08-29-2006, 09:53 PM
#31
Vehicle: 2002 Nissan Altima
really sorry JIT, I did quickly make the window non model, but i have to iron out focus on it, anytime I touch volume or track controls on the bottom the view history screen disappears and the main stopwatch screen jumps up. I want to see if i can fix this.
I have had a crazy week, I thank you for the effort you put into the skin, and appoligize again. As soon as i can find some more time I will get it up (with thoose config fixes as well)
08-29-2006, 10:20 PM
#32
Raw Wave
Vehicle: 2002 Honda CR-V
OK alti, I hope you can figure it out.
09-01-2006, 05:47 PM
#33
I finally have the fixes in (i hope) I just have to edit my skin slightly to test
09-06-2006, 09:39 PM
#34
Raw Wave
Alti,
Any update? I'd love to get this Nexus skin released for the plugin....
09-07-2006, 11:27 PM
#35
Banned
Vehicle: 3000GT VR4
Quote: Originally Posted by justintime
Alti,
09-07-2006, 11:59 PM
#36
ya its sorta working, sorta broken
I have it working past the focus issue, but if someone presses the close button (the main CF one on the bottom right, not the one in stopwatch) twice while the savedtimer window is open without closing it first. It causes a situation where the are you sure you want to exit box gets stuck behind the svaedtimers window...
other then that its working
If i can not find a fix I will put up the update tomorrow, it works otherwise.
09-08-2006, 09:23 PM
#37
ok, updated file is up!
there are still a few minor things i found i have to iron out, but nothing that will affect your skin.
09-08-2006, 10:39 PM
#38
Raw Wave
Thanks Alti. I see what you mean... if you chose the MAIN button while in the LoadTimers screen, you can lock yourself out. You need to fix that!
OK, here is my Nexus skin for StopWatch.
09-08-2006, 10:59 PM
#39
sweet! thanks JIT
I added the nexus skin to my zip file, so if anyone is currently using nexus they will not have to go through the extra step of downloading your zip...
I noticed in the nexus thread you mentioned including it in your skin install.. let me know if i should take it out of my zip when you do that
thanks again, it really looks sweet..
09-20-2006, 03:31 PM
#40
Raw Wave
Alti:
Looks like the Stopwatch plugin also needs to be recompiled for RC3. The show timers dialog is not showing up correctly anymore under rc3.
I guess you should just recompile all your plugins to be safe.
Good luck with the marriage. Worked out well for me so far!
09-20-2006, 10:07 PM
#41
recomplied and uploaded, hope it fixes the issue, let me know...
09-21-2006, 09:48 AM
#42
Raw Wave
Hi Alti,
I installed the new version, and the issue is still present
Here is what I get when I try to view the saved timers. The same happens with your base Onyx skins!
09-21-2006, 10:47 AM
#43
ok, something must have changed, I will look into it...
10-03-2006, 01:12 PM
#44
Vehicle: 1999 Nissan 200sx S14a (280bhp)
Seems to not display properly for me (in Onyx std. Skin), skin seems too wide for 800x600 screen
10-03-2006, 05:43 PM
#45
ok, I am just starting to get back to a semi normal life, I will take a look and see whats broken here....
| Thread Tools |
| Display Modes |
Linear Mode
