Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 06-07-2006, 11:51 AM   #1
paulpv is on a distinguished road
Hello World plugin
I have downloaded the CF SDK and example plugins (web and weather).
The example plugins are good for education, but you sortof have to rip out most of the stuff that is in them before you can start really writing your own plugin.
It would be great to have a basic "hello world" plugin that has the minimum required skin and code to write a plugin (plus lots of comments).
veetid, do you have a template plugin that you use to start your projects from?
Would you mind sharing that with us?
I would try to produce a hello world plugin myself, but I currently only have VS2K5 installed and I cannot get CF plugins written w/ VS2K5 (.Net 2.0) to install in to CF (.Net 1.1?), so I would need to resolve this problem [by reinstalling VS2K3?] before I could create a hello world plugin.
paulpv is offline   Reply With Quote
Old 06-07-2006, 06:28 PM   #2
alti's Avatar
alti has a spectacular aura aboutalti has a spectacular aura aboutalti has a spectacular aura about
I did one in c# awhile back, (when CF 1.5 first came out) and someone ported it to vb.
you might need to modify it for 1.6 but it should be here somewhere (I will search for it now as well to make sure)
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline   Reply With Quote
Old 06-07-2006, 06:35 PM   #3
alti's Avatar
ya sorry, i could not find it, i did find the vb version (Jarrod's) but the link was broken. Here is a link to source for a plugin i did for CF 1.5 it contains my code, but for now it is another example of a working plugin (with CF version 1.5) I have not have not had any time to update it for version 1.6, it will not work in 1.6 also you will have to make whatever changes are required for 1.6
EDIT: sorry it would have been helpful if i provided the link for the source :http://www.mp3car.com/vbulletin/show...8&postcount=13
I will look later this week (friday/sat) to see if i still have the empty plugins (c# and vb) on my home dev computer.
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 06-08-2006, 04:58 AM   #4
stric is on a distinguished road
Quote: Originally Posted by paulpv
... I would try to produce a hello world plugin myself, but I currently only have VS2K5 installed and I cannot get CF plugins written w/ VS2K5 (.Net 2.0) to install in to CF (.Net 1.1?), so I would need to resolve this problem [by reinstalling VS2K3?] before I could create a hello world plugin.
Oh so for CF plugins than I need VS2003? Is there any way to make plugins in VS2005?
stric is offline   Reply With Quote
Old 06-08-2006, 02:53 PM   #5
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
There are ways to compile .NET 1.1 applications in VS2005, but I have never done it... It is usually easier and more stable to just load VS2003...
david
veetid is offline   Reply With Quote
Old 06-08-2006, 11:07 PM   #6
alti's Avatar
here is a link to the empty VB plugin i referenced above.
I was not able to find the empty c# one, I probibly lost it or morphed it into a hlf finished plugin
speaking of which here is a link to the source for the skin switcher plugin i started before it was discovered that the SDK did not support switching skins with CF running. If i remember correctly it accesses the config xml file for centrafuse that contains the name of the active skin and changes it to the one you want, but you have to reboot CF to actually get the new skin, If David can add the ability to the SDK then you would just have to modify this to do it. It two was built for CF 1.5 so it would probibly have to be modified for 1.6 as well, refer to davids API documentation for that. (I dont think i got really far with GUI on this one, I put it on hold waiting for the change to the sdk)
My Install
Software:
CFiG v1
CarShell
StopWatch
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 01:32 PM
The following squads have just been announced for the 2006 World Cup Enforcer Off Topic 2 05-17-2006 02:20 AM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
What do you think of my playlist?? SkinnyBoy Software & Software Development 19 07-19-2001 01:51 PM
