I have created a small plugin to integrate Navigon Navigator2 into CF.
The sdk does not provide anything really usefull, and is therefore only in some degree used.
If a new version shows up, or someone finds some of the information available through the SDK usefull I will implement that.
But for now, please check that the window handling, navgation etc. is working.
Installation guide.
- Download & install the plugin as usual.
- Modify "path" in NaviConfig.xml found in the plugin directory. This must point to the directory of NR2.
- Modify NavigatoR.INI found in the installation directory of NavigatoR2. This should contain the following lines:
[Dimension]
Width = 653
Height = 344
I tested it today. maybe you should delete the right side of your plugin, so its more space for the map. Im using the Onyx WS Skin in 800x600 so the plugin looks totally **** :/
A plugin which just embed navigator in cf without this right side of yours would be perfect.
Hi Djerik,
would it be possible to compile your plugin for Centrafuse Version 2 or would you be so kind to provide the Source Code, so I can compile it by my self (of course for all others who are interested).
Hi Djerik,
are you still working on this Projekt, or did you gave it up?
I have made some changes in the .ini 's and skin.xml to have it embedded nice.
Would be nice if we can work on.
Cheers
VW_go_go
