Is the a Plugin for external Apps. I am a subaru owner and want to run evoscan inside of centrafuse, because i have a older subaru that doesnt support obd2 only ssmi.
Is there one available at all and if there is where can i download it.
Just add it as an external App. From the Settings click the plus sign (+) and click on Application. Name the app and pick the exe for the Evoscan app for the Application Location. If you want it to be inside the CF window (i.e. embedded) so you get the CF frame around it, just put in the Window Name.
Once you are done, make a button for it by click+hold one of the buttons and it will prompt you to pick an application to replace. Pick the Evoscan app that you just made from the list and thats it. You have yourself a external app inside CF without any need for a plugin...
How do I figure out the window name for different programs I want to embed in CF?
