Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 02-22-2009, 07:19 PM   #1
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
CFTrafficcams - Status - Beta Release 16/03/2009
See the traffic flow cameras in your area.
v1.1 Beta Release 16/03/2009
Download from my website
Extract to CF plugins folder and read, readme.txt
Current standalone version
Map of where cameras are (only the ones where I have GPS coords), your area not there? then get me the coords if the camera is already in the database or if cameras in your area not in database get me the camera urls and GPS coords.
Clicking on the icon will give you the Camera ID and it's GPS coords. (trying to add location as well)
Screenshot
Main Screen
Camera Search Screen & Database select screen
Preset screen & Large display screen
GoogleMap screen
Enforcer is offline   Reply With Quote
Old 02-22-2009, 07:20 PM   #2
Confusion Master
Enforcer's Avatar
Q. Why should I use this plugin version in CF as opposed to the Standalone version?
A. There is no reason why you shouldn't use the standalone version, however this version will have better intergration with your CentraFuse
Q. I have put my country code in the ini but there is no cameras in the list?
A. The initial download only comes with the UK database, after you have entered your country code in the ini, run the program and leave it running for at least 5 mins. If the skin you are using has the 'New Database' indicator on it, it should light up when a new database is downloaded, click on this indicator and it will load the new database. If the skin has no indicator, stop and restart the program. If the database is still not there it could be that my website is down, you are behind a firewall which has blocked the download or the program itself was updating.
Q. Why is my country not supported?
A. I have collected as many countries as I can where I can, either from searching or other users providing links, if you country is not supported it is either I haven't found a website with the cameras or if I have they are moving images which TC does not support at this time. Bear in mind if the site is not in English I may have trouble understanding it.
Q. Why is my State/Town/City not supported?
A. I have collected as many countries as I can where I can, either from searching or other users providing links, if your state/town/city is not supported it is either I haven't found a website with the cameras or if I have they are moving images which TC does not support at this time.
Q. I have found a site for my Country/State/Town/City what do I need to do to get these added to the databases?
A. If it is a new Country then firstly provide me with a link, if it is not in English you may have to harvest the info yourself. Please provide the info in the following format
<url of camera>
<Location of camera including town/state>
<lat>
<lon>
NB the lat and lon need to be in decimal format and not Degrees Minutes, seconds. ie (34.4567,-23,9465)
Q. How can I download this wonderful creation?
A. Register on my forum at www.en4cer.co.uk/forum , when activated go to the downloads section.
Q. I have registered on your site but am still not activated, why?
A. I do not monitor the forum registrations 24/7 so it could take hours or possibly a day or two before I can activate you. If I am going away I will normally put this info into the news section of the forum. If however after a few days of registering you have not been activated then contact me via PM here. Using the same username as you do on here will help you get activated quicker.
Q. Does this application only work with CentraFuse?
A. Yes, this is a dedicated CentraFuse Plugin, However there is a standalone version available.
Q. How do I change the size?
A. The plugin will run at the same size as CentraFuse.
Q. Can I use CFVisualDesigner to edit the skin?
A. Yes.
Q. How do I embed this is my skin?
A. Follow the standard instructions for installing plugins in CentraFuse
Q. Would someone care to send me this?
A. The Terms And Conditions expressly forbid the distribution of this program, please register on my forum to get your copy.
Q. Does this show redlight and speed cameras?
A. No, this is only for traffic movement cameras, for speed cameras a red light cameras try Gatso Hunter.
Q. Is the video live or updated? or mix?
A. Currently this is only static image cameras, these get updated by the websites anything from every second to some which update every 20mins.
Q. Does your plugin accepts video traffic cams?
A. Not at present, this maybe something for the future, but at the moment this would probably take too much bandwith.
Q. I would love to be able to add some custom images to the traffic cam app?
A. At present this is not possible, but it is something I will look into
Q. How do you pull coordinates for traffic cams?
A. This can be very laborious.
One method is to use google earth combined with the website the cameras are on and the Traffic Camera pictures.
You will need to look at roughtly where they say it is (there is normally a map of sorts), look at the picture, zoom in on google earth until you can marry the picture image with what is seen in google earth and then read the co-ordinates. It also helps if you are fairly familiar with the area/country.
Sometimes you are lucky and if you look at the source of the page with the map, it will sometimes provide the GPS coords in their somewhere, these can then just be copy and pasted into notepad.
Q. Why do you need the GPS coords with the cameras?
A. Two fold, one is to be able to see on a map where a camera is in the serach screen, help you decide if it is somewhere you go. And secondly I hope to add the ability to show cameras based on the position, so as you move it will always show the cameras nearest to you.
Q. What is the current database version for my country? (Cameras with coords / total cameras)
A.
UK Database version=UK007 ( 1273 / 1612) 79%
US Database version=US014 (1192 / 4985) 24%
Austria Database Version=AT001
Australia Database Version=AU002
Belgium Database Version=BE001
Brazil Database Version=BR001
Canada Database Version=CA004
Germany Database Version=DE003
Denmark Database Version=DK002
Estonia Database Version=EE001
Spain Database Version=ES006
Finland Database Version=FI001
France Database Version=FR001
Croatia Database Version=HR002
Hungary Database Version=HU002
Ireland Database Version=IE003
Iceland Database Version=IS001
Italy Database Version=IT001
Luxemburg Database Version=LU002
Malaysia Database Version=MY001
Nederlands Database Version=NL001
New Zealand Database Version=NZ001
Norway Database Version=NO001
Poland Database Version=PL002
Portugal Database Version=PT001
Russia Database Version=RU001
Singapore Database Version=SG002
Slovenia Database Version=SI001
South Korea Database Version=KR001
Sweden Database Version=SE002
Venezuela Database Version=VE001
Old 03-16-2009, 09:53 PM   #3
Confusion Master
Enforcer's Avatar
Bump for Beta (v1.1) release
RRGrid - A TS Friendly Game/Puzzle Status: Released 27/11/08 Enforcer RR Released Plugins 27 10-29-2009 03:27 AM
Dial up status / Internet Connection Settings Digital Mod sharpmat007 DigitalMods (Scripts / API) 11 07-31-2008 08:47 AM
NMC 07 development status netsuo NeoCar Media Center 15 11-03-2004 04:18 AM
