MsgTemplate="F004684832E6" Label="TP Press" Parse=True [ID:BUT_TP_REL] MsgTemplate="F0046848B266" Label="TP Release" Parse=True [ID:BUT_TAPEEJECT_HOLD] MsgTemplate="F004684864B0" Label="Tape Eject Hold" KeyBoardMap="^{F10}" Parse=True System=True [ID:BUT_TAPEREV_HOLD] MsgTemplate="F00468485480" Label="Tape Reverse Hold" Parse=True [ID:BUT_TAPEDOLBY_PRESS] MsgTemplate="F004684833E7" Label="Dolby Press" Parse=True ; --- BUTTON 1 --- [ID:BUT_1_REL] MsgTemplate="F00468489145" Label="1 Release" Parse=True [ID:BUT_1_PRES] MsgTemplate="F004684811C5" Label="1 Press" Parse=True ReplyMsgId=CD_RADSTARTPLAY_100 ReleaseID=BUT_1_REL ButtonState=True KeyboardMap="{F1}" [ID:BUT_1_HOLD] MsgTemplate="F00468485185" Label="1 Hold" Parse=True ReplyMsgId=CD_RADSTARTPLAY_100 ReleaseID=BUT_1_REL KeyboardMap="+{F1}" ; --- BUTTON 2 --- [ID:BUT_2_REL] MsgTemplate="F00468488155" Label="2 Release" Parse=True [ID:BUT_2_PRES] MsgTemplate="F004684801D5" Label="2 Press" Parse=True ReplyMsgId=CD_RADSTARTPLAY_200 ReleaseID=BUT_2_REL ButtonState=True KeyboardMap="{F2}" [ID:BUT_2_HOLD] MsgTemplate="F00468484195" Label="2 Hold" Parse=True ReplyMsgId=CD_RADSTARTPLAY_200 ReleaseID=BUT_2_REL KeyboardMap="+{F2}" ; --- BUTTON 3 --- [ID:BUT_3_REL] MsgTemplate="F00468489246" Label="3 Release" Parse=True [ID:BUT_3_PRES] MsgTemplate="F004684812C6" Label="3 Press" Parse=True ReplyMsgId=CD_RADSTARTPLAY_300 ReleaseID=BUT_3_REL ButtonState=True KeyboardMap="{F3}" [ID:BUT_3_HOLD] MsgTemplate="F00468485286" Label="3 Hold" Parse=True ReplyMsgId=CD_RADSTARTPLAY_300 ReleaseID=BUT_3_REL KeyboardMap="%{F3}" ; --- BUTTON 4 --- [ID:BUT_4_REL] MsgTemplate="F00468488256" Label="4 Release" Parse=True [ID:BUT_4_PRES] MsgTemplate="F004684802D6" Label="4 Press" Parse=True ReplyMsgId=CD_RADSTARTPLAY_400 ReleaseID=BUT_4_REL ButtonState=True KeyboardMap="{F4}" [ID:BUT_4_HOLD] MsgTemplate="F00468484296" Label="4 Hold" Parse=True ReplyMsgId=CD_RADSTARTPLAY_400 ReleaseID=BUT_4_REL KeyboardMap="%{F4}" ; --- BUTTON 5 --- [ID:BUT_5_REL] MsgTemplate="F00468489347" Label="5 Release" Parse=True [ID:BUT_5_PRES] MsgTemplate="F004684813C7" Label="5 Press" Parse=True ReplyMsgId=CD_RADSTARTPLAY_500 ReleaseID=BUT_5_REL ButtonState=True KeyboardMap="{F5}" [ID:BUT_5_HOLD] MsgTemplate="F00468485387" Label="5 Hold" Parse=True ReplyMsgId=CD_RADSTARTPLAY_500 ReleaseID=BUT_5_REL KeyboardMap="%{F5}" ; --- BUTTON 6 --- [ID:BUT_6_REL] MsgTemplate="F00468488357" Label="6 Release" Parse=True [ID:BUT_6_PRES] MsgTemplate="F004684803D7" Label="6 Press" Parse=True ReplyMsgId=CD_RADSTARTPLAY_600 ReleaseID=BUT_6_REL ButtonState=True KeyboardMap="{F6}" [ID:BUT_6_HOLD] MsgTemplate="F00468484397" Label="6 Hold" Parse=True ReplyMsgId=CD_RADSTARTPLAY_600 ReleaseID=BUT_6_REL KeyboardMap="{%F6}" [ID:BUT_PREV_PRES] MsgTemplate="F004684810C4" Label="< Press" Parse=True