Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 11-03-2008, 01:39 AM   #31
Dignen is an unknown quantity at this point
helper DL not working
can someone host the original Helper file. it has been corrupt every time i have downloaded it. thanks.
EDIT
Finally got it to work after 10 downloads...
Dignen is offline   Reply With Quote
Old 11-03-2008, 01:50 AM   #32
Quote: Originally Posted by f1racr View Post
I've got an odd issue with my install. I had the same issue when I first installed on one of my car PC's, but then it seemed to go away and I wasn't sure why but it was working so I didn't bother to check further.
Now I've attempted an install on my second car PC and I've got the same error but it won't go away....... any ideas ???
When I try to start the Garminlauncher.exe application. When I enable debug it says waiting for app to initialize and then about 2 seconds later this comes up.
I've checked the registry and the pathing is correct so not sure why this error is showing up. Any tips on how to diagnose would be helpful.
I get this same error. Everything works correctly but the error pops up everytime and I just click OK. Really annoying.
EDIT
FIXED!! Turns out that i have had the A: drive enabled since i built the computer but there is no actual drive. I disabled it under device manager and this did wonders for my system. Garmin Mobile PC runs MUCH faster, Centrafuse runs MUCH faster and no more error!!! But my next question remains..
Also, is there a way to make the Garmin window locked in place so I dont drag it around the screen?
Old 11-03-2008, 05:11 AM   #33
Frankino's Avatar
Frankino is on a distinguished road
the window name is "Garmin Mobile PC", for sure
double check if you've run boht .reg files with the right path to the executable in the files.. I don't know
I had this error and now it's gone but I don't remember the cause sorry
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Frankino is offline   Reply With Quote
Old 11-03-2008, 07:07 AM   #34
Frankino, I tried your setup with the ZWKB. Only problem i see is that it is always running in the background so if I ever touch the top part of the screen it opens the keyboard. Like when I hit Library or Playlists.
Old 11-03-2008, 07:13 AM   #35
Assault is an unknown quantity at this point
Hey guys, dont remove the \\ out of the path settings. i.e. it has to be C:\\GarminMobilePC\\Que.exe and not C:\GarminMobilePC\Que.exe
If you do remove a backslash leaving only one, you will get that error posted earlier.
Assault is offline   Reply With Quote
Old 11-03-2008, 07:37 AM   #36
Frankino's Avatar
I know, I plan to modify my "launck zwkb" tool to perform the task only if GMPC windows is in foreground. will take a look asap
I admit I'm not too active on GMPC tweaking right now, I switched to sygic and I LOVE it..
EDIT
just spent half an hour trying to get it work, it seems autoit can't find GMPC window correctly, I think I'm doing something wrong because it can resize and refocus it fine so.. I'll keep trying
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
Old 11-03-2008, 12:50 PM   #37
kmp14 is an unknown quantity at this point
Same thing was happening to me. Here is how you fix it - DO NOT enter the application window name (Garmin Mobile PC) when you add it to CF. Just add the path to the garminlauncher.exe. When you add an external app to CF and include the window name, CF absorbs the app so that it is not visible as a running EXE, so the utility can't find it.
Let us know if that fixes it! It did for me.
kmp14 is offline   Reply With Quote
Old 11-24-2008, 02:20 AM   #38
f1racr is an unknown quantity at this point
Nope didn't help. When I get that error message and click OK nothing happens.
I'm sure the issue is related to the fact that AutoIT script is looking for a application window name of Garmin Mobile PC, but with version 5.50 it seems there isn't a window title. If you use the tool for showing the window title then fire up GMPC it just shows a blank box with an OK button............
I wish I had the stuff to sort it out as it drives me bloody nuts not having this sorted properly it's been going on and on and on and it's still not solved
Why can't Garmin just bloody give us an SDK so someone can make a proper plugin.........
f1racr is offline   Reply With Quote
Old 11-24-2008, 03:05 AM   #39
Frankino's Avatar
I assure you the window name is "Garmin Mobile PC", it shows itself for several seconds during the application startup then it hides, I can see it if I maximize the application right after it starts
triple check the values in the .reg files (paths, window name, etc) and make sure to include the two .reg files in the registry doubleclicking on them
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
Old 11-24-2008, 04:45 AM   #40
F1 - PM me your .reg files and I'll check if its set up right.
the Window name is definately "Garmin Mobile PC" its just the "Show Title App" comes up with nothing. I use an App called "Hide Window Hotkey" to find out window names and it definately finds the GMPC name as "Garmin Mobile PC" when Show Title App finds nothing.
Old 11-24-2008, 01:44 PM   #41
OK will do.
I've tried all sorts of different combinations of reg files and get the same result with them all. tried the default one and just changed the path statement and it's still no go......... My GTR works with the same setup, but that was 5.3, then I upgraded to 5.5 and it still worked, the others were 5.5 before I tried to install this...... not sure if it's related in some way.
Task Manager says it's Garmin Mobile PC so I figured it was named correctly, but wasn't sure how the AutoIT script did it's thing.
Assault, will PM you my reg keys.
Old 12-01-2008, 09:26 AM   #42
Wow, I am suprised since I was having the exact same problems, spent LOTS of time on it, and finally removing the the app title from Centrafuse when I added it as an external solved the problem.
Also, I figured it out because, when I ran Garmin Mobile PC outside of CF, I could see it running in the task manager. When I ran it embedded in CF with the app title specified, I could not, so neither could the AutoIT script. Once I removed the app title in CF, I could see it in the task manager, and everything work as it should. When running GMPC launched from CF, see if you can see it in the task manager. If you can't, it must be that CF is absorbing it.
Old 12-01-2008, 01:30 PM   #43
It won't even launch properly outside of Centrafuse......... so it's definately not related to that at this point.
It's so frustrating.......
I've PM'ed my reg file to Assault, so hopefully he'll spot some rookie mistake and it will resolve it, but I don't think I've made any mistakes
Old 12-03-2008, 04:17 PM   #44
JCGBIKE is an unknown quantity at this point
I had the same problem with the same error message.
How to resolve this problem.
thank you
JCGBIKE is offline   Reply With Quote
Old 12-04-2008, 12:30 PM   #45
twingos is an unknown quantity at this point
hi
what an one like this would be like igo8 skin?
twingos is offline   Reply With Quote
Centrafuse 2.0 RC3 smeesseman Centrafuse 0 05-21-2008 10:29 PM
