The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Thread Tools Display Modes
Old 05-23-2006, 07:16 AM   #1
My Photos: (0)
Request: Video Capture PCI Card plugin
If i buy this card: http://cgi.ebay.com/4-CHANNEL-PCI-DV...QQcmdZViewItem
or another card that does the same thing (dont know if there are any, please tell me if you know)
Can someone make a plugin that support this card, so we can show and record 4 cams at once??
I dont know if this is possible to make without the card, but if it is, it would have been great.. No point in buying this card if it cant be used with CF..
TommyTott is offline   Reply With Quote
Sponsored Links
Old 05-23-2006, 07:38 AM   #2
shotgunefx's Avatar
Vehicle: 2002 Chrysler Sebring Coupe LXI
My Photos: (30)
As far as the card, I believe that is a Conexant 87* that multiplexes the 4 signals so you cut your frame rate with each camera.
There's a variant of that card, slightly more expensive but with 4 encoders, one for each channel. Double check before you buy.
shotgunefx is offline   Reply With Quote
Old 05-23-2006, 08:11 AM   #3
P3rv3rt B3ar's Avatar
Vehicle: '99 c5 sebring silver vette "P3rvette"
My Photos: (0)
Does nothing to do with cf... but since u seem to be rather knowledgeable about bt8x8 chipset... are u possibly aware if there exists WDM driver which allows capturing from several inputs simultaneously?
P3rv3rt B3ar is offline   Reply With Quote
Old 05-23-2006, 08:22 AM   #4
shotgunefx's Avatar
My Photos: (30)
Not really, cards like that are fairly common is all and trying to get it (or most anything) working under linux requires a bit of research.
The only windows WDM driver I came across in my travels was
http://btwincap.sourceforge.net/
an open source WDM cap driver. Don't recall if it does more than one input. I think it installs multiple devices, but not sure, was awhile back.You'll have to look at the docs.
Old 05-23-2006, 08:23 AM   #5
My Photos: (0)
I dont know what you are talking about (just a little bit)
I just want to add 3-4 cameras to my Carputer, be able to view and record them, all at the same time, within CF..
Dont know what hardware setup is the best.. I dont want to use a lot of money.. This will only be used to parking assistanse, and some small clip recording while driving av streetmeets ect..
Can any of you help me with a setup, since you seem to have some ideas about this.. Not very expencive..
Old 05-23-2006, 10:29 AM   #6
MySQL Error
veetid's Avatar
My Photos: (0)
The card should work with the upcoming version of CAM or TV plugin. I also added the ability to record from the CAM plugin to a CAM Videos folder that shows up in your library automatically.
I do not currently have the option to record multiple sources at the same time.
david
veetid is offline   Reply With Quote
Old 05-23-2006, 11:37 AM   #7
My Photos: (0)
Sounds good.. A multicam show and record would be perfect..
But, any idea for alternate setups?? Other pci cards, usb devices??
This was just something i came over on ebay, but other ideas are wanted..
Old 05-23-2006, 12:17 PM   #8
MySQL Error
veetid's Avatar
My Photos: (0)
Most cards that work in MCE and most other HTPC's should work with the new CAM and TV plugin, there are lots to choose from.
david
Old 05-23-2006, 12:49 PM   #9
My Photos: (0)
i know that there are many tv cards, but what about videocapture cards with multiple inputs??
Old 05-23-2006, 02:13 PM   #10
MySQL Error
veetid's Avatar
My Photos: (0)
I have no experience with any of them, so it's hard to say. If it has a WDM driver, then it should be no problem.
david
Sponsored Links
Old 05-23-2006, 03:13 PM   #11
My Photos: (0)
the app the hardware comes with probably works fine.
I've seen a USB version of this, 4 input USB DVR system. The framerates drop pretty low when you record both, but the screenshots of the software looked very straightforward. 4 cam displays, a record button on each, can record all at the same time, can stream online, etc etc.
I'd buy it and see what it comes with, maybe you can embed it or control it touchscreen somehow.
Vinister is offline   Reply With Quote
Old 05-23-2006, 03:23 PM   #12
My Photos: (0)
Remember where you saw this??
I live in Norway, and I havent ordered anything from the states earlier.. I want to be sure this works, before buying anything.. Shipping are often high to europe..
Old 05-23-2006, 03:47 PM   #13
shotgunefx's Avatar
My Photos: (30)
I know some years ago, a lot of those cards came with a bootleg piece of beta software called PICO 2000. It worked on 98, not so good on XP. I got mine around 3 years ago, so I have no idea what the situation is now.
Old 05-23-2006, 04:23 PM   #14
My Photos: (0)
Darn.. Hope I can find a useful card, some cheap but good cams, and a easy program to show and record multiple cams..
The program cant be hard for someone with some programming skills to make, cam it??
The way I see it, it should be something like this:
You have four cameras showing.. you select the cams you want to record by single clicking on them.. Then you have a "Rec" button.. When you click this it will record all the selected cams..
If not to much work programing, you can also have a "show" button, witch shows two cams selected in a splitted fullscreen view (for parking assistanse, front and rear)
I think many persons would like this program, so if someone could look at this, it would have been great..
Sponsored Links
vB code is On
Trackbacks are Off
The "Official" low profile card post lakorai General Hardware Discussion 8 05-22-2005 08:49 PM
PCI Video card not working TX5 General Hardware Discussion 9 10-10-2004 10:56 PM
PCI Graphics or Sound card - EPIA M10000 ZimZimmer Newbie 13 08-05-2004 10:02 PM
Help finding a 54g PCI wifi card for Procase'd carputer NJay General Hardware Discussion 19 01-21-2004 03:04 AM
Good, Cheap PCI Video card BumpNGlow General Hardware Discussion 3 07-15-2003 01:24 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