ReplyMsgID=CD_RADSTARTPLAY_100 KeyboardMap="{F7}" [ID:BUT_NEXT_PRES] MsgTemplate="F004684800D4" Label="> Press" Parse=True ReplyMsgID=CD_RADSTARTPLAY_100 KeyboardMap="{F8}" ; --------------------------------------------------------------------------------- ; Steering Wheel ------------------------------------------------------------------ ; --------------------------------------------------------------------------------- ; [ID:STW_PREV_PRES] MsgTemplate="5004683B080F" Label="S. Wheel < Press" Parse=True KeyboardMap="RRPREV" [ID:STW_NEXT_PRES] MsgTemplate="5004683B0106" Label="S. Wheel > Press" Parse=True KeyboardMap="RRNEXT" [ID:STW_PLUS_PRES] MsgTemplate="50046832111F" Label="S. Wheel + Press" Parse=True KeyboardMap="VOL+" [ID:STW_MINUS_PRES] MsgTemplate="50046832101E" Label="S. Wheel - Press" Parse=True KeyboardMap="VOL-" [ID:STW_PHONE_PRES] MsgTemplate="5004C83B8027" Label="S. Wheel phone Press" Parse=True KeyboardMap="MUTE" [ID:STW_RT_PRES] MsgTemplate="5003C8019A" Label="S. Wheel - Press" Parse=True KeyboardMap="PLAY"
Thanks for your help.
AzN_Tuan is offline   Reply With Quote
Old 12-20-2007, 05:02 PM   #2
kelmk's Avatar
kelmk is an unknown quantity at this point
There is a Ibus plugin for CF which I use that works great. Do a search for it.
kelmk is offline   Reply With Quote
Old 12-20-2007, 09:28 PM   #3
Hi, I searched but I found nothing.. Can you give me a link to download it?
Old 12-20-2007, 11:37 PM   #4
kelmk's Avatar
I can't find it anymore either but I'll attach it here.
Old 12-21-2007, 08:37 AM   #5
In fact I use Resler's ibus, not car2pc interface. are you sure that we talk about the same module?
Old 12-29-2007, 09:12 AM   #6
house98 is an unknown quantity at this point
Any luck? I've got an '02 325Ci + centrafuse. I've been preparing, and am hoping to get out today and get it all working. I've got the USB V5 version of the connector, downloaded all the ibus software, and just preparing myself for the day. But have you had any luck specifically with Centrafuse? -- I know on their forum people are not having a great deal of luck.
house98 is offline   Reply With Quote
Old 12-29-2007, 01:42 PM   #7
I made an update about iBus, Centrafuse and some new findings at Flux's site... http://forums.fluxmedia.net/showthre...1596#post11596
BMW IBus control for Centrafuse? Hark Centrafuse 21 12-27-2008 02:04 PM
bmw ibus / stereo bmw e46 jonessc General Hardware Discussion 2 02-21-2008 09:25 AM
bmw ibus centrafuse gringo61 Centrafuse 1 05-13-2007 03:38 PM
Hi from a noob, and a couple of questions primarily re e46 bmw IBUS integration stuthemong Road Runner 3 02-06-2007 06:40 PM
Mac Mini powered ICE in BMW e46 with Steering Wheel Controls support Piperclub Show off your project 17 06-15-2005 04:50 AM
