03-23-2007, 12:05 PM
#31
MySQL Error
Quote: Originally Posted by urosbe
No, there is a only
\Add-ons\X10RC\Radiator.icf
no Command line and rc.exe??
You are talking about Radiator path (C:\Program Files\Radiator\Add-ons...), aren't you?
So search the internet and get that file and place it in that folder... If you install the regular radiator it should have placed it their automatically... Some custom installs of Radiator might not include it...
should be easy to find an fix your problem...
david
03-25-2007, 05:35 PM
#32
Hm, I have downloaded Radiator from offical site? Do you have some other link where can I get version that works with CF?
System: VIA EPIA EN15000,512 MB DDRII,M2-ATX,300GB HDD,XENARC 1020TSV,VoomPC case
USB: Powermate,WinTV+FM,WLAN 54G,Bluetooth,Haicom GPS mouse SIRFIII
Software: Windows TinyXP Rev06+MinLogon+EWF+HORM+Centrafuse 1.2
Honda delSol project
CarDomain
03-25-2007, 05:54 PM
#33
MySQL Error
unless he changed his installer that rc.exe program was always included with his install package...
anyone else have suggesetion?
I haven't used radiator in a long time...
david
03-26-2007, 03:00 AM
#34
I have this one:
Offical site:
Radiator
Offical download:
http://flesko.cz/radiator.zip
(setup.exe is dated 20th December 2004, size: 2.355.579 bytes)
CarDomain
03-26-2007, 12:18 PM
#35
MySQL Error
I will check it out... CF Radiator Plugin uses rc.exe which use to always be included, it should be on his site somewhere...
david
03-26-2007, 12:49 PM
#36
uros, did u try it on a computer other than ur carpc?
VIA EN15000 C7 // CTF700 7" Screen // Morex 3688 Black Case
M2-ATX // 80GB HD
DVD-RW // PowerMate
Belkin Bluetooth V1.2 // Hauppauge WinTV FM
Centrafuse RC5
JBL GTO 75.4 520W // Pionneer Kevlar 260w Speakers
03-27-2007, 03:02 AM
#37
Of course. I have tried at home too...
SUVputer: Do you have RC.EXE in Add-ons\Command Line? In case you do, you probably still have full setup installation?
Uros
CarDomain
03-27-2007, 12:08 PM
#38
I will be back home next week end, i will send you all the files.. and will check the config for u... i left my car at home and i'm in france right now
M2-ATX // 80GB HD
DVD-RW // PowerMate
Centrafuse RC5
03-28-2007, 03:26 AM
#39
Thank you!
CarDomain
04-07-2007, 02:53 AM
#40
Hey,
I just came back.... I reinstalled Centrafuse since it was expired.. went into FM/AM and chose Hauppauge with Mic as In and it now works perfectly.. (make sure that "none" is selected in the TV config)
i've copied the .xml config file.. find it attached.. i hope it'll be usefull!
M2-ATX // 80GB HD
DVD-RW // PowerMate
Centrafuse RC5
04-14-2007, 02:08 AM
#41
Hi!
I wasn't online for a while, now I see that you have attached Radiator dll and xml - thanks, but is it possible that you attach Radiator setup package (the one that creates "Add-ons\Command Line\RC.exe"), because mine doesn't?
Uros
CarDomain
04-14-2007, 02:18 AM
#42
You mean the installation file? I've found a zip file called "radiator" of my PC, it's 2.23MB large... is that what you're looking for?
M2-ATX // 80GB HD
DVD-RW // PowerMate
Centrafuse RC5
05-01-2007, 05:31 PM
#43
Yes, this is exactly what I am looking for. Is it possible that you send it to me via email?
CarDomain
05-29-2007, 04:42 PM
#44
Hello,
I've just installed the 1.12 then 1.14 versions and centrafuse insn't controlling anymore Radiator with WinTV FM... it used to work perfectly with the previous versions...
any tip or modi ??
Thanks!
M2-ATX // 80GB HD
DVD-RW // PowerMate
Centrafuse RC5
05-29-2007, 05:44 PM
#45
MySQL Error
this was a bug and has been fixed...
I will update tomorrow with a quick 1.15 which includes the radiator update...
david
| Thread Tools |
| Display Modes |
Linear Mode
