Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 06-15-2006, 03:31 PM   #1
paulpv is on a distinguished road
CF1.6 MapPoint 2K4 Plugin Alpha Source Code Now Available
[Copied from posting at http://forums.fluxmedia.net/viewtopic.php?t=433]
First, the screen shots...
Basic view w/ GPS lock turned off:
Planning route from Portland to Seattle w/ GPS lock turned off:
Planned route from Portland to Seattle w/ GPS lock start+current+end:
Closed route (can pull up again) w/ GPS lock current+end:
The code is at:
http://workspaces.gotdotnet.com/CFMapPoint
Currently the code is in alpha, so the project is private access only.
You are welcome to request access, but I don't yet know how GDN's access control works, so please bear w/ me while I figure out a good way to continue to control access during the alpha stages.
You *MUST* have a copy of MapPoint 2004 and Centrafuse v1.6 installed for this to work!
You may also have to edit the project settings to get it to compile right.
Let me know what I can do to make the code more portable.
The code is semi-well documented w/ TODOs.
Here are the current TODOs:
  • CFMapPoint.cs(23): TODO: Create more skinned dialogs and fancy menu/button controls
    CFMapPoint.cs(24): TODO: Implement NAV Menu
    CFMapPoint.cs(25): TODO: Auto add current location to route
    CFMapPoint.cs(26): TODO: Status Text Timer
    CFMapPoint.cs(27): TODO: Union to fit entire route (not just endpoints + current)
    CFMapPoint.cs(28): TODO: Location.FindNearby(distance)
    CFMapPoint.cs(29): TODO: GPS Options - Lock, TraceSegments, Interval, UploadURL, UploadInterval
    CFMapPoint.cs(30): TODO: Region (US or Europe)
    CFMapPoint.cs(31): TODO: Units (Miles of KM)
    CFMapPoint.cs(32): TODO: Option to turn off AllowEdgePan
    CFMapPoint.cs(33): TODO: Find itinerary window and resize to half of control height
    CFMapPoint.cs(34): TODO: Intercept ALT-F4 close and save map (Application.BeforeClose or Application.Quit)
    CFMapPoint.cs(35): TODO: Routing user preferences (aka: DriverProfile)
    CFMapPoint.cs(36): TODO: Make use of ShowFindDialog?
    CFMapPoint.cs(37): TODO: Categorize FindResults by Type, StreetAddress, PlaceCategory
    CFMapPoint.cs(38): TODO: Print?
    CFMapPoint.cs(39): TODO: Save as WebPages? ActiveMap.SaveAs("file.htm", GeoSaveFormat.geoFormatHTMLMapAndDirections, false);
    CFMapPoint.cs(40): TODO: Make use of LocationToX and LocationToY to make UI a bit more fluid
    CFMapPoint.cs(41): TODO: Map.Union(locations...).GoTo() to make UI a bit more fluid
    CFMapPoint.cs(42): TODO: Make use of PixelSize to make UI a bit more fluid
    CFMapPoint.cs(43): TODO: Selected area?
    CFMapPoint.cs(44): TODO: Selection?
    CFMapPoint.cs(45): TODO: Shapes?
    CFMapPoint.cs(46): TODO: Symbols?
    CFMapPoint.cs(47): TODO: MP2K6 map rotation? (via SendKeys?)
    CFMapPoint.cs(48): TODO: Flicker free BitBlt drawing?
    CFMapPoint.cs(50): TODO: Traffic
    CFMapPoint.cs(51): TODO: Construction updates
    CFMapPoint.cs(356): TODO: Better way to get full path to plugin directory?
    CFMapPoint.cs(721): TODO: Find out where this is this used, or remove
    CFMapPoint.cs(950): TODO: Proper way to search for nearby places (by cetegory?)
    CFMapPoint.cs(1136): TODO: Make IDisposable? (sometimes helps to close GPS thread)
    CFMapPoint.cs(1172): TODO: Initialize to current map location?
    CFMapPoint.cs(1177): TODO: Find and use C# struct for HRESULT
    CFMapPoint.cs(1192): TODO: handle error (disconnect, etc) or poor quality (# sats, etc)...
    CFMapPoint.cs(1528): TODO: Make use of oPlace.PlaceCategory?
