Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 10-09-2009, 12:19 AM   #1
LeroyR is an unknown quantity at this point
Plugin for a DIY 4x20 or 2x20 LCD monitor?
First of all sorry for my English they aren't very well, I'm from Greece. I'd like to ask if there is any plugin, that is compatible with a monitor like that. I want to watch witch song play from centrfuse, shows equalizer graphics, monitoring system, obd info and things like that. I try to find it in that place but I didn't find something like that. Thank you.
LeroyR is offline   Reply With Quote
Old 10-09-2009, 01:59 AM   #2
The title isn't corect i mean a LCD monitor.
Old 10-09-2009, 02:01 AM   #3
sergatiuk's Avatar
sergatiuk has a little shameless behaviour in the past
i would like to see such plugin as well
2007 Toyota Tundra Double Cab SR5
>"Say what you mean and mean what you say"<
sergatiuk is offline   Reply With Quote
Old 10-09-2009, 02:44 AM   #4
I have see a video from a guy with a mazda 3 that he use a monitor like that and centrafuse frond end but i can't find the plugin that need to do that
Old 10-09-2009, 09:10 AM   #5
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
he's using his own software .. not a CF plugin, and having seen his car in person i sure wish i could set up my character LCD the same way. CF is supposed to have built in support for any HD44780-based LCD. I'm assuming yours is not compatible with that standard? My last (yea right) part of my rsx install is going to be a LCD, and somehow someway i will make it compatible with CF3 via built-in stuff or a plugin of my own.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Sonicxtacy02 is online now   Reply With Quote
Old 10-09-2009, 10:38 AM   #6
Mine is a HD44780-based LCD. It's the smartie lcd monitor. I use lcd smartie v5.4.1 software and it works perfect. Does cf support those monitors? Wow I did'n know that. You mean that you can control the monitor straight from cf?
Old 10-09-2009, 11:30 AM   #7
Well i tried to make it work but from what i see (correct me if I'm wrong please) cf can feed only vdf monitors that it's connected via a serial port?
Old 10-09-2009, 11:32 AM   #8
Terminal flasher
i dont think it HAS to be VDF.. but yes at this point i believe CF will only see serial screens.
03 Acura RSX Coupe
Old 10-09-2009, 12:42 PM   #9
I'm selling i smartie LSD monitor, anyone? Just kidding. I can put it to my media center.
O.k let's go for a serial one.
Old 10-09-2009, 12:50 PM   #10
Terminal flasher
soon as i can find a plug n play serial in the colors i want (black background/red characters) i'm going to buy it and get it working in CF.
03 Acura RSX Coupe
Old 10-09-2009, 01:00 PM   #11
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
They're a bit expensive....
http://www.matrixorbital.com/lcd-cha...cds-c-1_3.html
But they have some damn nice LCD's. Most of them are even RS232 so you can plug them right into your PC, or use a USB to serial converter.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 10-09-2009, 01:05 PM   #12
Will this adapter work? If i plug my smartie with a usb to serial converter could this work?
Old 10-09-2009, 01:11 PM   #13
Terminal flasher
i dont see that the ones at M.O state they have HD44780 compatibility though.
03 Acura RSX Coupe
DIY – Wireless USB monitor Fiberoptic Mp3Car Blog Talk 61 04-28-2009 02:05 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
Motherboard Monitor Frodoplayer Plugin? braidy Software & Software Development 1 02-21-2006 06:00 AM
Monitor components DIY naquada LCD/Display 10 01-09-2005 11:22 AM
Lorty's plugin wont work w/o monitor attatched dudah85 Software & Software Development 0 08-07-2002 11:14 PM
