for some reason im having a problem with this. i got this persons calendar plugin working great, but for some reason the calc is not working. i add the plugin, restart CF and it still does not show up. any thoughts?
and another general cf n00b question...what the hell is the button in the right corner for? its almost an "x" and its inbetween the advance track button and gamma button.
I am creating a Nexus skin for your calc plugin, but I have found a small issue (bug?).
It appears that the INPUT box field has a fixed size of digits, so if I make the box smaller and the font larger, it truncates... Can you add some code in there so it knows not to truncate, and handle the scientific notation a little better?
See my screenshot and compare the resulting number in the BOX field (top) vs the INPUT field (bottom)
Hi JIT, thank you for making skin . Yes this plugin need's some work, around numbers input. I was planing to add the max length of number in skin.xml file, but forgot it. Will add as soon as possible. (after next Calendar relese)
While you are at it, you might want to check how the BOX field works... mine is pretty tall, but it only displays a few lines... see my pic? It has plenty space above and below that I'd like to be usable. Also, truncation may occur in this BOX field too...
stric, how have you made your entry log? I have problems making the message log for my messenger plugin work properly, and was wondering if you could give me some input or source code?