    CFMapPoint.cs(1606): TODO: Handle case when we delete the last waypoint
    CFMapPoint.cs(1644): TODO: Turning trace on and off should clear listGPSTraceSegments
    CFMapPoint.cs(1660): TODO: Determine threshold
    CFMapPoint.cs(1753): TODO: Center relative to current view point (ie: relative coordinate system)
    CFMapPoint.cs(1762): TODO: Use logic that handles the different LockMode types
    CFMapPoint.cs(1789): TODO: zoom to closest POI (milestone, landmark, city, intersection, etc.)
    CFMapPoint.cs(1797): TODO: Need to zoom out a tiny bit
I will try to put together an installer by the end of this weekend.
You will still need to have MapPoint 2K4 installed for it to work.
I have not tested it WITHOUT MapPoint installed.
I have MP2K6 still in its box and will be installing it soon and making the plugin work with that too.
I will give my MP2K4 to the first person that assists me in making sure that the plugin fails gracefully without at least MP2K4 installed.
Pv
paulpv is offline   Reply With Quote
Old 06-15-2006, 04:59 PM   #2
P3rv3rt B3ar's Avatar
P3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud of
Awesome!
P3rv3rt B3ar is offline   Reply With Quote
Old 06-16-2006, 03:58 AM   #3
Installer available and GDN project opened to public
I have opened up the GDN project site to the public:
I have also created a simple installer to make it easier to...well...install!
You can find the installer at the GDN site [above].
Do let me know if you have any immediate blocking problems.
Again, you WILL need MapPoint 2K4 in order for this to work.
Try it out without MP2K4 and let me know how it goes!
Pv
Old 06-16-2006, 09:24 AM   #4
Cirion is on a distinguished road
Will it work with MS Autoroute? Autoroute is the Europe version of Mappoint.
Cirion is offline   Reply With Quote
Old 06-16-2006, 11:02 AM   #5
AutoRoute is the European version of Streets and Trips.
S&T and MP are fairly different from each other in their offerings.
Only MP has a programming object model that is exposed to development.
So, the short answer is "No".
But you bring up a good point.
CFMapPoint does not yet support European MP.
It is just a simple startup flag, but:
  1. I don't have the European version to test it with.
  2. I need to add an option to the UI
Pv
Old 06-16-2006, 01:52 PM   #6
Latest release should now support MP2K4 Europe.
I don't have a copy of MP2K4 Europe, so if you do please try it out and let me know!
Thanks!
Pv
Old 06-16-2006, 03:20 PM   #7
alanw is on a distinguished road
paulpv, I think I love you.
Or at least I will if I can get the Euro MP working. It CAN'T suck harder than Destinator in its current guise...
alanw is offline   Reply With Quote
Old 06-16-2006, 05:24 PM   #8
midiwall is on a distinguished road
_perfect!_
Absolutely wonderful!
Do you have a PayPal address that I can donate to? (seriously!)
:: Mark
midiwall is offline   Reply With Quote
Old 06-18-2006, 07:56 AM   #9
daemon is on a distinguished road
Yall,
The plugin works great as well with MP2K6 without any problem. Great Job.
daemon is offline   Reply With Quote
Old 06-18-2006, 12:01 PM   #10
I certainly hope u happen to be the 2nd female member of these forums...
Old 06-19-2006, 08:58 AM   #11
Quote: Originally Posted by daemon
Yall,
Now THAT is some awesome news!
Time to install!
:: Mark
Old 06-19-2006, 09:52 AM   #12
stric is on a distinguished road
stric is offline   Reply With Quote
Old 06-19-2006, 01:04 PM   #13
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Good work at putting this together, and making it available to everyone. With little fanfare to boot. Kudos!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 06-21-2006, 01:41 PM   #14
Yall,
fwiw, as of this morning, I can confirm this! It is SO cool to have full maps in CF!
THANK YOU PAUL!
:: Mark
Old 09-04-2006, 12:35 AM   #15
josgab is an unknown quantity at this point
new centrafuse not work with mappoint 2006
Hi i'm installed cf plugin but not work with the last release of centrafuse i have mappoint 2006.
any solution pleaseee
josgab is offline   Reply With Quote
Need spectrum analyzer source code XPLORE Software & Software Development 9 12-07-2001 11:19 AM
MPXPlays Source code is available!! Fosgate Software & Software Development 3 05-30-2001 06:18 PM
c++ LCD source code mprover Software & Software Development 3 01-19-2001 04:32 PM
Keypad plugin source code brandondere General MP3Car Discussion 0 12-28-2000 10:10 PM
Dos MP3 player/decoder source code? Fosgate Software & Software Development 4 03-23-2000 04:46 AM
