The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Thread Tools Display Modes
Old 09-04-2006, 12:37 AM   #16
midiwall's CarPC Specs
Vehicle: 1970 VW Bug
My Photos: (0)
Quote: Originally Posted by josgab View Post
Hi i'm installed cf plugin but not work with the last release of centrafuse i have mappoint 2006.
any solution pleaseee
"but not work" is pretty vague... What are the specific symptoms?
Are you having issues getting a button configured to launch it? Does the plugin load Mappoint but the GPS doesn't lock? Do you get a message saying that it can't find maps?
Which version of CF is this?
:: Mark
midiwall is offline   Reply With Quote
Sponsored Links
Old 09-04-2006, 09:46 PM   #17
My Photos: (0)
Will CFmapoint2006 work with RC2?
black06stang is offline   Reply With Quote
Old 09-04-2006, 10:17 PM   #18
My Photos: (0)
Yes, that's the setup that I'm running in my truck.
Did you try Paul's 0.82 that he released on 9/1?
:: Mark
Old 09-04-2006, 10:23 PM   #19
My Photos: (0)
Hi;
I just replied to your question on the CFMapPoint dev space. You gave more information over there, (that you only have NY and Berlin maps), so I'm thinking that you're actually running Destinator under CF and not Mappoint. the CFMappoint plugin doesn't _replace_ Destinator (the stock nav system in CF), it installs along side of it.
To use CFMapPoint, you have to create a button in CF to launch the plugin. Have you done that, or are you still clicking the "NAV" button and thinking that will launch MapPoint?
:: Mark
Old 09-06-2006, 09:13 AM   #20
My Photos: (0)
{paraphrased from my post on Paul's dev site}
You need to create a button for CFMapPoint. To do this:
  • In CF, go to SETTINGS, page DOWN one and you should see BUTTON LAYOUT. Select it, then hit SETUP.
  • This is where you configure the buttons that appear all over CF. The first set are the buttons that appear in the MENU drop list, then come the first page, then the 2nd, then the 3rd. Pick an empty spot, then click SET.
  • Scroll through that list until you see "CFMAPPOINT". Select it, and click OK.
  • Click CLOSE, then CLOSE again.
  • Flip through the pages until you find the button labeled "CFMAPPOINT".
  • Click it.
:: Mark
Sponsored Links
Old 09-12-2006, 11:04 AM   #21
Vehicle: 2003 Nissan 350Z
My Photos: (0)
Again, sorry for all of the delays folks!
Good news: My condo has an offer and is going forward to close on 8/12. I will be putting an offer in on a house to close hopefully around the same time (it will be tight). After that I should be able to concentrate more on getting CFMapPoint stabilized and v1.0 out the door.
I still use CFMapPoint myself and am fully aware of many of its problems of needed improvements.
There is a reason why I shared out the code folks!
Is anyone having *any* problems w/ getting CFMapPoint to at least *run* with either MP2K4 or MP2K6?
I am aware of some GPS imprecision and resume problems, as well as some required manual setup issues.
I will fix the GPS issues next, as well as look in to automating some last setup steps.
Are there any other known *blocking* problems?
Please post your comments either here, or preferrably on the project's site:
http://workspaces.gotdotnet.com/CFMapPoint
Thanks for the understanding of the delays!
Pv
paulpv is offline   Reply With Quote
Old 09-12-2006, 11:10 AM   #22
My Photos: (0)
midi, have you noticed any GPS precision problems?
Pv
Old 09-12-2006, 01:04 PM   #23
My Photos: (0)
Kinda', but neither instances were your issue.
I had a period of about a week where it looked like you were dropping the minus sign of the longitude, so West was becoming East (e.g., 46.80/-110.20 would become 46.80/110.20).
In digging through it I found that all of my GPS aware apps were doing this so it wasn't an issue with CFMapPoint. "Fix" wise - hard to say... It kinda' "just stopped" doing it. You know I'm a developer as well, and I HATE that crap, but I really didn't do anything 'cept a slew of reboots over a period of days.
The only thing that I actually touched was Xport3 where I shifted virtual COM ports. It may or may not have had something to do with it, but once the problem went away, I couldn't get it to come back. weird.
Past that... I've seen a couple of instances of the "20 miles off" thing, but it pops back into sync in a few minutes. I chalk that up to GPS interference (trees, mountains) and MapPoint is guessing wrong when trying to fill-in-the-blanks.
:: Mark
Old 09-12-2006, 02:48 PM   #24
My Photos: (0)
The reason for this error is a rounding error in the routine ConvertDegreeMinuteSecondToDegrees in the origional int32 was used.
I am assuming that the same code was used.
In my case when in Southampton UK the GPS had me located in the middle of english channel. At home 8 miles away all was ok.
/// <summary>
/// Expects input in dddmm.mmmm or ddmm.mmmm format
/// </summary>
/// <param name="input"></param>
/// <returns></returns> private double
ConvertDegreeMinuteSecondToDegrees(string input)
if(input == null || input.Length <=0)
return 0;
double inputvalue = Convert.ToDouble(input);
int degrees = (int)(inputvalue/100);
return degrees + (inputvalue - (degrees * 100))/60;
clarkie is offline   Reply With Quote
Old 09-12-2006, 04:11 PM   #25
My Photos: (0)
Danka! I will try to add that fix soon!
Pv
Old 09-19-2006, 03:51 PM   #26
My Photos: (0)
Pv
I have added the fix and will try to release a small patch today.
Pv
Sponsored Links
vB code is On
Trackbacks are Off
Need spectrum analyzer source code XPLORE Software & Software Development 9 12-07-2001 10:19 AM
MPXPlays Source code is available!! Fosgate Software & Software Development 3 05-30-2001 05:18 PM
c++ LCD source code mprover Software & Software Development 3 01-19-2001 03:32 PM
Keypad plugin source code brandondere General MP3Car Discussion 0 12-28-2000 09:10 PM
Dos MP3 player/decoder source code? Fosgate Software & Software Development 4 03-23-2000 03:46 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
