Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 02-08-2009, 01:12 PM   #61
f1racr is an unknown quantity at this point
Just right click on the image and save as..........
f1racr is offline   Reply With Quote
Old 02-08-2009, 05:58 PM   #62
adriank99 is an unknown quantity at this point
yes, just right click image -> save picture and replace the file keyboardletters.gif
adriank99 is offline   Reply With Quote
Old 02-20-2009, 04:13 AM   #63
Does anyone know if it's possible to start GMPC with a switch to stop having to always agree to the notice at the beginning ?
Old 03-14-2009, 02:53 AM   #64
plbyrd is an unknown quantity at this point
Is there a single, succinct post, FAQ or site that describes exactly how to install and set this up including all of the various downloads and such? Also, I am using 1280x768 resolution due to quirks with my display. How is that going to affect these efforts?
plbyrd is offline   Reply With Quote
Old 04-24-2009, 04:21 PM   #65
lkarmi is an unknown quantity at this point
ok i've succeeded integrating it but now the CF cant open it it tries and it just close the page i opened it with... and it shows that it waits for the app to load or something and when i press on the button it uploading the IGO and then exiting the window back to the menu... all the time. please help me
lkarmi is offline   Reply With Quote
Old 04-30-2009, 11:40 AM   #66
anuchit is an unknown quantity at this point
hi...
I used Comfort key + garmin cf helper
It best way . When U use other language of gmpc. U can use Comfort key for your region and lanuage
Comfort key..can change theme for your resolution..transparents..delay appear...etc..
I lock float button on bar cf and transparent it.
I like its ...
I'm not good Eng. Excuse me
Search............. Comfort_Keys_Pro_3.2.1.2.
anuchit is offline   Reply With Quote
Old 04-30-2009, 11:54 AM   #67
I have found a solution that is effective for me, but it requires hardware. I am using the Griffin Powermate (best part of the whole system, IMHO) and I have set the hold-click to Alt-Tab for Centrafuse and GMPC. This allows GMPC to be full screen all the time and simply holding the knob down for three seconds sends me back and forth between GMPC and Centrafuse.
I also have Centrafuse set to launch GMPC and the Powermate software at launch so I know that this arrangement is always there.
Old 04-30-2009, 12:08 PM   #68
skeet2331's Avatar
skeet2331 is on a distinguished road
That's not a bad solution. I like others use the zero weight keyboard. It is an ok solution but not ideal. I'm hoping in time garmin will allow us to embed it properly into centrafuse.
Lilliput EBY701, M2-ATX, Intel 1.8 GHz, 1GB Ram, 160 GB 2.5 hard drive, Centrafuse, Garmin Mobile PC, GlobalSat BU-353.
My 2000 Saturn SL2 Worklog
skeet2331 is offline   Reply With Quote
Old 04-30-2009, 02:07 PM   #69
I also use ZWK. I like it better than the onscreen keyboard for Windows 7 as it doesn't resize the windows, it simply sits on top. The OSK with Win7 is way better than any previous attempt by Microsoft. Hell, everything having to do with touch is better in Windows 7.
Old 05-03-2009, 08:13 PM   #70
eyalamram is an unknown quantity at this point
hi to all
eyalamram is offline   Reply With Quote
Old 07-13-2009, 10:14 AM   #71
vamis is an unknown quantity at this point
Just tried helper app. Everything went fine except the keyboard.
It shows up nicely, but at the moment if I try to press anywhere in the keyboard area I get AutoIt Error
Line -1:
Error: Array variable has incorrect number of subscripts or subscript dimension range exceeded
What to check
vamis is offline   Reply With Quote
Old 10-02-2009, 07:32 AM   #72
brianteel is an unknown quantity at this point
is there any where else to dl this. link does not work
brianteel is offline   Reply With Quote
Old 10-02-2009, 05:25 PM   #73
Assault is an unknown quantity at this point
have a look for Garmin Rebellium OSK plugin on the flux media forums
Assault is offline   Reply With Quote
Centrafuse 2.0 RC3 smeesseman Centrafuse 0 05-21-2008 10:29 PM
