The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Thread Tools Display Modes
Old 03-24-2008, 07:42 AM   #1
breast69au's CarPC Specs
Vehicle: Aus Spec MY98 Impreza WRX
My Photos: (0)
Plugin for external Apps
Is the a Plugin for external Apps. I am a subaru owner and want to run evoscan inside of centrafuse, because i have a older subaru that doesnt support obd2 only ssmi.
Is there one available at all and if there is where can i download it.
breast69au is offline   Reply With Quote
Sponsored Links
Old 03-24-2008, 09:37 AM   #2
My Photos: (0)
Just add it as an external App. From the Settings click the plus sign (+) and click on Application. Name the app and pick the exe for the Evoscan app for the Application Location. If you want it to be inside the CF window (i.e. embedded) so you get the CF frame around it, just put in the Window Name.
Once you are done, make a button for it by click+hold one of the buttons and it will prompt you to pick an application to replace. Pick the Evoscan app that you just made from the list and thats it. You have yourself a external app inside CF without any need for a plugin...
nintwala is offline   Reply With Quote
Old 04-01-2008, 03:16 PM   #3
My Photos: (0)
How do I figure out the window name for different programs I want to embed in CF?
popztarr is offline   Reply With Quote
Old 04-02-2008, 01:37 AM   #4
smeesseman's CarPC Specs
smeesseman's Avatar
Vehicle: http://www.fluxmedia.net/
My Photos: (0)
Usually it is the application name, minues the extension, but you can tell for sure by using a tool such as Winspector Spy.
smeesseman is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
DJiK's Jump-to-File External Control Plugin, v0.99b [BETA] DJiK RR Plugins 119 12-25-2007 02:20 PM
pc reboot on sd startup duanes7 StreetDeck 3 12-14-2007 08:55 AM
IRMAN plugin knyarko StreetDeck 3 01-05-2007 08:26 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 03:43 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 05:39 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
