11-07-2005, 04:04 PM
#1
Vehicle: 2002 Nissan Altima
StopWatch CF plugin: lamo C# plugin with source :)
UPDATE: New version available!! http://www.mp3car.com/vbulletin/showthread.php?t=66499
First plugin working!
It does nearly nothing, but may one day be remotely usefull and was a great learning experience with the centrafuse SDK
Anyone have any ideas to make it better? right now it just stops(resets) and starts a timer.
for now a screenshot :
11-07-2005, 04:17 PM
#2
Vehicle: '03 GTI 20th
Probably would be a good idea to have at least 2 timers available. Maybe the second timer could be started and stopped with the computer. Also saving timed results with options to name them. Could be useful for people who drive a lot for business.
11-07-2005, 08:13 PM
#3
There are two folders in the zip, the one called 'stopwatch' contains the plugin, just unzip it to the /plugins directory of centrafuse, assign it to a button and you are ready to go. I did not make a setup dialog for it yet, but i wil soon. The other folder in the zip, 'StopWatchPlugin' contains the source.
If anyone wants to add, modify, remake ect. go for it.
11-07-2005, 08:15 PM
#4
Vehicle: 2002 Ford F-250
The link seems to be broken
11-07-2005, 08:16 PM
#5
I just fixed it
should work now
I put a second timer in and made it so it pauses when you toggle the start/stop for each timer. The lower two buttons reset the timers, I did not yet get to creating a xml of saved times but will get to it eventually, or if someone else wants to take a shot at just email me the completed code and i will post it, enjoy!
11-07-2005, 08:17 PM
#6
Registered User
Vehicle: 04 Infiniti G35 Coupe
Huge props for even getting something working
You are a far greater man than I
11-07-2005, 08:23 PM
#7
Thanks, its nothing special, just wanted to throw it out there for others as a lightweight SDK example.
11-08-2005, 08:31 AM
#8
I just updated it with working reset buttons, updating the screen shot above
11-11-2005, 10:02 PM
#9
Just finished mid-terms
so i got the setup done, now it is skinable and you can change the langauge file ect.
I am going to add an xml save feature for the times.
11-12-2005, 03:36 PM
#10
Raw Wave
Vehicle: 2002 Honda CR-V
Thanks alti. This is a good small example for others to get braver.
11-12-2005, 07:41 PM
#11
Vehicle: '99 c5 sebring silver vette "P3rvette"
ok i tried to put it as nice as i could:
Skin kind of sucks!!!!!
11-12-2005, 08:17 PM
#12
then make your own.
That is why its skinnable
11-12-2005, 10:30 PM
#13
Raw Wave
11-30-2005, 10:52 AM
#14
Vehicle: 1999 JDM Subaru Legacy B4 RSK
How about a lap counter? Have a button you press to store the current time and continue counting. Should be relatively easy to implement based on what you have currently, and will be good for track days and the like.
11-30-2005, 05:09 PM
#15
I have created a version that saves the timers individually and allows you to add a description to the save. I also reskinned it (in neutral colors). The only thing i have left to do is a delete function to removes saves that you no longer want.
I just took a new job on monday and i have finals coming up, I will try to get that last part sorted and post it, but no promises on a time frame.
| Thread Tools |
| Display Modes |
Linear Mode
