Hi, I finally made some progress with this.
Here (see next post for new version) is the first beta release.
It is without installer so you must manually put it inside your Plugins folder.
The skin is terrible... The first page; big black box is useless. You can only press it to get to the notes section (it will be removed and you will get to notes by pressing a day or there will be some other button...).
In notes section the last row of buttons is not active. They will also be removed.
The usable buttons are: CLOSE, up/down, and add and remove.
If you double click on note it will be read (text-to-speech).
When you add note:
- first press add ( + )
- than enter note
- if you want to add reminder press yes otherwise no (and you are done)
- if you pressed yes: you must delete hh:mm and enter time when reminder should pop up on that day in format hh:mm. !It is important to use this format (24h)!
- that should be it
The arrow is next to the notes with reminder.
Please test it and report.
Remember this is first beta release so the plugin will change before final release.
